Question about Haier XQJ100-96 Top Load Washer
Walking Machine The repair person is having difficultly fixing my walking machine. He changed all four shocks or tub suspension (they are at the four corners of the tub that holds it) but the problem still persist. He also level the machine on the floor my adjusting the foot. Can you help? my email address is [email protected]
Why does my LG washing machine make a rattling noise even at low RPMs?
It is not uncommon for items that get loose in the washer (paper clips, coins, etc.) to slip underneath the "paddles" and then make noise as the drum turns. While an annoyance, it is not anything to be overly concerned about. Eventually the item(s) will come back out.
Mar 19, 2015 | LG WM-2277HW Front Load Washer
How do I fix the last few seconds of spin that vibrates off balanced and aloud noise.
All front-load washing machines have shock absorbers that are used to dampen the tub movement in the spin cycle. The shock absorbers or struts are attached to the base frame and to the outer tub and you will need to remove the front panel or the rear panel to access them. When shock absorbers weaken or become damaged, the machine will often make a loud banging sound during the spin cycle and if the symptom is not corrected, can lead to damage of other components. Inspect the shocks for signs of broken attachments, leaked fluids or a weakened dampening action and replace both shocks if worn. Remove power from the appliance before attempting this repair.
Some models of top-load washers use tub dampening straps to cushion the movement of the tub during the spin cycle. There are four straps attached to the top of the tub and to each corner of the cabinet
Also There are four suspension rods that suspend the tub and allow the tub to free float. If the suspension rods are noisy, there will be a squeaking noise during wash. You can fix this by putting bearing (lithium base) grease in the cup that each rod rests in. If it continues to squeal replace all four rods the cups come with the rods, replace them as well.
If your washer has a loud banging noise during spin the balance weight may be loose. This weight is to counter act the weight of the motor so you will find the weight directly behind the motor. Sometimes simply tightening the bolts will fix your issue but if the bolts are stripped out get some bolts slightly longer than the original bolt to allow you to put a locking nut on the bottom side of the mounting plate. If the weight is broken replace it.
Lastly Washer vibration can be caused by a broken counter balance spring. Ur washer may be equipped with one or more counter balance springs which help to absorb the natural movement of the spinning tub. If a counter balance spring fails the tub might lean in one direction more than another and it will shake and cause vibration.
By the way my advice is free cuz God is good!
Sep 23, 2014 | Samsung WF419AAW 4.3 cu. ft. Front Load...
I have a Samsung washer model number wf338aab/xaa my tub is off balance
Sep 17, 2014 | Samsung WF328AAW Front Load Washer
Why is my basket leaning to the side on my easing machine
Sep 06, 2014 | GE Washing Machines
Washer walking all over floor and oil is at base of shock absorber on the plastic mount
If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
For replacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Feb 28, 2013 | Kenmore Washing Machines
My GE washing machine tub is unlevel, It is tilted to the back and right of the machine. The macine itself is level.
Is it "walking" in the spin cycle? If not I wouldn't be concerned, the tub is mounted on suspension so as not to vibrate and run quietly
Mar 06, 2011 | Washing Machines
Good Morning !!! Does the tub move sided to side
Yes, the tub should move freely as you describe. The suspension doesn't rely on guide rails, but rather, on four suspension balls and rods. The unit should not have been moved horizontally because the suspension could be disengaged, but you may be ok. I would just level the machine properly and run a load in it. If the suspension has come apart, you'll definitely know it because the machine will bang loudly and try to "walk" across the floor. If that happens, respond back and I'll try to help you open the machine and fix it.
Good luck.
Feb 19, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Maytag Atlantis top load washer started making a loud noise when on spin cycle.
The tub has its own suspension to avoid having the machine walk away from its position. The chassis normally has four suspension points and when one of these gives way, any imbalance can cause the tub to hit the inside of the cabinet. Removing the back panel of the machine and using a good light, the offending suspension part can be found by having someone rock the tub by hand.
In some machines, this suspension is nothing more than some very thick, round rubber doughnuts and are generally not hard to replace.
Any appliance parts store will be able to supply these.
Nov 09, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Our new front load washing machine "walks"
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
IF THIS IS A BRAND NEW INSTALLATION - be sure you hav removed the basket shipping pins (4) that secure the tub during shipping.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 04, 2009 | Kenmore Washing Machines
Clunking noise and vibration during final spin cycle
For all those who say they recently bought the machine, the cause of the machine "walking across the floor" and vibrating violently is the packaging bolts on the back of the machine that were supposed to be removed when the machine was installed (why it says remove packaging bolts in the installation manual). These packaging bolts hold the suspension steady and firm during shipping but MUST be removed before operating the machine. When these packaging bolts (I think there are four total, some up to 6 inches long penetrate the rear of the machine) are removed, they allow the suspesion to absorb the vibration.
Feb 02, 2008 | Frigidaire ATF6000ES Front Load Washer
Haier XQJ100-96 Top Load Washer Logo
46 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Marvin
Marvin
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
