Question about GE DCVH515EFWW Electric Dryer
Dryer lent sign and wont run - GE DCVH515EFWW Electric Dryer
Dryer sheets deposit a film on filters. Take it out and hold it under running water and you'll see water won't go through. So every 3 months or so, take the filter out and clean with an old toothbrush to remove this waxy deposit. This problem can also cause dryer fires if filter is not cleaned periodically. Hope this helps!
Posted on Feb 05, 2008
Frigidaire frqe7000lw vibrating grinding
did you leave your lent filter out a couple of times? Sock or lent wad may be caught up in the fan that forces air through the dryer.
Oct 13, 2015 | Frigidaire FRQE7000LW Electric 7.0 cu ft...
Lent removal hoover dynamic 9+6
I have H02 on my washer dryer, all i can do is turn it on and off, i wont do anything else, what can i do to get it to work?
May 05, 2012 | Washing Machines
My kenmore dryer wont click on, it will light up and click but nothing happen's I cleaned out the lent trap and the lent funnel and it still wont click on
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
Jul 19, 2011 | Dryers
My Bosch wtl6304 condenser tumble dryer keeps indicating empty filter light and bleeps rapid. It warns me twice like this then trips the thermostat out. I have cleaned filter, washed the condenser out and...
never really heard of a condenser model dryer before however it does seem like internally its full of lent inside of the dryer housing itself around the heating elements if you have a large air compressor open it all up and spray air into everything in the dryer where you see lent build up this will force any lent out of the dryer and it should hopefully run as the day you first got it ;P found this to be an issue even with an LG TROMM dryer i opened up and wasnt drying very well
May 06, 2017 | Bosch Axxis WTL 6307 Electric Dryer
My maytag 3000 series dryer is not even a year old untill 2 more days, it does not dry my clothes no matter what setting I have it on the lent trap gets cleaned about 2 or 3 times during each cycle,yet it...
oooow,,,temper temper,,,,take a deep breath,,,
i think the temp censor has stoped working thats why its not getting very hot its that or the heating coil/s are broken,,also check the air vents at the back are not blocked up if so its not getting any air to it,,,
then go out and find a big stick,,,and batter it with the stick,,,
this realy wont help fix it,,but it will make you feel soooo much better?
Jul 12, 2010 | Maytag Dryers
Not drying completly seems not alot of lent on lent filter
Your rear connecting exhaust vent must be removed and cleaned out.
If it is the flexible vent material it must be un-kinked or mashed when reattached.
Run a 50 minute timed dry cycle with the vent completely off.
If the load dries OK,the connecting vent is the problem.
Jan 17, 2010 | Whirlpool LEQ8000JQ Electric Dryer
Lent is damp dryer takes too long to dry and burning smell
Your burning smell might just be lint which has been loosened by you, getting onto the dryer's heating element. If this is the case, the smell should not last long, nor will it damage the dryer.
Sep 10, 2009 | Dryers
Not drying clothes, heat is on, lots of moisture in dryer
hi there,
This is a classic sign that you need to unclog or improve the dryer venting to the outside of the building.
One of the most important functions of a dryer is the elimination of moisture recovered during the heating of damp clothing. A typical 12-pound load of laundry can weight as much as 20-pounds when first removed from a washer. The extra 8-pounds is water. That moisture is held as humidity in the warm air produced by the dryer and is normally expelled to the outdoors through the dryer's vent. If this air can not be adequately removed, poor drying will result.
This moisture can also condense into pools of water in the dryer vent, eventually leaking out. Moisture accumulation inside the dryer ducting is often a sign of poor venting which should be looked into
good luck!!
Jul 07, 2009 | Kenmore Dryers
Dryer has to run twice to dry completely
clogged wall vent dryer vent,lent shut,clean them all out-mike
May 17, 2009 | Kenmore Elite HE4 Electric Dryer
Dryer has heat..but very low temp , takes forever
Make sure that your vent pipe is completely clear of excess lent. It will not dry properly if the venting is not running freely. If the unit is cleared of lent, inside and out, the only other possibility is the thermostat is not reading correctly.
Apr 11, 2009 | Dryers
GE DCVH515EFWW Electric Dryer Logo
87 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
