Question about D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B)
D-Link dsl-2640b ive just purchased this router but basically have not got a clue what im doing im currently connected with AOL on a bt voyager 105 usb adsl modem i want to connect my other computer to the internet wirelesslycan you help me
  • 556 Answers
The first answer seems to address your question however as noted in your article the mode you have is not on AOL's recommended however it does support PPPoE so it may (should?) work. I recommend setting it up and getting it to work with a computer wired to the router before configuring and testing wireless connections. In terms of wireless configuration see
Posted on Dec 06, 2007
My dlink dsl-2540u router not connect to the internet. Dsl led blinking & sometimes totaly off.
Contact your ISP immediately- the issue you have is called no sync. Basically with the DSL led going completely off- that would point to a bad modem, however the fact that you have no sync otherwise indicates your DSL provider may need to service your DSL line.
Jul 09, 2011 | D-Link ADSL2/2+ Modem/Wireless Router...
Router supplied by AOL - DSL-2640R Firmware version V1.18 The router drops the Internet connection constantly.
Your router has small NAT table and it's easy to overflow, especially if P2P like torrent used. The only solution to prevent router to drop out connections is reset it periodically or install Router Comamander software (freeware version available). Router Commander prevents router from dropping connections using dynamic NAT table size control.
Dec 12, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
try scanning your computer for viruses and spy-ware, full scans and let me know if it still gives you problems. also- power cycle might be the trick.
(turn off pc, then router, then internet box- turn on in reverse order.
Aug 18, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Installing BT Voyager 105 on XP Pro PC shows newdev.dll error
I recently had this problem after buying a voyager 210 modem/router to replace the voyager 105 (in my case supplied for AOL broadband)
I tried to uninstall the voyager 105 and encountered exactly this problem - newdev.dll missing, Admin privileges required
After alot of Internet searching I found no answers. But in desperation tried this and it worked. I am by no means any computer expert so don’t blame me if this does not work for you, or damages your machine.
To install my 210 modem I was following instructions found here - But first I had to get rid of the 210
Here is what I did, exactly as I did it (some of it is probably unnecessary) Further below is a condensed version I expect would work.
1) Firstly I restarted in safe mode by pressing F8 in start-up ( I was doing this because i had remembered an administrator profile and considered attempting to uninstall from there.)
2) I logged on as the administrator.
3) Attempted to uninstall the voyager 105 via control panel and via the uninstall icon in the programme folder. - Both Failed with the above-mentioned problem.
4) I navigated to programme files. (Start> My computer> C drive> Programme files)
5) There I highlighted the folders "British Telecom”, "BT Voyager 105 ADSL modem", " Voyager Modem Drivers", "Voyager Test". I cut these folders wholesale and pasted them to my USB pen/stick (incase I needed to put them back)
6) I then ran disk cleanup (Start> All Programmes> Accessories> System Tools.)
7) Then I turned off my computer and unplugged the USB pen/stick and the USB and DSL cables from the back of the Voyager 105.
8)I turned the computer back on (starting up normally), logged on with my normal username which has admin privileges. Ran the driver install for my new router (previously downloaded from BT at –( It stated that a BT driver was already installed.
9) Navigated to add/remove programmes (Start> Control panel> add/remove programmes) selected the BT driver from the list selected uninstall …. AND IT DID IT! No error, or messages about newdev.dll or privileges.
10) This left me free to install my new driver and go through its install process ending in plugging the USB into the back of the modem and having internet again.
Here is what I expect would work
1) Turn on and log on to any account with admin privileges.
2) Navigate to programme files. (Start> My computer> C drive> Programme files).
3) Select and delete (or to be safe, cut and paste to a removable drive) the folders "British Telecom", "BT Voyager 105 ADSL modem", " Voyager Modem Drivers", and "Voyager Test".
4) Remove removable drive and run disk clean up (Start> All Programmes> Accessories> System Tools).
5) Then I turned off my computer and unplugged existing modem.
6) Turn on computer log back onto account with admin privileges. Navigate to add/remove programmes (Start> Control panel> add/remove programmes) selected the BT driver from the list selected uninstall.
7) Install desired drivers/modem.
If you find this works for you too and have asked this question elsewhere, please copy this solution so others can solve this problem too
Jul 11, 2009 | Computers & Internet
Cannot Connect to the Internet Using a New D-Link DSL-2640B
1. Make sure you have the latest firmware
2. Restore to factory settings first. This helped me with stacked ppp session.
3. Setup your connection according to ISP
4. If you have problem, install Router Commander from
5. Setup router to send syslog to your PC
6. Check syslog messages about the clue what's going on
Dec 17, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
Can't even connect to "setup assistant"
it sounds like you need to keep using your usb modem to connect to the internet. then setup internet sharing on the computer and connect the wireless router to the network plug on the computer.....
then basically you are sharing the internet to the plug on the back of the pc into the router and then wirelessly out to the network and PS3
Aug 18, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
D-Link DSL-2640
First I will need to know the type of ISP service you have, T1 - DSL - ADSL - CABLE - etc. And the connection type, STATIC IP - DYNAMIC IP - PPPOE - etc. BPCS
Dec 11, 2007 | D-Link ADSL2/2+ Modem/Wireless Router...
D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B) Logo
670 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
