Microsoft Xbox 360 Wireless Controller Logo
Posted on Aug 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My 360 controller keeps disconnecting
Even when my batteries have plenty of power my controller randomly disconnects and shuts off and when i turn it back on, a few seconds later it'll shut off
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Dec 24, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
3457
Points
5
same problem, i've been using rechargeable batteries for over a year with this controller and i've never had a problem with them, i have 8 fully charged ones sitting on my desk right now and every one of them is giving me the same double flash problem, my pc is telling me its "lost connection with the controller" but gives no information as to why this may be. this has only been a problem since i've gotten back from uni, before it would occasional not turn on (probably due to the tray being abit loose) but i fixed that with the rebending of the retention spring in the middle of the battery tray, but its still giving me the same problem. it seems to me as if the batteries have nothing to do with the problem, if they were, it wouldn't be turning on at all.
  • kervindor Jan 19, 2011
    mines does the same thing but it only happens when the controller is supposed to vibrate is it the same with you
Anonymous
Level 2:
  • Expert 43 Answers
  • Posted on Aug 18, 2009
Anonymous
Expert
Level 2:
Answers
43
Questions
0
Helped
13003
Points
123
You need to take the controller apart and look for cold(bad) soldering on the battery leads.
Anonymous
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Sep 10, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
0
Helped
2394
Points
7
Or maybe its that your battery pack is too loose if this is the problem just put tape over it.
Ho w to fix x box from controller to x box is really slow how to make it normal
Learn how to connect a wireless or wired controller to your Xbox 360 console.
Connect a wireless Xbox controller
  1. Turn on your console.
  2. Press and hold the Guide button on the controller until the controller turns on.
  1. Press and release the connect button on the console.
Xbox 360 E console fbbfb609-f7ed-4e6e-bd35-7543b1c20d61.png?n=xbox360-connect-m-s.png Xbox 360 S console Original Xbox 360 console 342c6e70-9e56-43d8-bb3a-05f5411040bd.png?v=1#xbox360s-connect-m-m.png 170df81e-0a79-49be-8236-a0fb68eec37b.png?v=1#xbox360-connect-m-m.png
  1. Within 20 seconds, press and release the connect button on the controller.
  1. When the lights surrounding the power button on the console stop flashing, the controller is connected.
On the Xbox 360 S console, each connected controller is assigned to one of four positions. Each position corresponds to a lighted section around the console power button and the controller Guide button. On the 360 E console, a solid green light on the front of the console indicates that the controller is connected. To determine the player position associated with your accessory, look at the ring of light that surrounds the Guide button on the controller.
c9341988-8ed5-4217-9b87-353de50efbec.png?v=1#connect-xbox-controller-m-m.png 5e4ab6ab-8cb0-41e6-a037-b88221a430c7.png?n=connect-xbox-controller-360-m-s.png
71add0b7-ddf2-4439-b4b4-f50f156d92b7.png?v=1#controller-batteries-m-m.png If the controller does not turn on, check the batteries. Insert fresh AA batteries, making sure they are correctly positioned in the battery case.
You can also use the Xbox 360 Play & Charge Kit or the Xbox 360 Quick Charge Kit to power the controller. Learn more about Xbox controllers and chargers.
To connect additional controllers, follow these same steps again. You can connect up to four controllers to the console. Each connected controller is assigned a position that corresponds with the lighted sections that appear around the console's power button and around the Guide button located in the middle of each controller.
  • To disconnect a wireless controller, press and hold the Guide button for three seconds, and then choose to turn the controller off.
  • When you turn off the console, the controller will reconnect the next time you turn on the console.
  • The controller can be connected to only one console at a time. You can connect the controller to a different console, but the connection to the previously connected console will be lost.
Connect a wired Xbox controller
5fb17f50-7448-45d5-a294-9ea90994f55b.png?v=1#controller-wired-m-m.png Plug the Xbox 360 Wired Controller into a USB port on the Xbox 360 console. There are two USB ports on the front of the console. To disconnect the controller, pull on the connector, not the cable.
cbe46bf0-3a46-4d53-9d8c-6697aa57622a.png?v=1#controller-cable-release-m-m.png The cable on the Xbox 360 Wired Controller has an inline release. The inline release on the controller cable is a safety feature designed to reduce the chance of the Xbox 360 console falling if the cable is pulled.
Wireless controller troubleshooting
If your wireless controller disconnects or cannot connect to your console, see Xbox 360 Wireless Controller disconnects or can't connect.
If your wireless controller does not turn on or loses power, try the following solutions:
Solution 1: Replace the batteries
Insert a new set of AA alkaline batteries into the Xbox 360 Wireless Controller, and then try to turn it on.
Solution 2: Try a different battery pack
If you have another Xbox 360 Wireless Controller, take the battery pack off that controller and attach it to your controller. Then try to turn your controller on.
If your controller works with the different battery pack, your original battery pack might be defective. If your controller is under warranty, you can order a replacement battery pack from Xbox Support . See the Assistance section at the bottom of this page for more information.
If your controller is out of warranty, you can buy a new battery pack from a retail store.
Solution 3: Try a rechargeable battery packIf you or a friend has an Xbox 360 Rechargeable Battery Pack, attach that battery pack to your controller and try to use your controller. If your controller works with the rechargeable battery pack attached, you can buy a new battery pack from a retail store or order a replacement battery pack from Xbox Support. See the Assistance section at the bottom of this page for more information.
tip
Get wireless Xbox 360 controllers to stop disconnecting
By disabling the vibration on the controller, you can keep the batteries in place and the controllers will disconnect less often. If you want to keep the vibration feature on, then use some tape to secure the batteries in place before you put the cover on.
Xbox360 console randomly shutsdown
take front face plate off and disconnect the wire for power and eject sensors. you will have to use the controller for ejecting a disk and powering on but quick fix and has no problems. i had to do it to mine and its still disconnected for 2 years now and now problems and no shutdowns by itself.
My xbox 360 elite is randomly disconnecting itself from both of my controllers and the batteries are brand new and fully charged
Hello
If you replaced the batteries then you may need to re calibrate the controllers to the x box console.
My Xbox 360 Wireless controller keeps disconnecting in the middle of Halo: Reach matches. I have tried different batteries, different battery packs, and even different controllers! But the problem...
You should get a refund for the game or exchange it. Also you should go to Game Stop and see if they could fix it. There must be a bug in the game.
7helpful
Wireless xbox 360 controller keeps disconnecting when i fire or get shot evertime whats the problem
I've had this same problem with a few controllers. It's your battery. Well, more specifically the container of the batteries. Chances are, it's lose.
(I would have to keep holding mine firmly in place, while playing games.) The reason it disconnects when you get shot is cause of the controller vibrations. It makes your battery jump out of place, due to not being held in place firmly.
My suggestion would be to either buy a new battery container, or turn vibrations off.
Hope this helps.
Wireless controllers for xbox 360 disconnect at random times
It sounds like there is a probem with the RF Board (google search it). Problems occur with this from time to time when a sytem is disassembled and reassembled.
17helpful
Xbox 360 controller turns off at random, yet has new batteries
The battery indicator found when pressing your xbox logo button is temperamental. It might say 2 bars, or 3 or even full battery but this is not a good indicator of a full battery.
The problem IS low batteries(or more specifically - bad batteries) - when the batteries become low the vibration function can cause the controller to disconnect. This is happens because the vibration function uses extra battery power.
So basically... Every time your controller vibrates, it disconnects. This occurs when firing a weapon in most games, grenades in COD, landing heavy tricks in Skate 2, the list goes on, you'll find many complaints from people stating their controller disconnects specifically with these events.
The simple solution, turn off the vibration function when this occurs. It'll never happen to you again ^_^
Thumbs this up when it proves correct for you. I'd recommend a recharge while you play pack. ALWAYS by the official products too. They're much more reliable and aren't prone to this kind of behaviour.
79helpful
10answers
Xbox 360 wireless control conects then disconnects randomly
The solution is VERY simple.
There is nothing wrong with your controller OR your xbox.
The problem IS low batteries - when the batteries become low the vibration function can cause the controller to disconnect. This is happens because the vibration function uses extra battery power.
Thumbs this up when it proves correct for you. People will find the solution quicker that way.
Top Microsoft Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
ELECTRICKSUSA
ELECTRICKSUSA
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
