Question about Kenmore 24902 Top Load Washer
Kenmore 80 series top loader the washer will not fill with cold water only hot water
The washer will only fill with hot water. If you put the water setting on cold cold or warm cold it does nothing. I can see the cold water is filling the hose coming from the valve, it is like the water is blocked from entering the machine does anyone have a solution to this problem. Please let me know it is very frustraighting. Thanks Patrick
  • 2 more comments
  • Anonymous Jul 29, 2008
    Same thing - no cold water into the washer. Wondered why it took so long to cycle through, then my clothes started shrinking which made me think the dryer was too hot (it wasn't). Then, I thought to open the lid while the washer was filling and I saw two little trickles coming out of the cold water hose. I thought. If it isn't coming out here, where is it coming out? Needs repair, but I'll try taking off the hose and seeing if it is blocked with debris. Dang, where is a man when you need one?
  • tiredmom101 Aug 31, 2008
    The washer will only "trickle" cold water when I've got it on cold wash. Warm wash is straight HOT water. I've removed hose & it was clear (even bought a new one just in case) & still having the same problem. I've found my repair parts list...could it a "valve, water mixing hose, inlet"? If so how do I get at it?
  • Anonymous Mar 17, 2014
    m crosley top loader washer will not fill with water
  • Times Scott Behnke
    Times Scott Behnke Apr 19, 2014
    I replaced my valve and still the same problem.
  • 447 Answers
Yes patrick you can try removing the cold hose from the washer, look inside the valve for a metal screen. If it has sediment blocking it remove screen, clean it and reinstall. If still no water replace inlet valve.
Posted on Dec 02, 2007
    I replaced my valva and still no cold water ?
Where is the reset button for a kenmore 80 washer wont stop filling water level
If this is a top loader then the vacuum line has come off of the dashpot or the water level switch is broken. UNPLUG the power-Standing in front of the washer, pry off the plastic trim strips on the left and right of the dash (control panel) Now you'll see a screw at the bottom where the strips mounted, remove ans KEEP the screws, now the dash will lift up and fold back, giving access to the parts.
Aug 17, 2014 | Kenmore series 80 Washer Motor 3363737-
I have a Kenmore washer model 110.98762792 and im having a problem with the cold water. When the water temperature switch is set to the cold/cold position the washer does not fill with cold water. W
Since U get warm water that tells you that the cold and hot water solenoids are both operating. Ergo the anomaly has to be with the device that controls temperature.
Apr 10, 2017 | Kenmore Washing Machines
I believe the water temp switch is bad. It will start filling on warm then stop if I put it on hot it will fill with cold water. I have cut the hot water off to achieve this but when it reaches rinse it...
it sounds to me that the hoses are connected to the machine incorrectly. Typically if the plumber ran the water lines behind washer correctly the hot pipe is on the left and the cold pipe is on the right sometimes thats backward and be determined by touching hoses while filling on warm setting and see which hose feels hot. On the back of washer they where they connect hot goes on the bottom and cold on top
Aug 08, 2011 | Estate ETW4400VQ Top Load Washer
My Kenmore front loader sometimes fills with warm water on cold setting.
Most washer today use automatic temp. control fill valves. If water is too cold the control might mix in some hot to bring up to a preset temp. The same is true when control set for hot. For energy savings cold water will be mixed in to maintain a semi hot temp. Check with manufacture just to be sure.
Feb 03, 2010 | Kenmore 3.5 cu. ft. King Size Capacity Top...
My new estate washer with 4 water selections actually only has 2, hot and cold. The warm water setting fills with lukewarm water for a while then shoots in cold water for a while and back and forth. In the...
Yes, this is normal. All newer washer have auto temp control fills. This is to meet energy saving requirements. The less hot water used the more energy saved. Most hot settings on washers give out basically lukewarm water. The detergent made today is made to work well with cooler temperature water, so things will still come out clean.
Feb 01, 2010 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Maytag Performa wont fill hot water
The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can test a fill valve live for 120 volts, power to a fill valve coil and no fill = a bad fill valve. You can also test the coils for continuity, no continuity = a bad fill valve. Some Maytag washers have a fuse in the fill valve circuit, if this fuse let go the washer will not fill. Fill valves can also from time to time stick open and not stop filling. If you have to shut off the fill valves to stop the water from filling in the washer, you have a bad fill valve and you will have to replace it.
Nov 27, 2009 | Maytag Performa PAV2200
Washing Machine Rinse and Spin lights are on
its the problem of drum getting blocked by any clothes getting tucked up.also try to move the drum manually with the machine off.if it makes any noise its the faulty motor.or drum has lost its alignment.it needs to be reseated properly in that case. -------------- The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
Jul 23, 2009 | Tricity Bendix AW1400W Front Load Washer
My kemore 80 series washer will not fill up
Check to see if there's good water volume coming through the hoses attached to the washing machine. If there is, check to see if the screens inside the water-inlet valve are clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If they're clean, you probably have a defective water-inlet valve. If so, you should completely replace the valve.
The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
May 03, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 24902 Top Load Washer Logo
335 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
