The packard bell motherboard i have is the ga6wmm7 I have made sure all connections are snug and in the right place also just put in 2 128mb ram sticks i keep having an alarm go off that sounds like this, be do be do be do and continues, what may be the problem need help fast because this is a work computer. I would not ask this if i had access to a manual
I understand that your connections are snug, but that beep code means RAM issue. Humor me and swap the RAM in the slots. If that doesn't do it you may want to run Memtest or try other "known good" RAM.
having the same alarm with the same motherboard, I gave it a spring clean this morning everything was running fine, nowi can't even get into C-mos and its driving e insane with the be do be do be do contunius alarm. ive swtiched its slots it will oly boot with the ram in just one slot, the alarm continues and it still will not let me into C-mos. is there a way to solve this?
Have you tried both sticks in the one slot? If you have and they both worked, you may have a bad slot. If only one of the sticks work you have a bad stick of RAM that needs replaced.
