Question about Philips HTS3450 System
Is there really any recourse?
Http://www.fixya.com/support/t246879-speakers_buzz_about_1_minute_when
  • Anonymous Dec 25, 2008
    I replaced capacitors with the 470uF/35V and still no sound. Red light on subwoofer still on, fan still not working. Any other suggestions?
  • 20 Answers
There are two 470uF/25V capacitors on the power supply board in the sub-woofer that are the cause of buzzing, crackling and then eventually no sound. Go to Radio Shack and buy two Catalog #272-1030 470uF/35V capacitors and change them out. They are in the middle of the Power Supply PCB and are close to the long flat aluminum heatsink. As far as installation instructions go; you have to have some soldering experience, first. You will also need some type of de-soldering device, be it a solder ****** or solder wick to remove the caps. Make note of the polarity before removing. Then it is just a matter of popping the new ones in (they are slightly larger than the originals so they might not go all the way down flush with the PCB) and soldering them back in. Make sure you do not make any solder shorts or your system will be toast! Your unit will be as good as new and will probably last forever now.
Posted on Jul 26, 2008
SOURCE:
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
Sylvania 7" netbook speakers have a loud buzzing
You may have to re-flash your system as the sound driver is inoperative. You can check at www.digital gadgets.com or follow my TIP at: http://www.fixya.com/support/r7350901-fix_synet07526_wifi_flashing
Mar 22, 2011 | Sylvania G-Netbook
The symptoms: fan starts and so does buzzing. buzzes for about 5 seconds then stops, compressor does not start. 1 minute passes fan still running buzzes for 5 sec then stops compressor does not start...
freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Sep 10, 2010 | Maytag MSD2756GES Side by Side...
No sound comes out but my speakers buzz. What do I do? I have a Yamaha RX-V661.
Sorry but you have to get your amplifier at a technician. The buzz from the speakers means internal electronic damage at the amplifier. TAKE CARE THAT in case of keeping the speakers on the buzz noise for some seconds may destroy the speakers.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Sep 04, 2010 | Yamaha RX-V661 Receiver
Freezer light comes on and dim when compressor starts to kick on. breaker trips after compresser runs and squeals for about 1 minute.
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
heatman101
Aug 23, 2010 | True 23 cu. ft. / 651 liter Commercial...
Buzzing noise from dryer and wont start
It sounds like your motor has gone bad....it will buzz really bad when it is trying to start and cannot...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
heatman101
Asker's Testimonial " Thanks so much for your help. Now that you'v mentioned it, the buzzing does sound like it's coming from the motor. I'm,now, more comfortable in call " -
Apr 12, 2010 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
When I push the button to start the dryer, it just makes a buzzing sound, but does not start. It was working fine 30 minutes ago.
It sounds like your motor has gone bad....it will buzz really bad when it is tring to start and cannot...
heatman101
Apr 11, 2010 | Maytag MED5707TQ Electric Dryer
Dryer is making a buzzing sound and not starting RoperRED4440SQ0
heatman101
Apr 11, 2010 | Dryers
Sound card broken? No normal sound and a constant buzz...
Sounds like you tried everything possible. Based on what you have stated that you tried already I would agree with your diagnosis of a bad sound card.
If this was my Laptop I would be looking for a nice set of USB speakers and Microphone or a headset.
You can either keep the speakers turned down or you may be able to disable the onboard sound through a BIOS setting.
Or even better. Here is a USB sound card with speaker and microphone jacks. Pretty Cheap too.
http://www.wolfcamera.com/product/EP4497467.htm
Jan 06, 2008 | HP Pavilion dv9000z Notebook
Philips HTS3450 System Logo
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
