Question about Apple iPod MA446LL/A MP3 Player
USB overload After changing the battery it worked fine for the first few recharges. but now I get a message saying usb port overloaded by powersurge.
  • dddickd Aug 18, 2009
    Sorry I dont understand what you mean.
  • 39 Answers
Plz chenge your Charge
Posted on Aug 18, 2009
SOURCE:
What will happen if I just continue to ignore the usb/ power overload message on my tv...seeing No idea how to fix it
Samsung TV - USB Device Not Found - Power Overload error message
I'm posting this since there's very little information available that explains how to resolve the following error message that you might receive on your Samsung TV. For many months, I have been receiving an error message pop up on the bottom left corner of my screen. The error message would say "USB Device Not Found. USB1 (or USB2) Power Overload." This message popped up without me ever doing anything with either USB port. In fact, I've never even used the USB ports on my Samsung TV. The message would appear at random and stay on for a few seconds or minutes. It's more annoying than anything.
To resolve this issue, I went to Samsung's website and navigated to their support section for my particular Samsung TV model. From there, you can download the latest firmware update for your TV and copy it to a USB flash drive. Once the firmware update is on your flash drive, you'll need to extract the files since they're zipped. At that point, you'll plug the flash drive into your TV's USB port. Go to your TV's menu and navigate to the section where you can update your firmware. On my specific Samsung, I went to my TV's Menu >> Support >> Software Upgrade >> By USB. This will start the update process and your TV will reboot once complete.
So far, my TV has operated great after the firmware update. I've not received the USB Device Not Found, USB1 or USB2 Power Overload error. Hopefully this will resolve the issue for me permanently. I'll update this post if the error message reappears.
usb power overload message on my tv Google Search
Apr 08, 2018 | Televison & Video
How do you recharge batteries with the usb
yes you can or many places they sell wall/car adapters that charge USB devices you have to look around .
Jul 09, 2016 | Garmin Etrex 20 Gps
Okay, I've just joined and I'm hoping someone can help. So tonight, I plugged in my iPhone to the left usb ports (as I always do before bed)(The right ones are disconnected for some reason, I think the...
I expect the iphone has overloaded the USB supply. The current the ports can supply is limited and will stop working if overloaded. Use a powered USB hub or the iphone charger. Your motherboard may need repairing now.
Jan 13, 2015 | Computers & Internet
USB port gives new message "unknown device"
hello allan213
my name is ausi.
is it on all usb ports only one of them if it is in only one of them then the message you getting generaly means one of thw follwng.
1- if it is in only one of the ports then try it with a different device as well to see if it is the actual port or not.
2- the device you have plugged in needs to have drivers installed. normally should have been supplied with it.
3- the device you plugging in is faulty and the system can not access it.
4- the system usb ports are overloaded. (too many usb devices connected simultaneously)
good luck
Jan 05, 2011 | Intel Motherboard
My ipod won't charge. keeps saying "please wait. very low battery" what's wrong with it?
I had the same problem. Went to the Apple store and the technician said that the IPOD battery ran down to low (battery level showed red) and the USB port on the computer was not strong enough to recharge it. He used a rechargeable adapter that pluged directly into the wall (adapter cost about $30) and recharged it enough for me to take it home and recharge it on my computer.He said to never let the battery level drop below 5% unless you are going to recharge it using the adapter that pluged into the wall. I bought an IPOD rechargeable travel kit from Target for $20 and used it to recharge my IPOD. My IPOD works fine now. The Technician also said at some point the battery will need to be replaced (in a year or two depends). Will cost about $59 to replace it (don't quote me on the timeframe or price of replacement, this may have been just for my IPOD but thought this would be useful info for someone.
Nov 24, 2009 | Apple iPod MA446LL/A MP3 Player
When I connect the printer I get a hub overload message. I can't reinstall because the computer connect manager doesn't see the printer. It did work until recently
Believe it or not, this problem is actually related to the computer, not the printer.
I can tell by the error message that you are plugged into a USB hub. Unplug it from the hub, then plug it directly into your computer's back USB ports, not the front ones. It will probably work now.
To properly fix the issue, you need to purchase a powered USB hub.
Essentially this happens because the printer is power hungry. Passive USB hubs like the one you have can only provide enough juice that your computer gives it. Since your computer doesn't want to fry out by "overloading" the voltage on the line, it reduces the power and throws that error message.
Now, if you are getting this message on a laptop computer OR you plugged the printer into the back ports and the unit STILL does not work, the printer or USB cable has a short and needs to be replaced.
Good luck. Please rate my response or post a comment on your original question to allow me to further assist you.
Aug 15, 2009 | HP Deskjet 3845 InkJet Printer
An error message stating that the device overloaded the usb port appears (yellow light at the port).
Go to the device manager and uninstall all usb devices. Turn off computer, unplug all usb, reboot twice, plug usb in again. Also helpful are troubleshooting usb articles here and here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
May 21, 2009 | HP PhotoSmart 7960 InkJet Printer
Message usb powersurge
Beep codes instructions:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=bph07107&dlc=en&product=362754
Please remember to rate all users who assist you for free :)
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Sep 30, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
USB port defective
Have you tried another USB cable? As long as it's got the same mini-USB connector, they are universal. Most digital cameras use these same cables, as well as many MP3 players and other handheld electronics devices.
If this doesn't fix it, most likely, it's a defective USB interface chip in the unit... and will need to be serviced. GARMIN 1-800-800-1020 (USA).
Fortunately, the USB ports on PC's are protected. When an overload is detected (> 500mA), the USB controller shuts down the offending port. This port can then be restored manually through the USB disgnostics, or simply shutting the PC down, and restarting it.
Mar 31, 2008 | Garmin StreetPilot c340 GPS Receiver
Apple iPod MA446LL/A MP3 Player Logo
Top Apple Audio Players & Recorders Experts
Parshiv Luthra
Marvin
Marvin
Will Mishler
Will Mishler
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
