Question about Dacor DMT2420 1200 Watts Microwave Oven
Heats but tray does not rotate...
My dacor microwave works well but the tray does not rotate. There doesn't seem to be a switch to turn off the turntable....can this be easyily fixed?
  • Anonymous Feb 13, 2009
    MICROWAVE TURNTABLE DOES NOT ROTATE
  • Dacor Master
  • 9,098 Answers
This one does not have a turntable shutoff option, which is available most commonly on over the range models.
You likely have a bad turntable motor or turntable support (the 3-legged part with rollers).
If yours is a Dacor DMT2420, it is essentially a rebranded Sharp model R440DK/DW / R540DK/DW.
There was an issue with the original turntable motor on these Sharps.
The new Sharp turntable motor kit is part # RMOTDA264/KIT and they are available from Tritronics at http://www.wehaveparts.com
I cannot guarantee that this is the correct Sharp part for this Dacor, but I believe it is, based on the other parts being the same.
Another thing to be sure of is that your turntable support does not have a cracked coupler (the part that connects to the motor) and you need to be sure the legs are straight.
Sometimes heat and weight cause the legs to bend so that the coupler will no longer go down far enough to make contact with the motor shaft.
To fix these, I use a gas stove burner or torch to heat up the area where the legs connect to the hub, then I turn it upside down with a weight on the hub / coupler and leave it until it cools.
This straightens the legs back, and you can do this once or twice before you have to replace the support. But if the support is cracked or charred, it needs to be replaced.
The Sharp turntable support part number is FROLPB025MRK0 and it's also available from Tritronics.
If you don't want to take the chance, the Dacor part numbers are:
66245 motor Ref # 1-11
66184 support Ref # 6-3
But it will depend on your supplier as to whether these are original parts prone to failure or the new and improved parts.
You can order the Dacor parts from sources listed here:
http://ww1.dacor.com/findus/PartsDistr.asp
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 02, 2007
Dacor DCM24S microwave not working--not heating and table not rotating
The bottom door switch or its mount is bad.
See the service manual here and a help file on door switches here.
Nov 23, 2012 | Dacor Microwave Ovens
I tried cooking with the convection function in my dacor DCM24 microwave. now the microwave function will not work. the fan comes on, but the turntable doesn't move and there is no heat.
This is almost certainly a bad secondary interlock (bottom door switch) or its mount.
See my help file on door switches here.
You can download the service manual and parts list free from our site.
You can order parts by entering the Dacor part number here.
Oct 28, 2011 | Dacor DCM24 Convection/Microwave Oven
Microwave panel is on, timer works, but no turning or heating. unit is 3 years old
Bottom door switch or mount.
See this file, and the DMT2420 manuals here and here.
You can order Dacor parts by part number from the Pros here.
Aug 14, 2011 | Dacor DMT2420SS Microwave Oven
All the controls work and seems to be working with tray rotating but makes noise and does not cook
Having noise means some obstruction near the rotating tray or its motor need some lubricant. Has for no cook but control seems working, the magnetron and its fuses is the culprit because it doesn't anymore produce heat to cook food.
I hope that advice help you.
Mar 31, 2011 | KitchenAid KEMC377K Convection / Microwave...
Turntable will not rotate.
If it's also not heating, on the DMT2420, that's a bad bottom door switch, or possibly that switch's mount.
Otherwise, it may be a bad turntable motor, turntable coupler, or the control circuit board (which we repair).
The service manual is here and the parts list is here.
Feb 17, 2011 | Dacor DMT2420 1200 Watts Microwave Oven
Turntable not turning
you should be able to repair this your self the turntable motor is fairly easy to get to.it does sound as though your motor has gone bad.
Jan 31, 2010 | Dacor DCM24 Convection/Microwave Oven
Dacor Microwave PCOR3OS will not heat/tunrtable not turning
This Dacor model is very similar to Sharp model R1874.
We have the applicable service manuals for these models and have uploaded it to our site here and here to help you.
You will need the
free Adobe Reader to view or print them.
This is probably a bad secondary interlock (lower door switch) or possibly its mount is loose or broken.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you only need a switch, you can order a universal type here for $5 postpaid.
Dec 16, 2008 | Dacor PCOR30SS Microwave Oven
Dacor dcm24s.light, fan, and control panel work but turntable and heat do not
Most likely the bottom door switch. Dacor units are built by Sharp and that switch is a very common problem. You'd either need to check the switch with an ohm meter or remove the cover of the switch to see if it's burned inside.
Oct 20, 2008 | Sharp R-930AK Convection/Microwave Oven
Dacor dcm24 microwave
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven. You may have to cut the cover off with snips, then use a screw when reassembling it.
Here are those part numbers:
66388 Turntable motor
66489 Turntable coupling
You can order either of there here.
Jun 08, 2008 | Dacor DCM24 Convection/Microwave Oven
Dacor Microwave dcm24s
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
This can be caused by slamming the door or by habitually opening the door while it's cooking without hitting the Stop pad first.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Feb 14, 2008 | Dacor DCM24SS Convection Microwave Oven
Dacor DMT2420 1200 Watts Microwave Oven Logo
322 people viewed this question
Top Dacor Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Steven Clarke
Steven Clarke
Are you a Dacor Microwave Oven Expert? Answer questions, earn points and help others
