Back to:
Tags:
Networking Hubs and Switches
Generic problem for all Networking Hubs and Switches
Internet Problems
posted by Dannyboy1234 on Dec 01, 2007
Hi , Im Daniel Aged 10. I Love Computers And Networking!
We have 5 computers and one laptop. 4 of the computers are not in use.
I have one Efficent Networks Model: 5861 Router and a HP 10Base-T Model: J3202A Hub.
Whenever my sister uses the computer and downloads and / or plays the radio from the internet ect... it slows my connection to the internet down completley!
When she stops using it it carries on being EXTREMELY SLOW!
Is there any cure to stop the slowness when my sister is downloading or when she has stopped it will stop being EXTREMELY SLOW?
Any help would be very appreiciated.
Daniel.
Comment by Dannyboy1234, posted on Dec 04, 2007
Thanks , Ill Try That.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Mar 28, 2008
Helpful (85)
edhall
Rank:Guide Guide
Rating: 91%, 7 votes
Hi Danny,
The easiest way to help your speed issue is to replace your hub with a small, inexpensive switch. Your speed will still slow down somewhat when the downloading is occuring but you may not experience the same amount.
Hope this helps..
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Internet Problems:
I don't want to Accept this solution
Solution #2
posted on Dec 01, 2007
Thanks for Trying (70)
thineking
Rank:Wiz Wiz
Rating: 88%, 58 votes
Hi danny! It is obvious that when u r downloading the comp will be slow because most of the bandwidth is used for the download process..however u can empty the browser cache to make ur system run faster after listening to radio..Mozilla firefox has got the simplest procedure for this..I advise that u install it(its free!).then go to tools menu-> choose clear private data-> select only cache.. Thats all..Your cache will be free and your internet will be back to normal speed..
Regards,
VJ.
Rating Locked! (?) Dannyboy1234 has rated this solution as Thanks for Trying
Thank You!
Can you Help with these Networking Hubs and Switches problems?
Clarinet Systems Clarinet EthIR STAR 1000...
who invented the combination on the flute, clarinet,...
Leviton (2210I)
Using leviton media box. Got linksys connected to the top...
Linksys (NH1005) 5x10/100 Mbps Networking...
just purchased a home cameras for outside and trying to...
Entrega (HUB-7U) Networking Hub
I had to re-install windows XP on my HP multi Media 1170n....
NetGear FE108 8-Port Ethernet Hub...
I have moved our office and can't get the Ethernet Hub to...
Loading problems.
Repair Service
Find Networking Hub and. Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
