Question about Yamaha HTR-5240 Receiver
HTR-5240 Will not play audio when switching to DSP
When I switch the effects off, I can get analog audio ok, but when switching to any of the DSP fields, there is no audio. We've had some storms a while back that might have caused this issue.
I tried resetting it by setting to standby and unplugging it for a while but still nogo. Thanks.
  • 31 Answers
Most likely your DSP board is bad, usually a pretty costly repair and sometimes the board is hard to find in stock.
DSP--Digital Signal Processor
Posted on Mar 08, 2008
SOURCE:
How can I lock my Input Mode setting?
sounds like you have too much hooked up trying to do the same thing and are fighting each other .
May 12, 2015 | Yamaha Audio Players & Recorders
My yamaha HTR 5240 comes on for like 2 seconds and then turns off
That proves the audio output stage is shorted on or two channels. It will need to be checked out to assess the situation.
Apr 15, 2012 | Yamaha HTR-5240 Receiver
I am looking for the owner's manuel the YAMAHA HTR5660
http://www2.yamaha.co.jp/manual/pdf/av/english/re/HTR-5240.pdf
Jan 05, 2009 | Yamaha HTR-5240 Receiver
Random Shutoff of Yamaha HTR-5240 When Playing Movie DVDs
I found this answer up above and it working. I check my speaker wires and fixed some and it has been working since then. I copied the answer below.
ce3810b.jpg barbu51
Rank: Guru
Rating: 91%, 206 votes
First i would strongly suggest that you review your wiring, since the problem occurred after those change , It might also be just coincidence. When you are playing something(music) go around and listen carefully to each of the speakers, check for muffled or distorted sound, that could indicate a speaker or wiring problem. Of course the problem could also be in the receiver. The protection circuit in your amplifier could be acting up(too sensitive), in that case you might need the help from a local repair tech.
Hope this will help Good luck
Dec 29, 2008 | Yamaha HTR-5240 Receiver
Yamaha HTR-5240 Receiver channels are mixed up
Sounds like your input switching IC is bad. THis is a shop job,major solder work and most likely a parts order. All the inputs tie into 1 intergrated circuit"ic" and the microprocessor see the signals and switches the output on this IC when you change inputs and when this IC goes bad you can have an outward symptom of not switching,only 1 input works or 2 or more inputs on at the same time. If this receiver cost several hundred dollars it's worth repair if less expensive unit you may want to look around for a new unit
Mar 07, 2008 | Yamaha HTR-5240 Receiver
Yamaha HTR-5240 no sound from main speakers
check and see if there is a a/b,a+b setting for speakers make sure its set to a
Jan 06, 2008 | Yamaha HTR-5240 Receiver
Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Is Yamaha HTR-640 a receiver? Try HDMI from PS3 to receiver or Sony HDTV. If HDMI from PS3 to receiver the you need and HDMI from receiver to out Sony HDTV. You could connect everything to receiver and HDMI out to HDTV. You can not have an HDMI cable AND an optical cable coming out of the PS3, only one or the other.
Dec 30, 2007 | Yamaha HTR-6130 Receiver
Yamaha htr-5240 dolby digital problem
Is there switch from dolby pro logic/ surround / or analog/ digital?
Sep 27, 2007 | Yamaha HTR-5240 Receiver
Yamaha HTR-5240 Receiver Logo
181 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
