Hi, Even though your igniter is glowing it's bad..A igniter should glow brillient yellow for it to be able to light the gas...basically whats happening in your case is although the igniter is drawing the correct amps to open the gas valve it is not getting hot enough quick enough to light it..change the igniter and you should be good to go. Good Luck!!! Mike
You have a weak ignitor and should replace it.
Ignitor
Not difficult to change, when the ignitor become weak this can happen. Just because it glow doesn't mean its good, it still can be weak to ignite the gas.
Good Luck
could be a problem with the ignitor. take the racks out of the oven. remove bottom panel in oven. remove metal plate covering the flame spreader. the ignitor should now be visible. turn the oven on. the ignitor should begin to glow. if it doesn't glow bright white, or bright glow, ignitor is bad and needs to be changed.
If you see the ignitor glowing down there that means power is getting to the oven circuit. You have a weak ignitor if that is the case. Sometimes you can bump it and make it work. Check out this video
The oven uses a silicone carbide ignitor which requires 3.6 amps or better to open the gas safety valve. If you don't see any glow from it then it is either blown or the gas valve has gone bad. If it is glowing but not real bright it probably is weak. How it works: Silicone Carbide Ignition XL44 gas stove manual
The problem usually is the ignitor. Even if it glows it may not be pulling enough current to open the gas valve. They also are very fragile and break easily.
This tip will help you also.
Hi, It very well could be the ignitor. Sometimes they work at first and then will not open the gas valve later in cycle. You can set the oven to heat and watch the ignitor. If it glows and the gas will not ignite in 30 to 45 seconds, the igniter is getting weak. I jope this helps.
Please let me know if I can assit you further.
The most common failure for a nobake on this type of oven is the bake ignitor. turn unit on and look at the bottom of the oven, you should after about 30-45 seconds see an ORANGE glow, if you do not, chances are you have a failed ignitor.Remove lower part of oven and if you have a meter, place one lead on each terminal and check for continuity( a closed circuit) If you have an "open" circuit, the ignitor is bad
The reason you can't smell it when the oven is on is because the gas is being ignited. DO NOT USE YOUR STOVE until you get this fixed by a gas fitter. You have a gas leak, which is either a loose fitting or faulty valve or line.
Call your appliance dealer IMMEDIATELY or you could have an explosion!!!!
