Question about Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41)
Help on Port Forwardsing?
I have a linkys BEFSR41 Vers 4 and have a set up called Echolink thats uses port 5198 and 5199 and that has to be set up for port forwearding ..How do i set it up...
  • 83 Answers
Goto your ip adress (Type it in adress bar) Your ip adress is located from www.ip-adress.com type it in, A pop up should come up "ACCOUNT" And "PASSWORD" the info should be
Account: admin
Password: admin
Or
Account: admin
Password: password
Or
Account: admin
Password: (leave blank)
then, goto "Applications and gaming" click Port Range Forwarding
Should pop up, goto Application space, name it anything (ex. echolink) From 5198 to 5199 Then select Both and for the last part you have to find it from
Start> Run> Type "Command" Then hit enter
Should pop up, just hit "Enter" and alot of stuff should come up.
Like this:
Where it says IP Address... 192.168.1.2 (Will be different for you)
That is where you put it on the last blank from your portforwarding!!
Hope I helped
Posted on Dec 01, 2007
  • Matt Perry
    Matt Perry Dec 01, 2007
    Sorry!! Type cmd not command
  • Matt Perry
    Crap- Sorry for messing up again, after you type cmd type ipconfig /all
I am having trouble with Port Forwarding for the Westell 327W Wireless Router.
Hello Michael Yancy,
Seems to be a bit dated... but the AMATEURS that have these ... like them.
Those trying to set them up... Not-so-much
see the videos at:
How to set up your Echolink Port Configuration
Port Forwarding For Noobs Linksys Routers
eHAM.net has the best forum (important)
http://www.eham.net/ehamforum/smf/index.php?topic=76200.5;wap2
May 20, 2017 | Westell Wirespeed VersaLink...
I have a WRT54G router and want to daisy chain a Linksys BEFSR41 switch off it, but I seem to be doing it wrong...
Not sure if you just want to expand the amont of computer you can connect to it or the wireless range but I would setup the BEFSR41:
  • Disable DHCP
  • Set an address out of the DHCP scope of the WRT54G
  • Connect them LAN to LAN if not use xover to connect them
Aug 27, 2010 | Linksys Wireless-G WRT54G Router
On my echolink progtam it says to use port 5198 or 5199, how do I do it?
access your router with following link.
http://192.168.1.1
or
http://192.168.0.1
For belkin router http://192.168.15.1
type user nams as "admin" and password as "admin" or blank or "password"
Then go to NAT and prot forwarding .
Select your port and open TCP and UDP protocol.
Then save settings and restart router.
Let me know if you need more assistanse.
Thanks.
then go to NAT
Aug 31, 2009 | Computers & Internet
When I turn on my BEFSR41 the POWER and PORT #4 lights up even though nothing is connected to it yet... what seems to be the problem?... is it defective?
If you are using the Uplink port, this may cause port 4 to show active. Disconnect the Uplink cable to see if the light goes out. If it doesn't, then yes, it sounds like you may have a bad port on your router.
Aug 30, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
I can no longer connect to Echolink
How to set up the ports for Echolink:
  1. Go to this page (link).
  2. Choose the correct router model (if you don't find it, use a model similar to yours. The setup for all Westell routers is almost the same.)
  3. skip the advertisement on the next page (upper right corner)
  4. choose "Echolink" from the list.
  5. Simply follow the instructions.
  6. Voila!
In general:
  1. Important!! (and most often the reason why it is not working): Make sure that yourWindows Firewall is not blocking the application (see Control Panel-> Windows Firewall -> Exceptions) (details also here).
  2. You have to allow UDP destination ports 5198-5199 between Internet andPC in both directions and allow TCP (source port any, destination port5200) from PC to Internet.
If you have any more questions, just come back and leave a comment - I am happy to help.
Thanks for rating!
Mar 24, 2009 | Westell Wirespeed VersaLink...
How to set UDP & TCP port for Echolink
First I assume that you simply posted this under "Linksys > WRT" by mistake and you are using a D-Link router.
  2. Choose the correct router model (almost at the end of the page)
  6. Voila!
In general: Make sure that your Windows Firewall is not blocking the application (see Control Panel -> Windows Firewall -> Exceptions) (details also here). You have to allow UDP destination ports 5198-5199 between Internet and PC in both directions and allow TCP (source port any, destination port 5200) from PC to Internet.
If you have any more questions, just come back and leave a comment - I am happy to help!
Mar 21, 2009 | Linksys Wireless-G WRT54GS Router...
Opening Port 123 on my Linksys BEFSR41 Router
Hi:
It turns out I didn't need to open port 123 on my router to get SymmTime to work.
Thanks for the efforts
Brad McMillan
Dec 16, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
OPENING NAT FROM STRICT TO OPEN
Sory to say this .....1 find a tech who knows networking... or.. call Linkys support to help with reset/setup...My final solution.... buy a different router... I've had trouble With Linksys before.
Mar 15, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Lost internet connection
Power off the router by unplugging it. Also power off the DSL or cable router. Shut down the PC. Located on the back side of the router is a small reset button. Using a pen press and hold for ten seconds. Same for the DSL or cable. Power every thing back up starting with the DSL/cable, than the router and lastly the PC.
Dec 16, 2007 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Accessing echolink nodes
Please go to the following website and check the port numbers that you have forwarded. Some wireless routers do have issues forwarding ports. http://www.t1shopper.com/tools/port-scanner/ Also, before you use this tool, make sure ICMP is not blocked in the router's settings; if it is blocked all ports would show blocked. Try this and let me know the results. Cheers
May 14, 2007 | Cnet CWR-500 Wireless Router
Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41) Logo
189 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
