Question about LG WM-2432H Front Load Washer
Wm1832cw it will stop washing after a few minutes ........and do nothing....
  • 1,294 Answers
Plug off the wall, check your washer plug, & the wire leading to the machine; there shd be some loose connection somewhere, your wall socket.........
Posted on Dec 02, 2007
Lg wm1832cw de error occurs when starting the washing. after multiple tries, it might start
It is a door lock error caused by bad door lock switch or if your door is very hard to swing closed because the hinge is corroded, then the hinge could be causing the door lock to error.
Jan 04, 2014 | LG WM-2277HW Front Load Washer
I have WM1832CW washer. I believe the timer is not functioning. It washes, but stays in the spin cycle. Goes through spin for several minutes and then it gets the IE error. The fabric softener never goes...
The error you are receiving is a bad water valve inlet problem. It's typically the cold inlet, but it's better to replace both.
Depending on the type of water you have, the valves could have lots of sentiment blocking the filter screens inside the valve, which can be cleaned, you'll just need to remove the water hose attached, and check.
If your valves look clear, then they have just possibly failed, and need to be replaced.
Mar 10, 2011 | LG WM2277H Front Load Washer
Lg wahser wm1832cw flashes oe on readout. nothing in drain
If you are getting this code it is because your washing machine has tried for at least ten minutes to drain the water out of the machine. The most likely cause of this problem is that you have a plugged pump filter or you have something stuck in the pump filter.Make sure that you unplug your washing machine.To clean out the pump filter you must empty the washing machine water. The best way to do this is to manually drain the water into a low bucket or basin. Then lay a towel down to catch to remaining small amount of water. Remove the pump filter, clean out any debris, and wash out the filter. Then plug your washer back in and restart the washing machine.Check that your machine is properly leveled. A washer that is too far out of level may not drain properly. Make sure that you are level front to back as well as side to side.This solution will solve your problem
Thank You !!
Aug 25, 2010 | LG WM-1832C Front Load Washer
WM1832CW has stopped spinning. Tries to spin but
If the drum is loose it probably means that the bearings at the rear.....OR...The arms that connect the drum to the pulley shaft have broken.....Major job....Sorry.....Nomess
Apr 18, 2010 | LG WM-1832C Front Load Washer
Washer stop before completely filled with water.
beko washing machine when turn it on it trips
Dec 12, 2009 | Kenmore Washing Machines
Noisy on spin cycle LG WM1832CW
this is joyce
Go to and download your manuel put in your model #
Feb 07, 2009 | LG WM-1832C Front Load Washer
OE message on our LG WM1832CW washer
I just was searching for the same exact error on my LG WM1832CW washer. From reading the other posts on different manufacturers I realized this was a pump clog issue for mine too. There is a small door near the bottom of the front of the washer and if you open that there is a filter basket. Once you start turning it and break the seal, the water will come out quickly, have 2 flat large tupperwares so you can catch the water. Once you clean out that filter it's good to go. A 5 minute job.
Jan 21, 2008 | LG WM0642H Front Load
LG WM-2432H Front Load Washer Logo
74 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
