Question about GE 31GT660 TV
Vertical size adjustment on my GE 31GT660 set
The vertical size of the image on my 31GT660 is off the bottom of the screen. I can't see scrolling bulletins that come in from news services.
I had the same problem. I found the solution in this link.
The only thing that wasn't clear was how to get into the service menu. With the TV on, press and hold the MENU button on the front panel of the TV and press POWER then press VOL+.
Posted on Jun 07, 2008
E472VL picture on HD cable channels does not fit screen correctly-how can we fix it?
Consult the manual---the answer lies in the size controls being grayed out so you cannot adjust or try to adjust the vertical size!
Mar 28, 2012 | Televison & Video
I have a Samsung NC10 notebook hooked up to an Acer x193w monitor and up until today it has been working perfectly. Now the display will not fill the monitor's space. Horizontal is fine but vertically the...
Do you have a spare computer to hook up to the monitor to see if the monitor's settings are off vertically?
Can you adjust the vertical size of the image of the monitor?
Are the letters squashed down vertically?
If the letters are squashed down vertically, did the setting for pixel size of the screen get adjusted to another size accidentally in the control panel under display settings?
Can you reset the Acer monitor from the menu?
Jul 29, 2010 | Acer X193W LCD Monitor
The view on my monitor is very truncated - about two inches top and bottom are not filled
Press the MENU button on the monitor and adjust the width and height of the picture to full screen.
Oct 10, 2009 | LG Computers & Internet
Sony lcd projection tv vertical adjustment KF-50E200A
Try changing the settings for the video formats, widescreen, regular, and all that. There are angle mirrors in the back of the tv that direct the projected image on the screen. The mirrors are positioned such that if, says, a piece of a metal bracket or something falls down inside the projection area, it'll fall right against the projection lens and block the image. Open up the back of the tv and follow the light path from the screen backwards to its source and make sure there's no debris in the projection path.
Sep 17, 2009 | Sony KF50E200 TV
Control of vertical TV image projected on the screen
You can try looking for 2 things
1. A button on your remote that says either: ARC, Ratio, 16:9, 4:3.... Some remotes have a picture of a square with arrows pointing out towards each corner..... I'm unfamiliar with this set, but it sounds like a widescreen, so give it a go
Apr 22, 2009 | Televison & Video
I cant read the scroll on the bottom of the screen
You don't give a model number or age of the set so I can't be too specific, but there is an adjustment for picture size (it's actually termed "vertical height") in TV sets. Many newer sets make adjustments through a service menu using the remote control, but many sets have a physical adjustment control inside. I can't tell you how it is in your set, but you can take the back off and look at the circuit board. If you see a small round adjustment control (screwdriver slot for turning) marked "vertical size," "height," "vh" or something similar, that's the one. A little turn one way or the other will do the trick.
Now having said all that, it's also possible there may be bad capacitors in the set's vertical circuit. Is this a problem that just started, or that's gotten worse over time? Do you notice distortion at the top of the picture, like a person's head or other round object looking stretched out if it's at the top of the screen? If so, that's usually a sign of capacitor failure. There are a few in the vertical circuit, usually in the range of 1 to 10 mfd at 50 volts, and they commonly go bad with age. Without knowing what model TV you have I can't suggest specific part numbers.
Hope this helps or gives you a start.
Nov 19, 2008 | Televison & Video
Are there internal picture controls for the WS-55315?
Good Day; OPTION MENU "MENU 0370" SERVICE MENU. CAUTION document settings before any adjustments are made. V = vertical, H = Horizontal. Good Luck, big IRISH.
May 11, 2008 | Mitsubishi WS-55315 55" Rear Projection...
Bottom of picture is cut off
Usually when the vertical starts shrinking slowly, it is due to capicators getting out of tolerance in the vertical output section of the chassis. If it can be adjusted out through a service menu, you'll probably need a tech with the right equipment to perform it.
Jan 01, 2007 | RCA F27440 27" TV
Image adjustment for GE 24GP65
Yes you can adjust the vertical size in the service menu, but you must be carefull when doing any horizonal adjustment as this can shut down your set .
Dec 16, 2006 | GE 24GP653 24" TV
Your problem is not a vertical alighnment or size adjustment. No, Im sorry to say its the old vertical output IC and /or the small capacitors around the ic and in the vertical circuit. If you dont have the right tools, like a soldering iron a multimeter know how to read a schematic diagram, then you should seek out a repair person to assist you in this repair.
Sep 12, 2006 | SansuiS2001 20" TV
GE 31GT660 TV Logo
105 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
