Question about Panasonic DMR-EH65 DVD Recorder/HDD Recorder
DVD/VCR Troubleshooting I set up my DVD/VCR correctly and all that will show is a blue screen. I don't think any of the cables are in the wrong places... I have a Toshiba TV and use DirecTV so I have a satillite box.
  • killgowie Apr 02, 2008
    cannot see or enter the menu ever since i went and used the (tv resolution)
    from 480p to 480i the screen whent blue and i cant go back to change annything when i use the other remote (tv) and shuttle through the input selector i get a distorted glimps of the dvd but that's it nothing els
    The dvd remote seems to run fine i can open close stop start but no menu
  • 85 Answers
Your cable ground has a poor ground
Posted on Sep 22, 2008
Will not Power Up
Posted on Jan 17, 2008
  • hani-d Jan 17, 2008
    will not power up Problem - Sharp DV-NC100 DVD Player / VCR Combo
SOURCE:
How do i get vcr to work with tv
The connection would be ideally a SCART cable or a phono AV cable ( red, white, yellow) which are you using? Then turn on TV, then turn on VHS, if the VHS does not show on screen, press the AV/Mode button on remote until VHS on screen!
Dec 15, 2014 | Disney Princess TV/DVD Combo
I can not accrss either a VCR tape or a DVD.
Is the TV saying no signal? Are you on the correct input? Is it SCART or composite? Are you getting sound? If no sound then it might be on the wrong input on the TV
Dec 14, 2011 | Philips Televison & Video
No picture
have you connected up correctly, have you selected correct EXTERNAL inputs, you do NOT "tune" a Channel to see picture, you choose external AV input on set. Must connect color to color. 3 for Composite Video AV.Yellow, Video, Red & White Audio. and 5 cables for Component 3 for Video , & 2 for Audio Blue, Green, Red, Also Red & White, Audio.
AV
Mar 18, 2010 | Panasonic DMR-ES10 DVD Recorder
Sansui DVD/VCR remote control issue, VCR works/DVD does not-black
There should be a DVD/VCR button on the remote control which will toggle the machine from one playback source to another. If she has pressed the VCR button then the machine will only playback tapes & not show DVD's. Press this button & the DVD's should play. If you look closely at the front window of the machine it will show what mode it is in ie VCR or DVD, set this for the DVD to get it to play.
Sep 16, 2009 | Sansui VRDVD4000 DVD Player/VCR
I only have cable tv. when i connect my magna avox
This unit does not have a tuner to receive TV broadcasting. If you have the owners manual on page 26 it explains this. If you do not have the manual here is a link to one.
http://www.magnavox.com/pdf/mn/DV220MW9_mn.pdf
Sep 05, 2009 | Philips Televison & Video
Sharp Aquos LC-37D44U only shows B&W images from DVD & VHS source
First thing- why not just use the HDMI instead of standard def cables in the first place? Anyway- If the RCA-video (yellow composite cable) is not producing color, 1 of 2 things may be wrong: 1. You accidentally connected the a/v cables [yellow white and red] to [red green and blue] component inputs or vice versa, or.. 2. Your TV or DVD player is somehow set to the wrong video format. Check the DVD settings for video output format and video connector type. Format should be NTSC, and connector should be composite and/or s-video for the cables you're using.
If this is only happening when connecting the DVD player through the VCR, then check to make sure the same cables connecting the DVD player to the the VCR are also connected to the TV from the VCR.
BTW- if this is just to record DVDs to a VCR, I'll tell you it's not worth it. If your DVD player has an HDMI port, your picture quality will be so much better than if you're watching a VCR copy of one. Your new HDTV will look worse than an old standard def TV. Worse; I'm not kidding.
I hope some of this helps.
Jun 01, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Samsung 15" ltn1535
Hey mcca,
In many cases, blue screens on TV's can be the result of the TV being in the wrong video mode or another device (like an attached VCR) being on the wrong station.
First, I would suggest testing to make sure that your TV is in the correct video mode and station. Depending on how many devices are directly connected you to your TV, you may need to cycle through one or two video mode settings using your remote control before the DVD menu can be displayed. Typically this can be done by pressing the "Menu" or "Input" button on most remote controls, but you may wish to refer to your owner's manual for instructions how to do so with your specific model TV. In some cases, the primary video input station is even set to channel 3 or 4 by default.
If you are sure that the TV is on the right input setting (and your DVD player is connected to a VCR), I would next suggest making sure that your VCR is on the right channel. Many VCR's will also require that the channel be set on 3 or 4 in order to display any images being sent through them by a secondary device, like a DVD player or video game console. Additionally, it may even be necessary to change the input setting from "TV" to "VCR" to display signals from an attached device. Again, you would need to refer to your owner's manual documentation for specific instructions.
Lastly, if you use an RF modulator or video signal switch for any devices in your home theater, you may want to make sure that they are on the correct settings.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
May 28, 2008 | Samsung LTN1535 15 in. HD-Ready LCD...
Connecting dvd/vcr combo with tv and digital cable box.
You trying to put the DVD/VCR combo between the cable box and the TV? OK, cable out goes to vcr in, vcr out goes to tv, I think you got that. Now there should be a tv/vcr button on the vcr/dvd, you need to press that when the unit is on. Also, make sure you are on the correct input on both the vcr and the tv, usually video 1 or AUX and choose line in or L1 on the vcr/dvd. If the tv/vcr button is toggled, itll completely bypass the vcr/dvd player.
Mar 03, 2008 | Toshiba 32A41 32" TV
Panasonic DMR-EH65 DVD Recorder/HDD Recorder Logo
129 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
