I have a GoVideo Model DV2150. I'll turn to channel 3 to set-up a timed recording. Later, when the vcr turns on (at the appropriate time) it scrambles the station that I'm currently watching and when I turn to channel 3, it becomes the station that I had set to record. I haven't been able to set-up a timed recording in months because of this problem.
Comments:
Aug 17, 2009
- I have never touched the original wiring in the back of the machine. The recording aspect used to work fine, now it doesn't. If you don't have any other solution, then I guess I'd appreciate the diagram info. Thanks!
There is a solution to your problem.
If you have video inputs on the back of your set you can split the antenna signal to both the GoVideo and then to the TV. Then hook up the GoVideo to input one on the back of your set.
This will allow you to record one chanel and watch another.
Then switch to video 1 to watch your GoVideo tapes or use as a tuner.
I hope this helps.
If you need further information I can send you some hook up diagrams.
Thanks
asnowman
DVR4000 - I have an outside source video line in and SVideo out. No outside video plays on Line 1 or...
(More)
DVR4000 - I have an outside source video line in and SVideo out. No outside video plays on Line 1 or Line 2 or on any channel.
How do I finalize my DVD. Can I e-insert it and finalize so that I can play it in other DVD machines...
(More)
How do I finalize my DVD. Can I e-insert it and finalize so that I can play it in other DVD machines ?
I've had this thing forever, always used HP Plus R DVD's. Bought some gold DVD's for archiving,...
(More)
I've had this thing forever, always used HP Plus R DVD's. Bought some gold DVD's for archiving, they're Neg. R's at $2 ea. I don't want to screw them up by trying to record on them, if the machine doesn't record on Neg R's. Can't find the manual! (VR2940)
