Power Acoustik GOTHIC OV2-800 Car Audio Amplifier
Problem for Power Acoustik GOTHIC OV2-800 Car Audio Amplifier
Power acoustik gothic OV2 800 manual
By hahaasshole on Aug 18, 2009
power acoustik gothic OV2 800 manual
Solution #1
posted on Aug 19, 2009
Not Rated)
killerhertz
Rank: Master
Rating: 100%, 2 votes
Could not get a manual for you but did get the follwing specs. Hope they help.
Power Acoustik Ov2-800 2-Channel Class A/B Gothic Series Amplifier (800-Watt)
POWER ACOUSTIK OV2-800 2-CHANNEL CLASS A/B GOTHIC SERIES AMPLIFIER
800-WATT 2-CHANNEL
4 ohm RMS: 150W X 2
2 ohm RMS: 180W X 2
Bridged mode MONO RMS: 360W
BRIDGED MAX: 800W
FULL MOSFET POWER SUPPLY
PWM CIRCUITRY
FULL SELECTABLE CROSSOVER
3-WAY PROTECTION CIRCUIT
TRI-MODE CAPABLE
VARIABLE LOW PASS 40 HZ - 120 HZ
VARIABLE HIGH PASS 150 HZ - 1.5 KHZ
VARIABLE 18 DB BASS BOOST @ 40 HZ
FREQ RESP: 10 HZ TO 30 KHZ
S/N RATIO: 98 DB
THD: 0.02%
2 ohm STABLE STEREO
SYSTEM DISTRESS INDICATOR
HIGH/LOW LEVEL INPUTS WITH FLOATING GROUND
4-GAUGE POWER/GROUND CONNECTION
PLATINUM RCA CONNECTORS
LINE OUTPUT WITH FLOATING GROUND
BLUE LED
CHROME TOP PLATE PANEL 2-CHANNEL CLASS A/B GOTHIC SERIES AMPLIFIER (800-WATT)
Was this helpful?
Yes
No
Popular Solutions for Power Acoustik GOTHIC OV2-800
Questions and Unsolved Problems for Power Acoustik GOTHIC OV2-800
Do you recommend Power Acoustik GOTHIC OV2-800 Car Audio Amplifier?
Answer
Answer
is there a wiring diagram for the nikkai EAPA450 Amp
Answer
steps to repair power acoustik gothis 2200 amp. for some wat reason i think my amp sorta burnt... (More)
Answer
im looking at a ssl fy1402 1400 watt amp 375rmsX2 at 2ohm and it is 2ohm stable. I'm getting a cvt12... (More)
Answer
hooked amp up it was working softly changed ring terminal on power cable to battery and it would not... (More)
Answer
Ford 5000 RDS head unit, the radio is drifting on AM and FM and making screeching noises as if... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Power Acoustik GOTHIC OV2-800...:
Top Car Amplifier Experts
Rank: Guru Guru
Solutions: 14935
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Car Amplifier Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
