Question about Garmin StreetPilot C330 GPS Receiver
Locked screen My Street Pilot C330 is locked on and the power button does not turn it off. Also, the screen is stuck with only "Back/ShowMap/Arrrow up/Arrow down
  • 2 more comments
  • len7604 Dec 08, 2007
    my garminnn330 gps will not turn off.
    leonardklein@hotmail.com
  • pludwig Dec 09, 2007
    i was updating my garmin streetpilot 330c and it locked up on the loading screen. power button does not work. froze. please help
    preston_ludwig@yahoo.com
  • Revelation78 Dec 22, 2007
    I tried to reset my garmin using the hold the bottom right hand corner of the screen and the power button for 30 seconds.. a minute later still on and locked up.. I tried waiting for the battery to die and eventually shut itself down. 4 hours later still going. I'm a truck driver near a place I never been before.. when garmin is working. it puts me on the right track everytime. so personally I'm a little desperate. anyone with a solution that actually works?
  • Anonymous Dec 23, 2007
    My Garmin c330 is locked up with a loader loading message when attempting to download updates. Will not shut off when power button is depressed.
WARNING: A reset will completely wipe the user information off the unit.
To reset the unit you will need to press the bottom right hand corner of your screen and hold in (relatively firmly) and then press and hold POWER, make sure you release the power button when the unit turns on and a message will appear asking if you wish to clear all user data - select YES to this.
This will completely wipe all data on your unit including almanac data (satellite information). Your unit would then need at least 45 minutes with clear view of the sky to update the almanac and re-acquire a GPS fix which will show your current position.
Your unit would then need at least 20 minutes with clear view of the sky to update the almanac and reacquire.
To reset the unit you need to press the bottom right hand corner of your screen and hold in (relatively firmly) and then press and hold 'power'. You need to hold both for 30 seconds.
Posted on Dec 20, 2007
  • 174 Answers
Pull the faceplate off. There is an indentation under the word GARMIN on the face which you can use to remove the faceplate. After the faceplate has been removed you will see the reset button on the right side of the unit. Press to reset the unit.
Posted on Jan 01, 2008
Street polit c330 stuk up
Remove the frame around the screen and press the reset button
Dec 11, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin won't turn on
I hope this helps, I had the same thing happen today. I noticed on the face under the word Garmin you can pop the face off and underneath on the right side is a reset button I held it down for 10 seconds popped the face back on and pressed the power button it came on. I hope this works for you.
Mar 20, 2009 | Garmin StreetPilot C330 GPS Receiver
My streetpilot c330 won"t shut off.
IT'S CALLED A FROZEN SCREEN...
2 OPTIONS
ONE, RESET IT !!! (See resetting instructions below)
TWO, let the battery die out!
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
Mar 12, 2009 | Garmin StreetPilot C330 GPS Receiver
Street pilot c330
It took a nap...
Feb 21, 2009 | Garmin StreetPilot C330 GPS Receiver
My street pilot c330 wont power up
I am continually amazed by how many people list there problems with only the barest of explanation. How on earth do you expect a reasonably informative answer when your total description of the problem is "my street pilot c330 wont power up"? OK, so tell us more! Did it work just fine until one day it stopped? Did you let it sit for 6 months and when you plugged it in again... nothing? Did you check the fuse in the power cord? Oh, you didn't know there was a fuse there? Read the book! If you want help from me, kindly describe in a bit more detail just exactly what the problem is, a bit of history of what, if anything, led up to the problem, etc.!!!
Jan 27, 2009 | Garmin StreetPilot C330 GPS Receiver
My Street Pilot C330 will not navigate pass the where to/view map screen Screen seems to be frozen
I have a c340 and instructions say: if your unit locks up. press the power button to turn off the unit, then press again to turn unit back on. If this does not help, reset by the following: place your thumb nail in the groove located under the Garmin logo on the face plate, gently pull off the face plate, press the reset button, turn the unit back on and it should operate normally
Dec 27, 2008 | Garmin StreetPilot C330 GPS Receiver
Street pilot is dead
It took a nap...
Aug 30, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin freezes
2 OPTIONS
Jun 13, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin Street Pilot C330 - screen problem
This doesn't fix Sitfar's problem, but for those how might find this helpful from Garmin's site: Question:  The touch screen is not responding correctly when I touch it. How can I recalibrate the screen?
Answer: To recalibrate the touch screen:
  1. Turn the unit off.
  2. With the unit off, touch and hold the Power button for 30 - 40 seconds.
  3. Follow the instructions on the screen.
May 09, 2008 | Garmin StreetPilot C330 GPS Receiver
Street pilot
There is a reset button on the unit
Aug 14, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
187 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
