Roper RES7648E Dryer
Problem for Roper RES7648E Dryer
Roper rex6634pq0 won't start, buzzes, gets hot on surface
By wghamblet on Aug 18, 2009
Roper dryer model rex6634pq0 won't start. Push the start button and it just buzzes. When it first went out, the metal surface was so hot we had to turn it off.
Best Solution
posted on Dec 12, 2009
Very Helpful)
jr68
Rank: Apprentice
Rating: 100%, 2 votes
Solution #1 makes no sense as a dryer does not have a water pump!
But the exact same problem happened to my same model dryer. Pull out from wall. Remove lint filter. Take out two screws holding top to lint filter casing. Pry up top at the front (pops out of two plastic retaining dowels and is hinged on the back so you can tip the top up). Remove front panel by taking out two screw-bolts at top of backside of front panel and lift up -- careful to support drum as you do, as the front part of the drum is supported by the flange built into the front panel. Check:
1) Is belt broken (the incredibly skinny belt that runs around the middle of the drum, not the rubber track at the back of the drum). If belt is broke, replace. New belt at internet parts stores is about $10 bucks.
2) If belt is not broke, get down on belly with flashlight and find the spring-loaded wheel that keeps the belt snug against the motor pulley -- push on the spring-loaded wheel and slip the belt off.
Now try to spin the motor pulley by hand. If it turns freely in both directions, it is probably good and the problem might be in the start switch (don't know how to test that).
If the motor pulley does NOT turn -- or is very hard to turn and binds -- the motor is dead. Probably the bearings burnt out (that's what happened to mine after only 4 years of light use). You have to remove the back panel to replace the motor, but it's a simple job if you know what a screwdriver and socket ratchet are for. New motor at internet parts stores is about $80 bucks.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Aug 18, 2009
Somewhat Helpful)
hektor1961
Rank: Guru
Rating: 87%, 27 votes
If your water pump is free of debrees then it's time to buy a new motor.
Was this helpful?
Yes
No
Popular Solutions for Roper RES7648E Dryer
Questions and Unsolved Problems for Roper RES7648E Dryer
Do you recommend Roper RES7648E Dryer?
Answer
Answer
We did 3 loads of laundry no problem, then when starting the 4th load, the dryer made an errr sound... (More)
Answer
dryer will not turn on. have power
Answer
Greetings, I have a two year old Roper REX6634RQ0 electric dryer that has been working like a charm... (More)
Answer
I replaced the motor and it worked fine through a full cycle. Now when I push the start button it... (More)
Answer
it runs for about 30 seconds and shuts off. I disconnected the vwent and cleaned it but nothing also... (More)
Describe your Dryers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dryer Experts
Top Washer & Dryer Repairmen
in Van Nuys, CA
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
