Question about Danby DMW139 Microwave Oven
LED displays ''STAGE'' after magnetron replacement on DANBY DMW162W-OTR
magnetron was replaced on a DANBY DMW162W-OTR microwave.
LED display now shows ''STAGE''.
Unit starts but does not heat.
This ''STAGE'' status is not specified in user guide, and i cannot find a service manual.
any kind of help would be appreciated.
Pierre (Montreal)
email: [email protected]
  • PXD240 Dec 02, 2007
    Hi Microwavesvc,
    this model goes back 3 years and is discontinued.
    All three Danby service dealer i have called do not want to even try to fix because its discontinued. I cannot even get the magnetron from Danby because its discontinued.
    I have met a local ''appliance'' tech who was willing to give it a shot.
    He found a ''generic'' ,magnetron ( same specs ) in Colorado.
    It was installed, giving the status ''STAGE'' on the display.
    The ''dummy'' type user guide is incomplete and worthless.
    What i need is a ''service manual'' which a cannot find anywhere.
    A service manual would probably point me to a combination of digits on the keypad that would ''reset'' the unit.
    I have submitted this issue to Danby service to be told that a tech would call me back with an answer, ....which was not the case.
    Danby makes cheap products and don't stand behind what they make.
    thank you Microwavesvc for responding
    Pierre
  • Danby Master
  • 9,173 Answers
What does the service center have to say about this?
Or did you do it yourself?
Posted on Dec 02, 2007
  • William Miller
    William Miller Dec 02, 2007
    Maybe these contacts can help?
    Monday – Thursday 8:30 – 5:00 EST
    Friday 8:30 – 4:00 EST
    By Phone:
    General 519-837-0920
    Sales 800-461-4492
    Consumer help line 800-263-2629
    Service issues: [email protected]
    Parts inquiries: [email protected]
SOURCE:
I removed the bolts for my Danby OTR microwave. Dmw162w-otr. The microwave does not move. Are there any other bolts or is there anything I am missing before I can remove the microwave?
In a normal installation, there is a plate that mounts to the wall and bolts come down through the cabinet. Once the bolts are removed from the cabinet above mic, the mic should hindge forward. It takes two people to handle. How ever, in some cases an installation guy will add screws into the side of the unit. So look for some screws to the right and left of mic. Good luck!
Jan 29, 2016 | Danby Microwave Ovens
I have the danby designer Mod DMW162W-ORT that won`t heat at all but everything else works. Hums a bit louder but will not warm.
The Magnetron in your unit is no longer resonating properly. The Magnetron produces the microwave frequencies and when it resonates properly, it will provide the excitation to heat your item(s). As well, the diode that accompanies the magnetron needs to be replaced as well. Should it be under warranty, take it back. Out of warranty? Have an appliance tech repair it (usually around $175) or get a new microwave.
This is typical for most microwaves. No such thing as quality any more.
Apr 12, 2011 | Danby Microwave Ovens
Microwave will not heat food but everything else works.
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))
Nov 13, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My microwave will not heat up food.
Oct 10, 2009 | Danby Microwave Ovens
Microwave Spacesaver #JUM 2050BH001not heating
(((The fuse is located inside the unit along side the magnetron)))...
Sep 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave does not heat but every thing works
Aug 03, 2009 | Kenmore 63252 Microwave Oven
Microwave want heat any longer. Everthing else is
Jul 31, 2009 | Microwave Ovens
Were are the magnetron ???
HI,
this will require the skilled hands of a qualified tech. the damaged part here is the Magnetron assembly. this is a very sensitive part that creates radiation and the heating process as well. you will need to replace this device asap if possible...
thank u
rate me
Jul 13, 2009 | Danby DMW139 Microwave Oven
Microwave runs but does not blow heat
(((The fuse is located inside the unit along side the magnetron)))....
Oct 03, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Not working
Sep 18, 2008 | Danby DMW1153 Microwave Oven
Danby DMW139 Microwave Oven Logo
256 people viewed this question
Top Danby Microwave Ovens Experts
William Miller
William Miller
vince
gbob59
Are you a Danby Microwave Oven Expert? Answer questions, earn points and help others
