Question about Ricoh 6513 Copier
About leaning the Sensor inside the dpinting drum for Ricoh aficio 6513
Like the other person I also getting the service message SC384 after calling my technician he said the sensor inside the printing drum need to clean. does any body know where to get the instruction or exact "how to" in the order to get to this sensor?
You help is truly appreciated
Thomas
  • fernando_vil May 11, 2010
    Hi Jules, is it posible to get a diagram or a drawing of the procedure to identify the parts?
  • 69 Answers
Hi im jules_09,you can get the instructio from your technician they this service manual that has it all from service code to repairs.its a bit tricky cleaning it and also you migth sratch or damage the drum.if you ant i can direct you but be extra extra carefull.
1st open front door,then remove toner cartridge and move it to your right so you can full out the developer unit.
2nd un srew the developer unit then carefully full it out.be carefull its a bit heavy
3rd see the drum unit it also have srews un srew it then full it out,do not let the drum be expose the drum from light office or sunlight.thrn place it in a table beneath it is a news paper or a soft cloth,thereyou ca see the drum procees unit you can clean it by using a smooth paint brush then locate the id sensor its just a litttle component located at the front end and left side while facing it,just clean it with the brush or blow air to it not with a compressor just blow like blowing a candle 3times then re install the same process i repeat do not let thedrum be expose to light ok
Posted on Dec 02, 2007
SOURCE:
How i can install ricoh aficio 6513 with windows7
search driver
try this driver but idk if it work on windows 7
or you can buy an old PC and put Windows XP or Linux on it
or the last solution is to change printer(not the best)
Oct 28, 2012 | Ricoh Aficio Color 6513 Photocopier /...
Ricoh aficio 6513 error code 422
this is a corona leak could be a broken or dirty corona wire
Jan 03, 2010 | Ricoh Office Equipment & Supplies
Ricoh aficio 6513 error 326
This is because the image transfer belt is dirty
Nov 26, 2009 | Cell Phones
Aficio 6513 ID sensor location / service manual
The ID sensor is located under OPC drum.Clean the optics component,the charge corona ,and see if the OPC drum is good(change every 120000 copies).
Oct 21, 2009 | Ricoh 6513 Copier
Solution for "code 373 ricoh aficio color 6513"
Hello sir; the error code you display is toner senser problem, now the first thing you have to do is make a full color copy find out which color missing then pull out developer unit from missing color the senser right underneath, replace it.
May 23, 2009 | Ricoh 6513 Copier
Have a Ricoh Aficio Cl 4000DN and have replaced the CPU Drum
You most likely have a defective "yellow" PCU . Try replacing that.
Otherwise you have a high voltage problem
Feb 23, 2009 | Ricoh Aficio AP3800C Laser Printer
Aficio 6513
the proplem solved by adjusting the the home position of the trans fare belt cleaning unit .
May 24, 2008 | Ricoh 6513 Copier
Ricoh color aficio 6513
The following is taken from the service manual I hope it helps Thanks J
SC457 Position error for
the image
transfer belt’s
cleaning unit
- Timing & Condition
• When the belt cleaning
section touches the
image transfer belt, but
the belt cleaning sensor
signal remains LOW.
section releases from the
remains HIGH.
• Dirty Sensor
• Defective sensor
• Defective belt cleaning
shift clutch
• Defective drum
peripheral component
motor
• Defective I/O control
board
• Defective main control
board
1. Pull out and re-insert the image transfer
belt unit.
2. Clean the image transfer belt cleaning
H.P. sensor.
3. Replace the sensor. (Input Check: 5-803-
012)
4. Replace the belt cleaning shift clutch.
(Output Check: SP5-804-036)
5. Replace the drum peripheral component
motor.
6. Replace the I/O control board.
7. Replace the main control board.
[Signal Check]
• H.P.: CN219-B2 or TP108 on the I/O
control board
Jan 06, 2008 | Ricoh Aficio 2022 All-In-One Laser Printer
Aficio color 6513 id sensor location, td sensor location
toner density sensor is located in the developer unit. either the sensor is not reading cause something is covering it or it has poped so it can not reference any longer.
Oct 17, 2007 | Ricoh 6513 Copier
Error code
sc 385 is ID sensor vsg adjustment error.Clean the ID sensor.If the developer life is expired replace the same
Sep 05, 2007 | Ricoh 6513 Copier
Ricoh 6513 Copier Logo
465 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
