Question about Kenwood KDC-MP435U CD Player
My Cd and iPod doesn't have sound
The radio works fine, but when I turn it to the iPod selection it shows that the iPod is connected and playing but there's no sound. It even shows the song name! Same with the cd, it shows how it's going through the song (minute and seconds w/ track) but no sound!
Please help!!! I really appreciate it
  • 1 more comment
  • Anonymous Dec 08, 2007
    I've got the same problem with the USB and CD devices. I think I might have to rewire the power ant. to not be controlled by the stereo or the factory stereo came with an extra ground wire, I can try to hook the up and see if that helps. Please, if anyone has something else I could try, POST IT.
  • Anonymous Mar 16, 2008
    ?nbvdvanvcvsmvcv
  • Anonymous Mar 29, 2014
    it worked now it does not. The radio has sound however no sound for Ipod. it is telling me it is playing a song but no sound. regards heath
Wow dude... that was completely the fix on my jeep... Thanks... Def. ANT wire!
Posted on Jan 08, 2008
Alright I fixed it. My stock Jeep stereo had a speaker amp that was wired in with the power ANT, the kenwood would turn the power ANT off when using other medias. So I had to hook up the BLUE power ANT wire up to the RED IGN wire so that when the car was on both the ANT and AMP would be on when the car was on. There are other ways of hooking this up I could have hooked the ANT wire up to the AMP wire coming out of the Kenwood so that the AMP and ANT would've only been on when the radio was on, but I'm happy with the way this turned out.
Posted on Dec 08, 2007
SOURCE:
Audio doesn't work
Send it back if possible ,you've bought a faulty stereo.
Jan 20, 2018 | Sony MEX-BT2500 CD Player
I have a ten year old bose wave/radio/cd player. Sound is great but want to play music from my ipod through the bose. my ipod plays in car using aux cable but this does not have same result when...
Anything that has a headphone output can be adapted to feed an RCA cable pair for standard stereo to any audio device with a standard RCA input (except PHONO). Get a cable like the one described here: http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021804&p_id=665&seq=1&format=2
and connect it into any available analog input EXCEPT "Phono".
Jun 17, 2011 | Bose Wave Radio
Just purchased a cda105, the radio works fine and sounds great. Although when using the cd player or my iPhone it produces no sound. The display shows that the iPod and cd player is working correctly, the...
the problem is that you are not turning on the amplifiers,
pull the radio out there are 2 blue wires, you are using the wrong one
just switch them and the cd and ipod will work
good luck
Sep 13, 2010 | Alpine CDA-105Ri CD Players
Alpine cda 9884 has no sound in cd or ipod mode
actually, chrysler/dodge has factory Infinity sound systems installed. The nice part about these systems is that you dont have to bypass the amplifiers in order to put a new radio in, but simply power up the amp by hooking up the amp turn on wire at the harness. The alpine should have 2 blue wires coming off of the back, one that is solid, the other with a white stripe. The one that is solid only has 12v when the fm/am radio is on (used for power antenna) but cuts off when other sources are used (cd,aux,ipod). My guesses are, you have the amp wire on the vehicle harness (blue) tied into this wire, instead of the BLUE/WHITE wire on the alpine which has 12v as long as the radio is on. i hope this solves your problem, 9 times out of 10 on a chrysler this is it.
Auto Tech
DA2 (Supa)
Jun 07, 2009 | Alpine CDA-9884 Car CD/ MP3 Player
Pioneer AVH-P4100 Ipod Video not playing
You have to set up the AUX output.
1. Touch the source icon and then touch "OFF" to turn the unit off.
(The unit will be in demo mode)
2. Touch the screen to display the touch panel keys.
3. Touch AV Menu you should see "Inital Menu" and touch it.
4. Touch AUX 1 on the inital menu to select desired setting.
5. Touch it until Ipod is selected (make sure you have the CD-IU200V connected.
6. Touch ESC. Ipod video should work now.
7. See Page 50 in Operation Manual for more information.
May 08, 2009 | Car Audio & Video
Alpine IDA-X300 not playing mp3
try recording a cd as a wma instead of mp3 format. i had this problem before and that worked for me
Jan 11, 2009 | Car Audio & Video
Eclipse CD2000 has no sound from a cd or sirius... radio works
If you have an amplifier hooked up make sure that the correct blue wire on the harness is connected. One of the wires is the remote amp turn-on, the other is for a power antenna. That would be why your radio plays through your speakers, the power antenna wire' when the source is set to radio, sends a 12 volt signal. That would turn on your amp if thats the way that its hooked up.
Nov 16, 2008 | Eclipse CD2000 CD Player
Alpine 9885 - no sound with cd's or ipod
have you fixed it yet? if not try this. your car probably has factory amplified speakers. hook up the remote wire AND the power antenna wire to the blue factory amp wire and it should work just fine
Mar 08, 2008 | Alpine CDA-9885 CD Player
Radio has sound but not the CD player or iPod
Your amp is not turning on - what you should do is connect the "blue/white - remote turn-on lead" to whatever wire you have the "blue - power antenna" output from the Alpine connected to now. That should solve your problem.
Mar 07, 2008 | Alpine CDA-9883 CD Player
Radio sound but NO cd or ipod sound
Radio is screwed.
But try these these steps:
Clean the eye of the head for reading CD. Must open up the radio.
IPod: check for good connections from Ipod to PCB.
Feb 23, 2008 | Alpine CDA-9856 CD Player
Kenwood KDC-MP435U CD Player Logo
299 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
