Mach Speed Trio Clip  MP3 Player Logo
Posted on Aug 17, 2009
How do I charge a TrioClip MP3 Player?
Do I just take the USB Cable and Plug it into the computer until it's finished charging???
  • shadowut0625 Aug 17, 2009
    Wait, nevermind. I solved it.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Oct 02, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
192
Points
When charging, you have to leave it on, or it will look like it's charging but will not actually charge.
Anonymous
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Sep 29, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
Helped
634
Points
13
You just attach the USB cable to the MP3 and leave it in the computer until it's done. It should not become weaker if you charge it often, as it does have a Lithium Polymer battery.
How to charge a cativa AT-MP420 portable Media Player
Ti charge the MP3 player, connect the supplied USB cable to the player and then plug the other end of the USB cable into the USB port of your computer.
OR
Purchase a 5 volt mains USB power adapter and plug the USB cable from your player into the USB port on the power adapter.
1helpful
How do you charge the battery?
MP3 players are usually charged using the supplied USB cable. Connect the USB cable to the MP3 player and then plug the other end of the USB cable into the USB port of a working computer.
How do u charge the mp3 player?
The MP3 player is charged using the supplied USB cable. Connect the cable to the MP3 player and then plug it into the USB port of a powered up computer/laptop.
6helpful
2answers
I bought a Swagger 2gb MP3 Audio player, and it went dead. I didnt get a charger and I lost my instruction paper, how do you charge it?! Please help, Alicia.(:
Plug the USB cable they provided to a PC and hook the other end to the mp3 player. It takes about 4 hours to fully charge.
How do i charge my mp3 player/sandisk sansa m240
Connect the USB cable to the MP3 player then power up a computer and plug this MP3 and cable into the computer's USB port.
You can also charge it by purchasing a 5V USB power adapter and plugging the MP3 player and cable into this adapter.
1helpful
How do i charge my sansa mp3?
  • Step 1:Plug the appropriate end of the USB link cable that came with your SanDisk MP3 player into the MP3 player itself. The port for this cable can be found on the right side of most models of SanDisk MP3 players.
  • Step 2:Plug the other end of the USB link cable into a free USB port on your computer. This will effectively connect your SanDisk MP3 player to your computer.
  • Step 3:Turn your computer on. This will cause your SanDisk MP3 player to automatically begin drawing power from the computer and charging its battery. On the screen, an indicator light will flash yellow while the player is charging.
  • Step 4:Disconnect the cable from both your MP3 player and your computer when the device has finished charging. You will be able to tell when the charge is complete when the indicator light that previously was flashing yellow appears as solid green.
  • 0helpful
    My trioclip mp3 player wont charge
    Yeap i had the same problem that you do. Try to turn on your device and plug it in to the USB. Leave it for 5 minutes then unplug the device from the USB. It should work. ayt, peace!
    1helpful
    3answers
    Wont charge
    put it in the hold position, hold the center button while you plug it into the cpu, keep holding untill it is recognized by your cpu. about 5 or 6 seconds
    Trouble charging
    1. Plug in usb cable to computer.
    2. Plug other end of cable into MP3 player.
    3. Turn MP3 player on using the power slide switch. The display should change slightly to indicate charging. (Mine has a picture of a battery that will fill and empty...) Hope this helps!
    2helpful
    3answers
    Charging
    If it just has a usb cable for charging then yes you would. The charging time varies but it generally shouldn't take longer than 3 hours to fully charge. Check your manual if you have one, it will give you more information.
    Top Mach Speed Audio Players & Recorders Experts
    ZJ Limited
    ZJ Limited
    Steve Pack
    Steve Pack
    Are you a Mach Speed Audio Player and Recorder Expert? Answer questions, earn points and help others
