Question about Vacuums
How do i replace a belt?
I have a Ereka upright Boss, model# 7620. The belt is broke and I want to be sure of how to properly replace it.
    Filmmaker:
    Uploaded 5 video answers.
  • 152 Answers
On the bottom above the beater bar there should be two deep set screws one on the right and the left take them out. =you can use a flat blade screw driver to pop the sides off you should see the gap at the edges the belt if there is one left would be attached to the beater bar replace the belt .should all go back together same way it came apart. hope this helps ya.
Posted on Dec 01, 2007
Eureka Boss Capture 8803AVZ Bagless Upright Vacuum smells like it is burning
First you need to checkl and make sure the roller brush is not jammed up and the belts is not slipping due to the brush not turning
Apr 30, 2011 | Eureka Boss Capture 8803AVZ Bagless...
The belt on my used Eureka Boss 5857 upright slips off the end of the motor shaft every time the vacuum is used. When I turn the brush roll slowly by hand, the belt walks toward the end of the shaft. It...
The brush roller could be worn and in need of replacement. Some Eureka uprights have a wire guide that prevents the belt from slipping off the motor shaft.
Apr 02, 2011 | Eureka 5856BVZ Boss Bagless Upright...
Eureka Boss - Belt is not broke but brush will not turn. I have already turned it over - checked belt - and pushed the reset button.
The belt may look fine but they can still be stretched or worn and it won' turn the brush. Try changing the belt and see what it does. You can get Eureka belts here:
Eureka Replacement Vacuum Belts
Nov 07, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
I have to check the belt in the ereka powerline plus. how do I do that?
Below I have listed a link that will open the owners manual that has step by step instructions on how to change the belt. Also I have listed links for the replacement belt you need. Eureka recommends replacing your belt at least every 12 months.Hope this helps you.
Eureka Powerline LiteSpeed Owner's manual
Eureka Powerline LiteSpeed Replacement Belts
Oct 29, 2009 | Eureka Powerline LiteSpeed 5845 Upright...
Belt broke how do i fix it
To my knowledge model F7220900 SteamVac doesn't require a belt. Are you sure that is your model? If you have a different Hoover model you can get a replacement belt here:
http://www.vacbelts.com/
Oct 20, 2009 | Hoover F7220900 SteamVac V2 Upright Vacuum
Problem getting belt around motor shaft... Eureka The BOSS
make sure the vacuum is in the upright (locked position) - when you lower the handle, this puts tention on the belt. If it is in the upright and locked position, there is plenty of clearance (unless you have the wrong belt.
Apr 07, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Belt broke
The belt number is 60957, There should be some screws that you remove from the bottom and the whole bottom nozzle will come apart, then you can change the belt.
Feb 27, 2008 | Eureka Boss SuperLite Bagless Upright...
Eureka 5849A Boss bagless upright
remove belt to brush roll and see if noise persists. if it stops, you probably need a brush roll. at least doing this will narrow down the fault area
Mar 26, 2007 | Eureka 5849A Boss Bagless Upright Cyclonic...
Vacuums Logo
243 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
