Question about Pioneer CDJ-1000MKII CD Player
Main LCD display doesn't work!
this thing was working fine, while it was on, i was moving the cdj, i lifted it up at a 60 degree angle had it in that position for maybe 2 secs, and then i saw the main LCD display just shut off.
since then, the LCD display does not show anything or turn on. everything else seems to be working but i just can't see anythign!
please, if you can tell me what happened, or how i can solve this.
how much would it cost to repair? ahhhhhhh
  • 515 Answers
This is a tricky one. There is a very small/thin ribbon cable which connects the LCD display to the main board. If this shifted, or came loose - highly unlikely, but possible - it might explain the issue you are having.
You will have to open it up to see if anything is loose, or not properly connected.
Or, I would suggest taking it to a qualified service center for repair. If the LCD is not damaged, shouldn't be too expensive. If the LCD just burned out, then look to spend about US$120-160 for the repair, including parts.
- Davis
Posted on Jul 12, 2008
I want to know the torque opel corsa lite 1.4 cylinder head bolts.
stage 1 ... 25 Nm (18 lb ft)
stage 2 ... angle tighten + 90 degrees
stage 3 ... angle tighten + 90 degrees
stage 4 ... angle tighten + 90 degrees
stage 5 ... angle tighten + 45 degrees
Feb 26, 2015 | Opel Corsa Cars & Trucks
Is there such a thing as a reset for the Autohelm WIND ST 50? I purchased a boat with one that showed proper wind angle but not speed. I removed the sender, greased both the wind vane and cuos. now
I assume you have an ST-50 or ST60 windvane setup. These are the calibration instructions from the unit manual for the ST-50. They are the same for the ST-60 and ST-60+ units.
Hope it helps you.
Initial Calibration Windvane Alignment
Before the unit is used for navigational purposes the masthead transducer must be accurately aligned to the vessel. Before this procedure is carried out the windvane should be linearised as follows.
1 . Powerup lhe ST50 Plus Wind instrument.
2. Tum the vessel through two complete circles, making sure that the windvane remains in line with the wind -the instrument will automatically linearise the windvane.
1. Press and hold CAL for 2 seconds until CO is displayed by the LCD.
2. Press < > to move the pointer to the correct wind angle.- WIND
- Press < > once to move the pointer by 1 degree.
- Press < > for 1 second to move the pointer by 10 degrees/second.
The LCD will now display the applied correction.
3. Press and hold CAL for 2 seconds to exit and store windvane alignment.
Windspeed Unit Selection
1 . Press and hold CAL until Ul (Knots) or U2 (Meters/second is displayed.
2. Press CALwithin 8 seconds to change the windspeed units selection.
3. After 8 seconds the wind instrument returns to normal operation.
Nov 22, 2014 | Boating
Its a major road with a 60 degree angle . how to find unknown angles
Which unknown angle? If a road meets another at an angle of 60 degrees then the angle is 60 degrees.
Nov 05, 2013 | Office Equipment & Supplies
The LCD screen flickers on a perticular angle... open normal --- working.. no flicker (Cam and LCD at Rt. Angle) Twist screen by 180 degree... still working no flicker Now move twisted screen...
The most likely cause for this is a damaged or defective flexible ribbon cable that connects the LCD to the camera body and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on
Aug 04, 2011 | Sony Handycam DCR-SR42 Camcorder
I want to purchase a pair of pioneer CDJ 850 players, however in my country the power supplied is 110 volts at 50hz. I have had problems using electronic devices that only specify 60hz. The CDJ 800's...
The 850's should work fine on 50Hz. They are spec'ed at 120/60. with your lower voltage the transformer in the power supply should NOT have a problem. There is nothing syncronized to line frequency so it should work fine.
Jun 01, 2011 | Pioneer CDJ-850 CD PLAYER
Driver side wiper only moves when it is lift off window at a 90 degree angle. other wiper is fine.
it sounds to me like the wiper gear is possibly stripped out and only working when it isint under pressure try replacing the gear on that side it should take care of the problem
Jan 12, 2011 | 2000 Nissan Frontier
Not sure how to use the calculator for my physics class? Problem x and y components of the vector A = 10.0 @ 60.0 degrees
There is not much you can do with the information you provide. One has to assume the application point to be (0,0) and the angle the vector makes with the positive X-axis is 60 degrees
The X-Component is X_A=10*cos(60 deg)
The Y-component is Y_A=10*sin(60 deg)
To calculate the values of the X, and Y components you must make sure the angle unit is degree.
  1. Press [MODE]
  2. Move cursor to the line that says RADIAN DEGREE
  3. Highlight DEGREE and press [ENTER].
  4. Press [2nd][QUIT] to exit the configuration screen.
To get X_a type in 10 [COS] 60 [ENTER]
Oct 08, 2010 | Texas Instruments TI-84 Plus Calculator
Hello i have problem with Screan/Display on my CDJ
I have exactly the same problem. Normally it is one of the fuses on the power supply board but this time all fuses are ok. Let me know if you get a fix.
Mar 30, 2010 | Pioneer CDJ-1000 CD Player
Pioneer CDJ-1000 CD Player jog wheel display
The only way of solving this is to bring it to repair shop and get a replacement screen.
Jan 30, 2009 | Pioneer CDJ-1000 CD Player
Round lcd?
Unfortinetly i cant recommend to you a quick fix or a quick check as the fault seems to be intermittent,
i would suggest taking the player to your cdj pioneer dealer.
email: for all your dj equipment repairs.
Aug 16, 2008 | Pioneer CDJ-800 Turntable
Pioneer CDJ-1000MKII CD Player Logo
191 people viewed this question
Top Pioneer Audio Players & Recorders Experts
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
