Question about Scytek 2000RS-M Remote Control
Galaxy 2000 RS Remote Starter
When I press the start button, the 2 way remote control operates normally by beeping, but will not engage the starter motor of my vehicle. The remote starter battery is new. The unit was purchased, and professionally installed, and has worked well for the past two winters. This year it just won't engage the starter motor. Help please. Thank you
  • 1 more comment
  • Anonymous Nov 15, 2008
    my remote would not start but would lock and open doors why
  • Christopher Renner
    Christopher Renner May 11, 2010
    dayme - if you still have this problem:
    Do the parking lights flash when you push the button on the 2-way? If so, how many times?
    Do the dash lights/heater blower come on when you push the button?
    What is the year/make/model of the vehicle?
  • Anonymous Mar 21, 2014
    Purchased a vehicle with a Viper 474 remote start. I don't have the manual and would like know which buttons do what ?
    Problem Solver:
  • 13 Answers
Go to bulldog security.com and look for your vehicle under free wiring diagrams
Posted on Mar 30, 2008
the parking lights flash 3 times when i hit the button
Posted on Dec 02, 2010
I bought a remote starter, but need wiring info.
Posted on Jan 07, 2008
3 Suggested Answers
  • 13433 Answers
SOURCE: Galaxy 2000 RS Remote Starter
If everything else seems to be working fine I would suggest to double check the battery and the starter motor. not enought power to start up? Thats what comes to mind.
I'm not a professional car repair tech, you may ask other experts for advice
Thanks,
Ekse
Posted on Sep 06, 2008
SFroese
  • 141 Answers
Sounds like the circuit that engages the starter system is not working. Are you able to trace the wiring that goes to the ignition harness?
Factory remote start wont work. hit button horn bbeps all lights and radio come on. when horn beeps second time car wont crank as it always has in the past
Ford Keyless Remote Car Starter fix - YouTube
? 5:14
https://www.youtube.com/watch?v=fQHb0mU0rvI
Jun 24, 2012 - Uploaded by mitch cox
I bought a 2010 Ford Raptor my remote starter won't work? when I press the .... 2013 lincoln navigator, 2-Way Remote StartSystem and i press button ... a Ford OEM 1-Way 100 Series Keyless Remote Start (CM5Z-19G364-A).
1998 to 2008 Lincoln Navigator Factory Transmitter Remote ...
? 3:00
https://www.youtube.com/watch?v=sLMN34KN3nY
Nov 2, 2012 - Uploaded by Lessco Electronics
1. Close all doors and then open drivers door and press the UNLOCK button on drivers door panel while door ...
2008 Lincoln Navigator Remote Start Accessories ' Th
Dec 12, 2015 | 2008 Lincoln Navigator
Thanks,
Ekse
Sep 06, 2008 | Scytek 2000RS-M Remote Control
Electrical problem
Hi Anonymous and the usual suspects are:
1. Ignition switch not in the "ON" position.
2. Engine run switch in the "OFF" position.
3. Discharged battery, loose, corroded or broken battery cables, especially the "NEGATIVE" cable at both ends (solenoid chatters).
4. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
5. Security alarm needs a reset.
6. Starter control circuit, relay, or solenoid faulty.
7. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
For more information about your issue, please visit the websites below. Good luck and have nice a day.
DOWNLOAD 2000 Aprilia Rs 125
Mar 25, 2014 | 2000 Aprilia RS 125
Remote starter not working
Check to make sure the remote start kill switch isn't broken. There should be a switch under your driver seat or gas pedal that turns your engine off if someone tries to drive off with your car while you're warming it up. If that switch is damaged, it can trick your remote start system into thinking there's someone in your car, and preventing the system from starting up at all.
Dec 12, 2013 | Viper 5301 4202V Remote Start System and...
I bought a used truck with a bulldog remote starter in it but the guy has it set to start when it reaches a -10. I want to reset so only starts when I hit the button. The key fob looks alot like the rs...
PRESS AND HOLD THE BRAKE PEDEL, PRESS AND HOLD BUTTON 2 UNTIL PARKING LIGHTS FLASH 2 TIMES, RELEASE BUTTON 2 AND PRESS AND HOLD AGAIN UNTIL 2 FAST FLASHES ARE HEARD, RELEASE BRAKES AND LIGHTS WILL FLASH 3 TIMES, THERE ARE 7 DIFFERENT SETTINGS SO IT MIGHT A COUPLE SECONDS TO COMPLETE
Feb 01, 2010 | Bulldog Remote Starter & T-Harness Kit for...
Scytek 5100 RS-2W system Problem
How do you reset the remote, alarm. I have a scytek two way security alarm, remote start. I can lock and unlock my vehicle, however the remote start and alarm won't work. When I press the middle button to have the car start it just beeps, and when I lock my car it just locks it doesn't beep to let me know the alarm is on.
Please advise, do I need another alarm, or just reset it.
Claudia
Aug 14, 2009 | 5000RS-2W Remote Starter with...
Remote starter on a 2004 Accord with V6 engine
remote starter is designed to shut down the vehicle if there is no key to drive with. This is a security feature so that unauthorzed drivers cannot steal it. to answer second question the purpose of remote starters is to allow you to heat up the vehicle so it is an ice cube when you are ready to drive. Not sure what remote I cannot answer the horn question. Need more on what remote starter you have model number and make
Apr 20, 2009 | 2004 Honda Accord
I cant start my car with the remote starter
You normally have to while the car is running transmition in neutral push the brake pedal, put the emergancy brake on, release the foot brake, press the remote start button on the remote, take keys out of ignition switch, car should stay running, get out, press the lock button on remote starter remote, car should shut off, and now is set
Feb 05, 2009 | 2002 Hyundai Accent
Galaxy 2000 Rs-m
yes, you can connect the tach sense wire from the controller(2000rs) to a fuel injector , and select tach monitor in the programming (see manual, available at scytek.net) and it will automaticcally adjust the starter crank time, other way to go is to install a delay card, sutch as the k 141 multi mode timer, and set it to crank for 3-6 seconds when triggered
May 26, 2008 | Scytek 2000RS-M Remote Control
Scytek 2000RS-M Remote Control Logo
1,545 people viewed this question
Top Scytek Televison & Video Experts
Are you a Scytek Televison and Video Expert? Answer questions, earn points and help others
