Question about Konica Minolta bizhub 350 All-In-One Laser Printer
  • 214 Answers
Press utility, and there is meter counter or you can see meter count in web interface
Posted on Dec 05, 2007
How do i get an event log on bizhub250?
No such item. must use the meter count meter. if so some one use the machine. did you use the had count meter or the one on the screen hard count is inside toner cover
Mar 07, 2016 | Konica Minolta bizhub 250 All-In-One Laser...
How do I clear the error code C11A3?
Shutter unit defection.Press Utility key-Meter count-Check details-00000000-End and you entering in service mode,select trouble reset.The very simple method is remove the finisher/exit unit and work without.
Aug 05, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
Bizhub c350
Before replacing the IU select Utility - Meter count - Check details- Stop 00 Stop 01,enter 00000000 END,select Tech.Rep.Mode - Counter - Special parts counter-PC life.Press the Clear key to clear the counter value.Select IC life and clear the counter value.Turn OFF the copier and remove IU unit.After installing the new IU unit select Tehc.Rep.Mode -Function-F8 and press START.After 2 minutes the developer is initialized to make a copies. fcf3fced-96eb-4483-840f-8de548aa8045.jpg 378b39ea-2f19-4cf6-887c-617430da4931.jpg
Jul 14, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
How to clear developer count ineo 350
Go to Tech. Rep. Mode screen then press [ Counter] --> [Special Counter] -> [Developer count] -> [Clear]--> [Exit]. Then turn off main switch 10 secs. turn it On.
May 27, 2014 | Konica Minolta bizhub 250 All-In-One Laser...
Need to replace the drum on a minolta bizhub 350 copier
First get into service mode. Utility/Counter then meter count then check details. Then Stop 00 stop 01. Counters. Clear Drum and Developer. Then touch end do not exit all the way out of service mode. Turn off the machine using the main on/off rear of machine left hand side. Then remove the image cart. and replace the drum and developer. then turn machine on reenter service mode. Run F-8 found under Function. Do not print copy or allow fax to print before this is done. Or you will have to replace the developer again. So remove network cable and fax line if machine is as printer and FAX. after powering off
Jan 15, 2014 | Minolta bizhub 350 Black and White Copier
The problem is in the fusing unit,fuser warm up error.Enter in the service mode:Press utility key Meter count key introduction 00000000 press enter select trouble reset.
Jan 24, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta C652 Fax/Scan Button and User Box Button
The hard drive is not turned on. enter service mode ( utility, meter count, details, stop, 0, 0, stop, 0, 1 - this should be pressed in exact succession) then go to system 2 and look for a place where it asks you about all the installed perifferals. Turn the hard drive setting on.
Jul 14, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
How to clear nvram
how to do reset nvram for HP 4250 laser printer,
Jan 02, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Question about Konica Minolta Bizhub 350
click here for the steps on how to configure the bizhub 350 and here for the vista driver that you need to use if you're going to install it in a vista computer
hope this'll help you
Aug 26, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
364 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
