Denon DRA325R Bad Reception
My Denon DRA325R receiver has served me well since 1990. A couple years ago, the tuner lost its ability to pick up all but one or two FM channels. The EURAS site references a "continuous swith over MONO/STEREO. Resembles bad reception." problem, but I don't think that is the problem my receiver has.... Any thoughts on what it might take to fix it are highly appreciated. Thanks.
  • ppetrusek Aug 23, 2008
    I get perfect AM but no FM chanels
SOURCE:
techman
  • 3130 Answers
SOURCE: No radio
The front end is bad on this reicever. Your going to need special equipment to trouble shoot this problem, as Its all RF. It is most likly not worth repairing as a shop will most likly charge you more then its worth
Posted on Sep 16, 2006
bernardlunda
  • 318 Answers
SOURCE: Manual required. FM reception is not sounding like stereo.
get connected to
www.audiokarma.org/forums/archive/index.php/t-83626.html-20k for your manual
Posted on Apr 27, 2009
SOURCE: NO FM Reception, on JVC DR-E53L HI-FI
sorry I can't help with this but I want to ask you for favour if you have manual for that model u could help me a lot
Posted on Apr 07, 2010
  • 87 Answers
SOURCE: My AM radio reception does not work. I have a loop
You should buy an antenna amplifier. Here are some that work in-line and are designed specifically for AM radio:
http://www.google.com/products?q=AM+antenna+amplifier&oe=utf-8&rls=org.mozilla:en-US:official&client=firefox-a&um=1&ie=UTF-8&ei=sVRBTKGhD47msQOvpNCYDQ&sa=X&oi=product_result_group&ct=title&resnum=1&ved=0CDEQrQQwAA
Posted on Jul 17, 2010
pgh_pa_guy
  • 2992 Answers
SOURCE: FM antenna is not providing
If I understand your setup, you've connected the receiver antenna terminal to the output of the antenna amplifier. If this is true, I'd suggest trying the receiver using a plain old FM dipole antenna (available at Radio Shack and other stores) or even just a piece of wire hooked to the antenna terminal. You should be able to pick up some local FM stations then.
What might be happening is that the FM is being filtered out by the amplifier. Some amps made mainly as a TV signal booster have an FM trap designed to block the FM broadcast band. In the analog broadcast days, the FM band was right near the sound part of a TV signal, and the trap was there to prevent interference. It may be filtering out your FM band.It may also be possible that you're just overloading the FM antenna input with the amplified signal. Sometimes a signal can be too strong. Using a simple wire antenna will let you test the receiver by itself.
Other than connecting an antenna you shouldn't have to do any setup for FM reception. If you still get no stations at all when using a simple antenna, then the receiver may need service. But I doubt Circuit City would have sold a floor model that was defective, even at the very end, unless it was clearly marked as such and sold "as-is". I'm pretty sure you'll find that the receiver works with an antenna made for FM.
Posted on Sep 14, 2011
Have Denon AVR-2313ci receiver. FM tuner quit working; will tune in 50 MHz steps, on every step "stereo" and "tuned" are lit but no sound comes out whether actual station or not.
There is no module per se. Tuning is accomplished by applying a voltage to the tuner chip and their associated circuits. It needs to be repaired by a Denon service center.
Oct 25, 2016 | Denon AVR2313 7.2 Channel A/V Receiver
Why can't I get a tuner signal on my Denon Receiver?
make sure your antenna is hooked up properly, with even a bad antenna you should be able to pick up some stations
Mar 02, 2013 | Audio Players & Recorders
My radio reception is intermittent
Check your antenna and antenna cable. Many devices has switching power supplies with can interfere with the receiver like a computer, laptop, dect home phone, printers, fax etc. Also could be something outside like rf tower. you may try other receiver/fm tuner to see if it has the same recption problems. If you find that your receiver is no good you need to replace internal FM tuner.
Dec 08, 2011 | Denon Audio Players & Recorders
My denon DRA-295 does not remember stations I set to memory when completely turned off. If on standby all goes well. A month after the problem mentioned above the tuner started to modulate reception and...
My better guess is a CMOS chip is either bad or there is a cold solder connection in the vicinity. If the power supply is bad, the receiver would not power up.
Nov 23, 2010 | Denon DRA-295 2 Channels Receiver
Tuner not working.
These do on occasion have a bad fm tuner assembly. part number 9630145608. to verify try a fm ant to see if works
Dec 09, 2009 | Denon AVR-1908
Not getting all channels on brandnew flatscreen TV LG 42PQ1000.
Yes the incoming signal can overload the tuner
Aug 01, 2017 | Televison & Video
Denon AVR 1705-no audio on TV
I have had the same problem and was told that it is a "board" inside. Essentially it has lost the surround sound ability and can only play things in Direct/Stereo. Mine is just over 2 years and I originally thought my kids had hit a button on the thing causing the issue...ended up paying $100 to trouble shoot it and confirm that it is internal and more expensive to fix than replace. Can't say that I will be buying a Denon again.
Jul 09, 2008 | Denon AVR-1705 Receiver
Tuner error
Use a multimeter to check for connectivity to the sirius. Where did you mount the antenna? Maybe its a reception problem? Sounds like the head unit is going bad. Try shutting it down, and take the pace plate off, let it reboot and see if it works. Check to see if the Tuner is unplugged.
Nov 16, 2007 | Kenwood Sirius KDC-MP225 CD Player
Reset channels??
http://www.eserviceinfo.com/download.php?fileid=26004
http://www.eserviceinfo.com/download.php?fileid=26005
Here are the links for the manual. I've lost my remote as well. I can't get my unit to recognize the digital audio input (optical). Very frusturating.
Apr 28, 2007 | Denon AVR-2700 Receiver
506 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
