Question about Akai PT5598HD 55" Rear Projection HDTV-Ready Television
Interlaced comes in fuzzy & with lines
This just started a couple of months ago. It could be my HD receiver from Direct TV but I don't know. If I choose 480i, 720i, or 1080i my screen is fuzzy and I have lines. With 480i it is diagonal lines and with 720 or 1080i it is horizontal lines. 480p comes in much better but still real slight horizontal lines
You need to check if the dvd or games are doing the same thing on different inputs. if they have the same problems you might be looking at the single board or the focus block.
Posted on Dec 14, 2007
SOURCE:
Left front speaker channel not working
Check that the green plug is properly inserted or it is not bent
Dec 09, 2014 | Pioneer VSX-D307 Receiver
New 60ph6700 hd 3d tv /watchind hd sports fuzzy grass and background/once in awhile lines run through screen/its only two wks old??
Anything new has a chance of failure the first month or so from cold solder joints on circuit boards. If it passes the first month it may last 8 or 12 years. Send it back under warranty.
Nov 29, 2013 | LG 60" 6700 Series Plasma HDTV - 60PH6700
New vizio 26'' hdtv seems sharp from a distance, but pixalated and
it is important to understand the difference in digital cable and high def. high definision is on a fiber optic display alwing milions of pixels per square inch on your tv. the resolution effects your fuzzy picture you are recieving . the only real way to fix that fuzzy dull picture is to get a HD box from your cable provider and an HDMI cable to conect it to your HD TV. this is the only connection you will need for picture and top line sound. In the end the fee is usually $9.95 or less a month and it is well worth the difference in quality of TV viewing.
Mar 16, 2009 | Vizio VA26L 26 in. LCD HDTV
White line across screen when using HDMI jacks , and HD comp jack. Attempting to use Direct TV HDMI , but when we plug box into HDMI jacks and HD comp jacks, a dotted white line appears. But when we plug...
first plugging another hdmi device in to your tv.
the hdmi ports on those direct tv receivers have been known to go bad. i've had this happen on three of my receivers from them and have been told that they came out with a new receiver for just this reason.
hope this helps.
please rate well.
If you need further help, reach me via phone at https://www.6ya.com/expert/mark_445a24324be9eb03
Mar 02, 2009 | LG 37 in. Flat Panel LCD HDTV
Fuzzy screen with alot of green lines
if the problem corrected itself, good. however, was it particularly cold? Plama sometimes need a lil time to warm up, if it does it again i would return it or start the warantee proccess, as i could be a sign of things to come.
Dec 13, 2008 | BenQ PDP-46W1 46 in. HD-Ready Plasma...
N2750W PROBLEMS WITH DIRECT TV
just press the "PIP" button on the remote it happened to me and i just thought that it looked familiar and i pressed it and it worked hope it helps :)
Nov 19, 2008 | ViewSonic N2750w 27 in. HD-Ready LCD...
Ringing noise coming from my philips 30PW9110D/37
This noise is coming from the power supply.
You may want to look for a local repair shop from this website to get service if desired.
If the power supply were to be replaced, it could be done by you if you are somewhat savvy.
Mar 31, 2008 | Televison & Video
My yamaha htr 6050
Make sure you speakers are turned on on the receiver,
Jan 23, 2008 | Yamaha HTR-6030 Receiver
Akai PT5598HD 55" Rear Projection HDTV-Ready Television Logo
108 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
