Question about Lakewood Oil-Filled Electric Radiator Heater
Rocker switch for 600 watts broken----
Need rocker switch assembly for oil fill radiator 500
  • mronde Dec 01, 2007
    YOU ARE A BUNCH OF CROOKS--I WILL MAKE SURE THAT YOUR TYPE OF SERVICE RECEIVES ALL THE ATTENTION YOU DESERVE.
    YOU ARE GUILTY OF SELLING PRODUCTS IN THE USA WITHOUT ANY MEANS TO PROVIDE LOGISTICAL SUPPORT WITHOUT HAVING TO PAY RANSOM TO A RESEARCH OUTFIT.
  • pemars Dec 24, 2007
    Lakewood Heater rocker switch broken on the left side (600W).  The right side still works (900W)
    pemars@atlanticbb.net
  • 625 Answers
First of all complaining to FixYa isn't going to accomplish anything. I doubt that the supplier of your device even knows about FixYa. Now on to your problem --- can you get me any numbers off the rocker switch? I'll do the research and get back to you. Use my original email address which can be found in my profile.
Posted on Dec 06, 2007
I was quoted $500 to replace all the lifters. Is this a good price?
That is a ridiculously high price to replace lifters on a 4 or 6 cylinder engine. On the Mitsubishi 4 cylinder motor, the only thing that is needed to do is remove the valve cover and remove the rocker rod. (2 rods which hold the rocker assembly.) Next is remove the lifters from the bottoms of the rockers and pop in the new ones. Be sure to soak the new lifters in oil for 24-48hrs prior to install so they are pre-filled before install. Replace the rocker assembly and torque down to specs. replace valve cover and then start the vehicle. Check that there is no loud tapping noise and do not race the engine until the lifters have pumped up with engine oil. You should replace oil and filter for this engine work as well.
Apr 17, 2015 | 1994 Mitsubishi Mighty Max
Ew6507l - nowhere near warm enough
only made for 400 to 600 sq feet try Eden pure heater 1500 watts than cover 1000 sq feet the oil fill heater might have a switch 600 to 1500 watt there r usually a high and low to them good luck
Dec 11, 2013 | DeLonghi 6507L Oil Filled Radiator Heater
I have a Lakewood oil filled heater, mod # 7096. It heats, but not heat like it used too. I have checked the on/off switch, thermostat, and both seem to function properly. I have done a resistence check of...
No, the oil does not break down over the years of service. These units are made and sealed from the factory. The purpose is to make a unit that does not require repairs and will run for years. It appears that the TSTAT is not sending proper amperage through. My suggestion is to replace the unit as it costs more to repair then to replace.
Sorry for the bad news, but these units are just not meant for service, hence the price.
Jan 27, 2011 | Lakewood Oil-Filled Electric Radiator...
How do you turn on a comfort zone cz7007? has a knob that turns up to 7 and 2 red switches right next to each other.
On the comfort zone CZ7007, the #1 rocker switch is for 600 watts, the #2 rocker switch is for 900 watts. If you flip 1 and 2 both to on you will get 1500 watts. Which is 600 and 900 added together. There is no down position, but only on and off.
Sep 24, 2010 | Comfort Zone CZ7007 Oil Filled Electric...
Both togggle switches are broken
Go to the hardware store and match them up, they have toggle switch. Get the heavy duty 20 amp switch.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Oct 03, 2009 | Heating & Cooling
Actual output on settings
MODEL DELONGHI TRD0820ER 2KW OIL FILLED RADIATOR
YOU HAVE THREE SETTINGS
1. 900 WATTS
2. 1.1 KW 1,000 WATTS WHICH IS ABOUT 1.096 WATT
3. 2.0 KW 2,000 WATTS
Nov 25, 2008 | DeLonghi Dragon 3 1025 / 1025T Oil Filled...
Switch
Try this link   http://www.nelsonappliance.com/Space+Heater+Parts.html
Mar 24, 2008 | Lakewood Oil-Filled Electric Radiator...
Lakewood Oil-Filled Electric Radiator Heater Logo
529 people viewed this question
Top Lakewood Heating & Cooling Experts
jay kaye
jay kaye
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
Are you a Lakewood Heating and Cooling Expert? Answer questions, earn points and help others
