Question about Sony Cyber-Shot DSC-P32 Digital Camera
Lens shutter is getting stuck when camera is turned on
When I press the power button, the lens shuter tries to open and does half way but then gets stuck?? It asks me to turn it off and on but it always does the same thing.......can you help????
  • gerrigraphic Dec 07, 2007
    Shutter will not work. Tried rapping it on table but did not resolve problem. Any suggestions of where I might have it repaired at a reasonable price or is it better to just throw it out?
Mine was doing that when I sent it in to have the lens/screen problem repaired. The camera was part of a class action lawsuit and the repair was free and fast via Sony, but since then I've had issues with power. The camera won't stay on!
Posted on Dec 19, 2007
I keep getting error 99 message
Error 99 is common error on Canon cameras. Make sure the battery is freshly charged. Take the battery out, the compact flash card out, and the attached lens off of the camera. Leave the camera set for a while for the capacitors to bleed off. Around a half hour would be good. Next re-insert the battery and push the shutter button as if you were taking a picture. If you get an Error 99 then, you can't fix the trouble and Canon will have to do it. If you do not get an error 99, power the camera off, insert the compact flash card, power the camera back on and press the shutter button again. If you get an Error 99, the trouble is in the compact flash card or its connector. Try a different card. If you do not get an Error 99, power the camera off, a lens on it, power the camera back up, then press the shutter button once again. If you do not see an Error 99, the problem is no longer in the camera. If you do see an Error 99, power the camera off and remove the lens. The problem is probably in the contacts on the camera or the lens. Clean the contacts by holding the camera carefully with the lens opening down so it will not allow dirt to get inside the camera. Take a cotton swab dipped in alcohol and clean the gold metal contacts well, Dry the contacts with a tissue. Next hold the lens with the contacts down and repeat the process on the contacts on the lens. Be very cautious not to allow lint, dust, or alcohol to get into the camera body or into the lens. Some people use a pencil eraser to clean the contacts but you have be very careful not to let particles enter the camera or lens. This should clear your trouble, if the camera passed the first step of troubleshooting.
Nov 02, 2013 | Canon EOS 40D Digital Camera
Our camera seems to be okay but when i'm attempting to get picture, i can't see any image in LCD, is it the lens?
First try pressing the DISP or DISPLAY button on the back of your camera. If that doesn't help, try taking a picture with the screen black. Is the picture also black? If so, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Oct 13, 2011 | Sony Cyber-shot DSC-S750 Digital Camera
LENS ERROR, RESTART CAMERA
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Sep 17, 2010 | Canon PowerShot SD1100 IS Digital Camera
WHEN I TURN ON CANON POWER SHOT A1000IS THERE IS NO DISPLAY ON LCD SCREEN.
First check that you didn't accidentally press the DISP or DISPLAY button on the back of your camera. Press it once with the camera turned on just to check.
If that didn't help, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Feb 21, 2010 | Canon Cameras
Error Message
Try to take off the battery and reset the camera. You can also try to remove the lens and check the mirror opening..see if there is some thing stuck there. You can try to click the shutter while the lens is removed. If this procedure didn't work I suggest calling Nikon for further repairs.
Sep 25, 2009 | Nikon D60 Digital Camera with 18-55mm lens
Power shot a620. screen is not showing pictures, all icons are there but screen is black? Help please!!
Sounds like you might have accidentally pressed the DISPLAY button on the back of your camera. It turns the screen on and off to save batteries. Turn on your camera, and press this button once again to turn the screen back on.
But if your camera is also taking black pictures,
Jul 30, 2009 | Canon PowerShot A620 Digital Camera
Shutter stuck half open
This sounds like the mechanism has worn. It is a straight forward service centre procedure, I wouldn't recommend trying to do anything that will make it worse. Leave it to Nikons engineers.
Mar 11, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
ERROR 99
if you have a DSLR and your'e getting this "error 99" it may be associated with the particular lens youre using. try turning off the camera and removing the battery, the lens, and the memory card. let it sit for half an hour. reinsert the battery only and depress the shutter button as if you were to take a normal picture. if error 99 occurs again, then the camera needs servicing. if it error 99 doesn't occur at this point, turn the camera off and install the memory card. format the memory card while it's in the camera and press the shutter button as if youw ere to take a normal picture again. if you see error 99, then the problem probably lies with the memory card. if it doesn't occur, turn off the camera and install the lens. again, power on the camera and press the shutter as if you are taking a normal picture. if the error occurs, then it's with the lens. try to clean the lens including the connection points both on the camera and the lens. if the error code still occurs, try different lens to narrow it down to which particular lens is giving the issue. if it happends with all the lens, then the camera needs to be serviced.
Sep 16, 2008 | Canon Cameras
Frozen lens and shutter
Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Sep 06, 2007 | Canon PowerShot A510 Digital Camera
Sony Cyber-Shot DSC-P32 Digital Camera Logo
49 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
