Question about Fahrenheat Electric Convector Baseboard Heater, 240 Volt
How to wire 2 plh 1504
How do I wire two plh 1504 units that are 25' apart?
  • 1 more comment
  • jpeters220 Dec 02, 2007
    One thermostat.
    It is PLF 1504. They are 240 volts, 1500 watts.
    Thanks
  • jpeters220 Dec 03, 2007
    Thanks alot for all your help.
  • 625 Answers
Are they to be controlled off one thermostat or seperate?
Posted on Dec 02, 2007
  • THOMAS MIERZWA
    THOMAS MIERZWA Dec 02, 2007
    I did a search and your numbers are not correct - stock numbers I found begin with an "F" - I need to know the number of watts these units consume. are they 240 volt?
  • THOMAS MIERZWA
    THOMAS MIERZWA Dec 03, 2007
    I drew up a diagram for your heaters. Use 12 gauge wire from the panelbox to your wall case for the thermostat. Run another 12 ga to your basement to a junction box. From the junction box run a 12 ga to each of your heaters. In the diagram the white wire is shown in light blue as I cannot draw white on a white background. the thermostat may look different, may even have different colored wires. but in any case it is a double pole switch. [stat] Install a two pole 20 amp breaker. each heater draws 6.25 amps but I say run 12 gauge because of wire [cable] length.
SOURCE:
Trouble shoot
I believe that's a Speed Sensor issue.
Diag:
1. Ensure mainshaft and countershaft speed sensors are installed properly. Disconnect mainshaft speed sensor harness connector. Using a DVOM, measure resistance between sensor terminals.
2. If resistance is not 400-600 ohms, replace mainshaft speed sensor. If resistance is 400-600 ohms, disconnect 25-pin PCM harness connector "B". Check for continuity between ground and 25-pin PCM harness connector "B", terminals No. 15 (Red wire) and No. 14 (White wire).
3. If continuity is present, repair short to ground in Red or White wire between PCM and mainshaft speed sensor. If continuity is not present, reconnect mainshaft speed sensor harness connector. Measure resistance between 25-pin PCM harness connector "B", terminals No. 15 (Red wire) and No. 14 (White wire).
4. If resistance is not 400-600 ohms, go to next step. If resistance is 400-600 ohms, go to DTC
P0720 (FLASH CODE 9) . Check for loose PCM harness connectors. Replace PCM with a
known-good unit if necessary.
5. Disconnect mainshaft speed sensor harness connector. Check Red wire for continuity between 25-pin PCM harness connector "B", terminal No. 15 and mainshaft speed sensor harness connector. If continuity is present, go to next step. If continuity is not present, repair open in Red wire between 25-pin PCM harness connector and mainshaft speed sensor
harness connector.
6. Check White wire for continuity between 25-pin PCM harness connector "B", terminal No. 14 and mainshaft speed sensor harness connector. If continuity is present, check for loose PCM harness connectors. Replace PCM with a known-good unit if necessary. If continuity is not present, repair open in White wire between 25-pin PCM harness connector and mainshaft speed sensor harness connector.
Mar 21, 2014 | 1998 Acura Integra
Car
Speed Sensor probably. Try:
harness connector.
Mar 21, 2014 | 1998 Acura Integra Type R
I need operating instructions for the VTECH CS6328-4
You can download the manual from the manufacturer's web site at
http://vt.vtp-media.com/ecp/documents/product_Product/1504/UserManual/5261/cs6328-4_manual_i6.pdf
Aug 02, 2011 | Vtech CS63283 Cordless Phone
I have the same problem with Panasonic NN-8501V Microwave Oven
I took the touch pad control unit apart, clean the connector for the ribbon wire connection between the key pad and the control unit, reseated the ribbon wire in the connection. Everything worked like new.
Oct 16, 2009 | Panasonic Microwave Ovens
Installing hebrew to mini iphone KA08
Open phone directory screen choose settings, then initial setup then language if hebrew is available it would be on that screen.
Jul 03, 2009 | Cell Phones
P8 eroor code
P8 error is abnormal pipe temperature indoor. If you are running it on heating P8 error will appear because the disc pressure is too high. It could be overcharged.
May 31, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
How do I install the replacement igniter in my Ducane grill?
you remove the nut in the back of the old igniter and the single wire that plugs into the end.  Then you pull the unit out.
Next, you insert the new igniter and replace the nut and tighten then reinstall the one wire into the end.
When you receive advice from this website you have to understand that without the item in front of us, we are only able to provide "a best guess" as to what the problem might be based on you description of the defect.  If you haven't described a clear and precise description of the defect you decrease the chances of an accurate reply.  Thank you.
May 02, 2009 | Ducane Standard 1504 (LP) Grill
Asko Excellence Dishwasher Model # 1504
I have a manual for 1504 and it says F2 blinking means high water level in machine
Apr 15, 2008 | Asko W6021 Front Load Washer
Brother MFC-240C Change Unable 50
I also had this problem, your solution was spot-on, remove the top cover and control panel and re-seat the encoded strip. simple.
boy, are you guys good.
Dec 11, 2007 | Brother Multi-Function Center MFC-240C...
Fahrenheat Electric Convector Baseboard Heater, 240 Volt Logo
2,082 people viewed this question
Top Fahrenheat Heating & Cooling Experts
Paul Carew
Thomas F. Schneider
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
