Question about Jenn-Air JGR8875QDS Gas Kitchen Range
Electronic touch pad problems
The touch pad on my Jenn-Air JGR8875QDS does not work properly. For example, in trying to set the clock, the only numbers that work are 1, 4, & 7. Do you have any ideas as to the problem/solution?
Thank you.
Dennis
  • 2 more comments
  • angcarle Nov 02, 2008
    #5 is not working as well as self clean, timer, clock and lock buttonjs
  • carstensoren Nov 14, 2008
    Touch pad #'s will not work. Cancel works, we have to press Bake twice to cook and it sets the oven to 350 deg only.
  • Anonymous Nov 30, 2008
    Same problem, after a little over 3 years.
  • Anonymous Jan 05, 2009
    1 2 3 4 5 6 won't work
  • 22 Answers
From what your telling me, you have tried all the numbers and only 1,4 and 7 beep when touched. Also, the timer display was set at 0:00 when you started. Also, you followed the manual's instructions first, and looked in the back of your manual in the trouble section, and found no answer.
Did you timer ever work? If not, you should be able to a free replacement of the control panel module from an authorized Jenn-Air repair company. It may be a good idea to contact Jenn-Air first.
The timer shows only hours and minutes when first started. For example 2:05 is two hours and five minutes. It goes into the seconds mode only during the last minute.
Posted on Dec 03, 2007
You need to replace the whole touchpad/display unit, which includes the whole top/front cover.
Posted on Mar 08, 2009
 the f1 and f3 fault code beeps i press clear it goes off but still will not let me cook in my oven.  gas down draft stove model jds9860aap
Posted on Dec 28, 2007
SOURCE:
F1-8 error
F1 indicates a clock or touch pad problem. F8 indicates a clock, or ERC (Electronic Range Control) problem. Are you receiving both codes? If so it seems likely that your touch pad and ERC are contained together in one module, and must be replaced. If you find however that they are separate modules it is possible to determine which is faulty by simply disconnecting power to the unit, disconnecting the touch pad from the ERC, and then powering it back up. Wait for a half hour or so to see if the unit sets the error code again with the touch pad disconnected. If it does the ERC is faulty, otherwise it is the touch pad.
Please note that if you do not have experience mucking about in your appliances inner workings it is best that this be done by an experienced technician.
May 12, 2011 | Jenn-Air Cooktops
The Jenn-Air Gas Range Electronic touch control 800. The key pad does not work. You can not set the clock or work the oven. Help.
My Jenn Air has the same problem with the computer touchpad. The only temperature I can get to work is from the left hand column, 411 degrees. I don't want to waste another dime on this oven. I've read so many complaints from other owners. No more Jenn Air products for me.
Nov 22, 2010 | Jenn-Air Ovens
Jenn- Air cook top oven sve47500b has error # F7 and the oven will not work
F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC).
Oct 25, 2010 | Jenn-Air JED8430 Electric Cooktop
Electric Range.-oven stopped working. Error Code F1 show on electronic display
Hello there:
Here is the 2 most common f1 codes for this oven and what the problem is and what repair procedures that should be taken
F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad) F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC)
Dec 13, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
Oven won't work and the touch pad is diplaying "off"
first try a Hard reset...
find the house breaker panel find the oven breaker should be a double 40 or 50 on it .. turn it off for 30 sec than back on....
let me know for it help if NOT please let me know and I will be glad to do more in depth.
Sep 26, 2009 | Jenn-Air JGR8875QDS Gas Kitchen Range
F0 fault code
Hi ,
F0 is Function key faulty.
You can find parts online at partselect.com , or appliancespartspro .
May 29, 2009 | Jenn-Air Ovens
Jenn-Air Wall Oven up controls don't work
you have a touch pad issue, whats the model and serial ill look up the part for you, sometimes you can just get the key pad, sometimes comes sa a whole console or as part of the electronic control itself.
Mar 17, 2008 | Jenn-Air SCE30600 Slide-In Electric...
F9 Code after power outage - Model JGR8855ADS
Try unplugging the oven from the electrical power. May release the lock, which is held in place by a tiny micro switch. If not and while the electric is still off or the oven is unplugged, use a bright light flashlight to look through the slot where the lock is in the oven, not in the door.
You may be able to use a thin blade screwdriver to move the lock to the release position. Check the angle of the lever. A slightly bent lever handle also can cause this type of condition.
If all else fails, remove the access panel on the front of the oven to access the locking device and release it. May have to disconnect the wires to the lock which will allow door to function but not during any self cleaning modes.
Generic:
Fault Code Interpretation Components To Check
F-1 Communication error between touch pad and ERC (clock)
Replace the touch pad or clock.
F-2 Oven temperature sensed by electronic control Replace the clock/relay board
F-3 Open oven sensor or harness. Replace the oven sensor
F-4 Shorted oven sensor or harness Replace the oven sensor
F-5 Power to element relay disabled in cook mode Replace the clock/relay board
F-7 Shorted touch pad key sensed for 32 secs. Replace the touch pad/control panel
F-8 Shorted meat probe Replace the probe jack.
F-9 Door lock safety circuit on ERC sensed Replace the door latch assembly
F-C or F-0 Communication error between boards Replace the relay board
Maytag-Maycop-Magic Chef-Jennair-Admiral: Oven Fault Codes:
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Mar 09, 2008 | Jenn-Air JGR8875QDS Gas Kitchen Range
F-8 on my jgs8750ads
F8 Analog / Digital problem Replace clock (ERC).
Not hard to replace, just make sure you unplug the appliance first. I can not tell you about a recall, try contacting customer service with that question.
Jan 29, 2008 | Jenn-Air JGR8875QDS Gas Kitchen Range
Jenn-Air WW30430W double oven flashing F7 and beeping
It seems you have a stuck button. Here is a list of fault codes:
JENN AIR
Range/Stove/Oven Fault Codes
Failure
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad) F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) F2 Oven too hot Replace relay board (if present) or oven temperature sensor F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Check for proper voltage F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or attempt to un-stick button F8 Analog/Digital supervisory Replace clock assembly (also called the ERC) F9 Door latch supervisory Check door lock circuit or replace clock assembly (also called the ERC) F0 Function key stuck Replace touch pad or clock assembly (also called the ERC)
Dec 09, 2007 | Jenn-Air JJW8530C Expressions Collection...
Jenn-Air JGR8875QDS Gas Kitchen Range Logo
826 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Thomas F. Schneider
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
