Question about Hotpoint Ultima WF860 Front Load Washer
Dispenser shots out water
When doing a wash around 32 and 16 mins left of a wash, the dispenser drawer fills up with water which then is forced out of the front of the drawer. The quantity of water is quite large as well.
  • chubster808 Dec 02, 2007
    thanks, the drawer does come out, it looked pretty clean, i manages to stick a toothbrush down the drainage hole not much room to maneuver. I did a wash and water still came out but not so much. As you said it must be clogging, but I could not get the toothbrush all the way down, unless I take the machine apart. its a shame because the repair man is going to charge £100 to unblock it
    President:
  • 1,294 Answers
If possible pull out your drawer and clean it up. Reason due to clogging with detergent, etc. Refer to your manual. If you can't get the drawer out, use a tooth brush to scrub; see that brush does not fall in. The dirt can fall in. To test if clear pour water into drawer.
And rate me pl......
Posted on Dec 02, 2007
  • prem mathew Dec 03, 2007
    You can take the top of the machine off. Plug off the wall first. Use a nice grip-clip to loosen the hose from the dispenser. Examine this hose for any blockage.
Water leaking from detergent drawer
The first thing to do is take note of what the washer is doing when water leaks out in order to help pinpoint the cause. Does it only leak when filling? Is it leaking during wash or rinses? Or is it leaking only when it goes into spin?
Only leaks when filling
  • Water pressure that's too strong. Some dispensers can't cope with high water pressure. Make sure the washer is level as one leaning forward can leak if combined with high water pressure. Try turning the tap on the washer down. Only suspect this if you know the water pressure is high and it looks like it's gushing in quite fast on fill
  • If there is an optional detergent flap fitted in the drawer for holding liquid detergent make sure it is removed or drawn into the up position if using powder otherwise it prevents detergent running down into the drum
  • A build up of grease and slime in the nozzles at the top of the dispenser where the water flows in causing water to spray at the front and run out when filling. Check this article -black jelly-like substance in soap dispenser and on soap drawer (In extreme cases I've had to replace the dispenser.)
  • A build up of undissolved detergent in the base of the soap dispenser under the drawer (depending on the design). Remove the soap drawer and check the bottom of the soap dispenser for a build up of detergent that could allow water to run over the lip of the dispenser
  • Blocked dispenser hose: Some washing machines can flood water out of the soap dispenser if the hose leading out of the dispenser into the tub gets blocked. Blockages can be something put into the drawer by a child or a chunk of undissolved detergent tablet. Indesit, and Candy, as well as some of the later Hoover washing machines suffered from this design flaw. The hose where the water is flushed down, was right at the front of the soap dispenser on these washing machines and it wasn't wide enough. Undissolved powder from a tablet or lumps of detergent through poor water pressure can block this hose solid causing water to back up. Unplug machine, remove lid and feel this hose carefully for obstructions.
  • Overfilling: If the washer starts to fill and never stops it will flood out of the drawer eventually - Washing machine overfills
Leaks out of drawer during the wash or rinse cycle
  • Too many suds? If you can see the door glass is white with foam up to the top it could be foaming out of the dispenser. Too much foam in the washing machine
  • Overfilling: If the washer starts washing but the water doesn't stop coming in it will eventually fill the drum so much it will start to pour out of the soap drawer and other places. If this is the fault you should be able to see the drum is so full of water it's making a different sound, maybe labouring under the load, and the door glass full to the top with water. You should also hear that water is still running into the machine and be able to detect it by opening the drawer. However, in most cases an over filling washing machine should trigger an error code long before it gets to this stage but if you suspect overfilling check this page - Washing machine overfills
  • Surging: There are (often intermittent) faults that can cause the motor to spin out of control on wash or rinses. Instead of turning slowly the fault causes the motor to surge into spin instead which throws the laundry and all the water about violently. Water can then be forced out of the soap dispenser drawer. This fault should be relatively rare these days but if you observe this behaviour call an engineer to diagnose the cause.
Leaks from drawer only when spinning
  • If it only comes out on spin it can be caused by a partial blockage preventing the water being pumped out fast enough resulting in excess water being thrown around on spin and backing up into the dispenser. This fault is similar to the surging fault described in the last list but different in that the problem only occurs when it's on a proper spin cycle and much of the water has been pumped away. Troubleshooting this fault is all about finding out why it isn't emptying the water properly which is usually due to a partial blockage. Follow the same troubleshooting as described for a washer not pumping any water out at all - Washing machine won't empty water
  • If water is being forced out of the drawer when the washer is spinning but it is on wash or rinse and shouldn't be spinning follow the procedure for surging in the previous section above
Dec 23, 2016 | Washing Machines
Tip
Is Washer Leaking From Soap Dispenser Drawer? Try this first!
There are a lot of times that some problems can be fixed very easily by the owner themselves and at no cost at all. This is one of them.
Some people experience that the soap drawer leaks from the front of the soap drawer dispenser on certain cycles, this can be caused by a couple of things but could just be a very simple fix which you should try first before calling a engineer.
MACHINE LEANING SLIGHTLY FORWARD: This is the main tip and FIRST CHECK anyone should do before going on to the next tips. If a machine is not level and leaning forward the water that is in the drawer while filling will be forced forward and can easily get past the drawer and leak down the front of the machine especially if the dispenser housing is slightly warped. If this is your experience then first thing to do is to check the machine is level. Adjust the front feet on the machine to raise the front making it level or slightly leaning back. This will cause the water to be forced to the back of the soap drawer dispenser allowing it to go in to the machine and not out the front of the drawer. Make this the first thing you do as it can be as simple as that.
If this has not solved your problem then check for:
EXCESSIVE WATER PRESSURE: Some people have very good water pressure in their areas (normally cold supply), if this is the case and you have a cut off valve in your system at the filling pipes (red&blue pipes, sometimes red&grey) then you just need to figure out which water is being pumped in at that time and then turn that valve off slightly (NOT ALL THE WAY!) only slightly and this will slow the amount of water entering the machine. This will cause the machine to take a bit longer to fill so the wash will take slightly longer to complete. So please bear this in mind if you have adjusted the water pressure! It won't be a new fault!
on Feb 26, 2010 | Washing Machines
Dispenser fabric softener slot
Fabric Softener Compartment Full Of Water - White Goods ...
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jul 9, 2013 - The small fabric conditioner compartment in the soap dispenser drawer has a plastic cap or tube at the back for the water to siphon up through. ... Make sure the washer is level front to back as well as side to side. .... If the washing machinehasn't been used since there's always the possibility that the plastic ...
The fabric softener part of my washing machine drawer keeps ...
www.mumsnet.com > Topics > Housekeeping
MumsnetAfter each wash, the fabric conditioner part of the drawer is f. ... The fabric softener part of my washing machine drawer keeps filling with water ... Stopped using thedispenser compartment for fab softener and instead did I separate ... see if that clears it up and also try cleaning behind the drawer in case there is a blockage.
Washing Machine ' Fabric Softener ' Problem ' Won't Empty
Jan 16, 2016 | Washing Machines
WATER LEAKING from Soap / Softener dispenser
Close the water faucet slightly to reduce the speed of the flow into the the soap drawer...The machine will fill a little slower, so what??!
Oct 25, 2017 | Maytag MAH8700A Front Load Washer
Sirs: The Softener Dispenser on my Bosch Axxis washing machine is filled up with water. What to do? It won't dispense softener.
Take out the drawer and clean the compartment and pipe at the end of the drawer with hot soapy water - washing up liquid works well. Clean all around it. Use a pipe cleaner, cotton buds or piece of coiled curtain wire to ensure that the U shaped pipe is clear of obstruction. Pull it back and forward to dislodge any accumulated fabric conditioner. To show this is working OK, put it in the sink and fill up the compartment with water until it is overflowing then stop. The water should drain out of the compartment on its own.
Next, where the drawer fits in the machine clean the water exit above the drawer with a washing up brush. This can appear brown or white depending on your water type. If this is OK then try running the machine. If there is still a problem, remove the drawer again and turn off the power at the mains. Use something like a paper clip to poke all the holes in the water dispenser area above the drawer. There are lots of them so some patience might be required. If you live in a hard water area it could be blocked with limescale in which case an application of a descaling mousse or spray will assist. Once complete, make sure you rinse the drawer area, drawer and put the drawer back in and run the machine on a short cold fill wash cycle. Put some fab con in the drawer to test that the machine drains it correctly. A good idea is to slightly water down fab con concentrate as it will eventually clog up the dispenser. If all is well then there will be no fab con left. If it is still there then you will need to get into the water dispensing area to see what is wrong. Occasionally the mechanism can get jammed, lose a spring or just get broken, in which case it will need replacing.
Nov 13, 2009 | Bosch Axxis WFL 2060 Front Load Washer
When wash is done, the fabric softner tray is left with water. Why?
Nov 06, 2009 | Bosch Washing Machines
Help with drawer for fabric softener
Nov 04, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Fabric softener doesn't leave the dispenser
Take out the drawer and clean the compartment and pipe at the end of the drawer with hot soapy water - washing up liquid works well. Clean all around it. To show this is working OK, put it in the sink and fill up the compartment with water until it is overflowing then stop. The water should drain out of the compartment on its own.
Next, where the drawer fits in the machine clean the water exit above the drawer with a washing up brush. This can appear brown or white depending on your water type. If this is OK try running the machine. If there is still a problem, remove the drawer again and turn off the power at the mains. Use something like a paper clip to poke all the holes in the water dispenser area above the drawer. There are lots of them so some patience might be required. If you live in a hard water area it could be blocked with limescale in which case an application of a descaling mousse or spraty will assist. Once complete, make sure you rinse the drawer area, drawer and put the drawer back in and run the machine on a short cold fill wash cycle. Put some fab con in the drawer to test that the machine drains it correctly. If all is well then there will be no fab con left. If it is still there then you will need to get into the water dispensing area to see what is wrong. Occasionally the mechanism can get jammed, lose a spring or just get broken, in which case it will need replacing.
Oct 21, 2009 | Bosch Axxis WFL 2060 Front Load Washer
The softener dispenser doesn't completely dispense. There is wqater still in it when the load is finished.
Sep 20, 2009 | Bosch Washing Machines
The softener holder just fills with water but will not drain.
Is water left in the dispenser at the end of the cycle?
About two tablespoons of water remaining in the dispenser compartment at the end of the cycle is normal. At the end of the wash cycle, fresh water automatically cleans the dispenser. Check that the cycle is complete before opening the dispenser drawer.
Is the dispenser drawer clogged?
A clogged dispenser can block the flow of water through the dispenser and cause water to leak out. Manually remove the dispenser, and clean any leftover detergent or additives that could clog the flow of water through the dispenser. Also, check that the detergent drawer is always completely closed during the cycle. If the drawer is not closed completely, water can leak out onto the floor.
Are the additives dispensing too early?
Here are a few things that can cause the additives (detergent, fabric softener or liquid chlorine bleach) to dispense early:
  • Check that the dispenser is not overfilled. Do not fill past the MAX fill lines on the dispenser. Overfilling can cause early dispensing of liquid chlorine bleach and/or fabric softener.
  • Check that the detergent separator is in the correct position. For liquid detergent, the separator should be in the front position. For powdered detergent, the separator should be in the rear position. If the separator is in the rear position while you are using liquid detergent, it will dispense immediately, which is not how it is designed to work.
  • Use powdered HE detergent when using the DELAY WASH option. Liquid detergent may dispense prior to the start of wash.
Are the additives dispensing too late?
The additives will not dispense until the proper time if the DELAY WASH option is selected.
Dec 17, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
