Question about Bosch 24 in. SHU66C05 Stainless Steel Built-in Dishwasher
Diswasher airlock there is water coming out from the dishwasher airlock
  • 1 more comment
  • Anonymous Apr 12, 2008
    SHV68MO3UC
    Water leaks on to floor. Had repair people 3 times . They cannot fix. Any suggestion?
  • Anonymous Mar 19, 2014
    No water coming in the dishwasher look like it working but there is no water
    nO wATER COMING IN THE DISHWASHER
    Problem Solver:
  • 6 Answers
By the airlock , you mean the air gap? .If the water is coming out of you air gap that means the hose that connects the air gap to your drain is clogged or your drain itself is clogged.Check the hose that connect the air gap to your drain(or disposer), check air gap and clogged disposer opening
Posted on Aug 15, 2008
SOURCE:
Diswasher water isn't draining?
It is most likely the drain pump. If the drain pump passes a tech's test ok, have the drain passage checked for clogs.
Apr 17, 2012 | Dishwashers
Hotpoint Aquarius FDW60 won't take in water. Suspected airlock after house move?!?
Try checking the inlet solinoid , should be 1 for hot & cold, sometimes the solinoid will freeze up due to alkaline buildup .try soaking it in CRL , alkaline deposit desolving liquid .
Mar 13, 2012 | Hotpoint 24 in. FDW60 Free-standing...
I have Frigidaire FDB956RBC1 diswasher. I have to turn off the water to fix the faucet. When I turned the water back on, water did not go to the diswasher when I used it. The diswasher runs normal except...
FRIDG... EXPERT HERE
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
Jan 19, 2011 | Frigidaire FDB956RB Built-in Dishwasher
My diswasher only washes at the top of diswasher.would we have pressed a button for this to happeren or is there another reason many thanks
Try cleaning the water jet openings on the propellar inside of the dishwasher. These small openings get clogged with food
Jun 16, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
My Zanussi ZDF231 dishwasher does not rinse properly and I always have to run it twice to clear the silt from the top tray items
Check inside the diswasher to make sure that the bottom screen is clear of any debris. If clear on the last rinse cycle add a pot of hot water to the dishwasher and observe to see if your dishes come out cleaner.
If the come out cleaner you are probably not getting enough water into your dishwasher.
Replace your water inlet valve.
Dec 29, 2009 | Dishwashers
Maytag diswasher won't spray water
water level/float switch is stuck. (dishwasher is getting a indication the unit has enough water in it to operate)...repair/replace float switch, located in front right corner under bottom rack.
clarkco
Feb 28, 2009 | Maytag 24 in. MDB9750AW Dishwasher
No water comes in to wash dishes.
sorry to sound obvious, but you will have pull the dishwasher out to get to it, just follow the hose into the inlet valve unit, they are located under the unit at the back.
Jan 27, 2009 | Maytag 24 in. MDB9150A Built-in Dishwasher
NO WATER COMING THROUGH ON DISHWASHER JUST LOUD BUZZING NOISE
The buzz that you hear is the water line solenoid. It probably is not opening up to let the water through. You should replace this solenoid and it will fix your problem as long as you have water coming up to the diswasher's solenoid valve.
Dec 03, 2008 | Smeg 18 in. DWF409WH Slim-Line...
Water still running with buttons off and door open
indicates that the water solenoid diaphragm has failed and not shutting of the water supply
get a new one from the service agent or have a technician come , diagnose and replace the faulty item
Sep 08, 2017 | Dishwashers
Bosch 24 in. SHU66C05 Stainless Steel Built-in Dishwasher Logo
788 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
