Question about Optoma EzPro 739 Multimedia Projector
No Picture My projector tries to power on but the lamp does not power on,, I did replace old lamp with new No Luck. It had sit for 7 month with no use
Hi There
I had the same problem, and the solution is very simple,. When you remove the cover ( 2 screws) to replace the lamp, then there will be a piece on this cover a bit stiking out. this piece is made to push a small metallic piece to make contact, and then to let electricity pass. so if you try to put a screw driver in this hall, you will feel that there is a contact and then your beamer will go on.
so this security contact is nor operating properly and you need to push it permanently so it will work. I hope my you can understand my english
Posted on Dec 27, 2007
SOURCE:
Projector
What is the model number?
Nov 23, 2013 | Optoma Office Equipment & Supplies
Hello! I have a DELL 1209S that the picture is wavering. Is it spring?! Some vertical lines almost invisible in the background are also perceived. What can it be?
follow this steps and fix it. God bless you
  • Secure the lamp cover and the air filter cover of the projector body if the projector does not power on. Ensure that the power cable is firmly connected to the projector and an active power plug. If the projector was turned off and then on quickly--let it sit for 90 seconds before trying to turn it on.
  • 2
    Replace the projection lamp if the projector will not power on or if the lamp indicator is flashing. Turn off the projector and let it sit for at least 30 minutes. Locate the lamp cover and remove or loosen the lamp cover with a screwdriver. Carefully remove the projection lamp from the projector housing using the handle, if available.
  • 3
    Place the new projection lamp into the projector housing and secure it to the projector. Replace the lamp cover and reset the lamp timer. Power on the projector to ensure the new lamp is working correctly.
  • 4
    Remove the projector from the enclosed area to allow air circulation if it constantly overheats. Place the projector into an open area and make sure there is no blockage for the ventilation holes. Unplug the projector for at least 45 minutes to allow it to soft reset.
  • 5
    Clean the air filter to allow the projector better air circulation. Turn off the projector and unplug it from the outlet. Remove the air filter cover and use a vacuum to remove dust from the area. If the filter is unable to be cleaned correctly or is damaged, then replace it. Pull the air filter from the projector and place the new one in the now empty slot. Close and secure the air filter cover.
Oct 29, 2013 | Dell 1209S DLP Projector
Red warning light
  • 2
  • 3
  • 4
  • 5
Oct 29, 2013 | Sanyo PLCXU355 LCD Projector
Turn off on screen message
  • 2
  • 3
  • 4
  • 5
Oct 28, 2013 | Dell 4310WX Projector
Red lamp/ orange/lamp After a "break" of about
test this steps and fix it. God bless you
  • 2
  • 3
  • 4
  • 5
Oct 28, 2013 | BenQ PB6110 Multimedia Projector
No light
Hello!
Have you notice overall condition of the lamp compartment? If it was burned or molten, there is a chance that new lamp is not sitting properly and has no contact with HV plug. If there is no visible damage and old lamp was looking good, the ballast is to blame. It's usually buried deep inside of projector and must be serviced or replaced by qualified personnel only.
good luck,
thanks,
Alex.
Dec 22, 2011 | Panasonic PT L735U Multimedia Projector
The projector would not turn on and had a flashing red light for the lamp. Knowing it was an older projector when we rented the building I purchased a new bulb for this projector. When I put the new bulb...
PROBLEM :-The power supply of the projector is faulty there is a transistor witch is switch 15 volts for the lamp drive board.
SOLUTION: Remove the upper cover with 6 screws back side of the projector.
remove main board and lamp cover with 7 screws.(show in the picture)
remove upper cover of the power supply and lamp drive unit with 3 screws.
remove power supply unit with 4 screws and 3 connectors and put face down on the table.
now you find the transistor no Q107 and replace with the transistor no 2SB710 is and surface mounted compunent(show in the picture)
fix it all as you open.
power ON the projector and enjoy
(doing very carefully This is a technical job)
Feb 05, 2011 | Panasonic PT-LB10SVU Multimedia Projector
I have an Infocus 5000 projector that we have just tried to replace our 2nd brand new lamp. Each time we attempt to replace the lamp we get no picture and the red light blinks once so often. At first when...
be sure and reset the lamp hrs. But you really need to make sure you haven't pushed the lamp connection in the lamp housing out of its cubby hole. I've seen this alot, the connection gets pushed in and when you think you have the lamp in, it's not really connected. Really the only way to check this is to remove the top cover. Before you do this though, one other thing that can happen is the lamp door gets mishapen due to the heat from the lamp and can cause the thing that pushes against the safety switch when the door is on not to depress it fully. you can power the unit up while holding the switch in with something non conductive to see if it is in fact the lamp door. anything beyond this is likely the power supply/ballast being defective, or the blower fan in the right rear of the unit not working.
May 21, 2010 | InFocus ScreenPlay 5000 Multimedia...
New lamp turns on flashes 7 times
Just a thought...you *might* have a bad ballast in addition to that defective power supply.That flashing could be the ballast trying to ignite the lamp. A lamp is just like an enclosed welder's arc. The ballast generates a high-voltage spark to initially start the lamp, then low voltage with high current keeps it burning. If you look into the lens and see "lightning" flashes but no lamp ignition, that's what's happening. The ballast could've been damaged by the defective supply. Also, try a known-good lamp...just to rule out a defective new one--in the shop, we kept all old working lamps as testers.
Aug 30, 2009 | Sony XL-2100U Projector Lamp for...
My picture brightness is uneven - there is a persistant bright field on my screen.
I have the exact same problem with my AE700. It a started about the same time, around 2500 hours for me. I lived with it untill I could afford a new bulb which arrived yesterday. The old bulb was still working at a 3603 hours when I installed the new one. But the new bulb didn't fix the problem for me either. I may try to take it apart this weekend and give it a good cleaning. Andy
Jan 07, 2007 | Panasonic PT-AE700U Multimedia Projector
Open Questions:
Optoma EzPro 739 Multimedia Projector Logo
108 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
