FixYa.com
Tags:
Vapor TR-5 Wet/Dry Vacuum
Fiero cooling system
By Janice - usenet poster
84 fiero 2m4, 2.5L, 4spd
I have a very slow leak in my cooling system.  I've just been filling the
reserv once a month and so far that works fine.  However, my radiator
doesn't get hot, even after 1 hour of driving.  my temp gage is always in
the middle.
I can't find the leak because it is so slow.
Is there a danger of overheating if the radiator doesn't get hot or build up
pressure?
gasol @hotmail.com
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 09, 2005
Not Rated (0)
Phoebe
Phoebe - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Yes, having the system pressure checked would be a good idea, but you already
know there is a leak somewere. If it is internal it will have the white,
chocolate milkshake look to the oil on the underside of the filler cap or the
oil dipstick. Since you talked about no heat in your radiator, there is no water
movement to the radiator. It could be that the head might be cracked? Lets hope
not. Try the cheapest route first, replacing the thermostat, then if it doesn't
solve the problem, ensure that the water pump is actually working.
Check for a working water pump: With engine cold! Remove the filler cap on the
block. Remove the thermostat. Turn on the engine, if water pours out, the pump
works. Turn it off and replace the thermostat and add till full enough cooling
fluid. It wouldn't hurt to use the Copper seal or Alumaseal product, it will fix
a leaking head and is much less expensive, but it is not a permanent fix! Save
your money for a replacement head if the thermostat didn't fix it.
P.S. I was told in my 84, that I had a cracked head with the same problem
mentioned. It turned out that the thermostat replacement lasted me for four more
years of faithfull service "with a cracked head". I stopped driving the car when
I got the 88 GT. I still have the car but the motor was sold to make way for a
267 Chevrolet v-8, that I managed to squeaze into the engine bay. That motor
sucked! But it was fun to do. The car is currently "resting" in south Georgia at
a friend's house awaiting a reunion with her sisters. -Dade
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
LiZzIe
LiZzIe - usenet poster
Rating: 0%, 0 votes
Check the base of the coolant fill tube on the engine. You'll probably have
to remove it to check it properly. I had one corrode through. The water
evaporates as soon as it comes out so doesn't leave much evidence.
Solution #3
Not Rated (0)
Duke
Duke - usenet poster
Rating: 0%, 0 votes
You seen quite positive about this one John. Well, uh, um, NO. 84's are
notorious for cracking heads, and this is exhibiting the exact symptoms of
that.
Da Rev
p.s. Have (or do it yourself) the cooling system pressure tested. Also,
chances are you are going to find water in the oil (milky substance can be
seen on the underside of the oil fill cap) and will probably toast a bearing
soon if not rebuilt.
Solution #4
Not Rated (0)
Bray
Bray - usenet poster
Rating: 0%, 0 votes
Your termostat is busted. If it has ever gotten over heated the wax pellet
inside will release and the thermostat will not open when needed. It is
basically bypassing the radiator completely and just running the same over
heated water around in the engine. Replace the thermostat  (remove it
temporarily NOW and save the money and your engine!) might be a good idea to use
Aluma-seal or Copper-seal radiator sealer in your system also it looks like
powdered metal flakes, since you'll be at the parts store anyway. :)
John Dade
Solution #5
Not Rated (0)
Ross
Ross - usenet poster
Rating: 0%, 0 votes
Got simular problem with an 88 Formual...I think I have no coolant system
movement.  I have no milky oil value, so hopeful that I don't have cracked
head on my hands.  Will take Dave's advice and pressure check the system,
check the thermostate and water pump.  I've used Copperseal type products
before (different vehicles) with good success.
-Gary
Solution #6
Not Rated (0)
Bomber
Bomber - usenet poster
Rating: 0%, 0 votes
Gasolene
I have fought the coolant system leak problem on my car. Here is a list of all
that I had to fix before I got rid of all of the sources of leaks
 Radiator had a leak (The engine did get hot)
 Water pump had a leak (it made alot of noise)
 Coolant hose by the intake manifold had a slow leak (no indication other than
antifreeze smell until the coolant got low then it overheated)
My advice is as follows:
 Fill up the coolant system
 Start the car and let it sit (maybe drive it a couple of miles to get it warm)
 Stop the car and look for a drip someplace
 Raise the trunk lid to see if steam vapor is coming from someplace obvious
If the leak is slow and the car warms up something is going to drip or turn to
steam
There may be water stains to help find the leak.
Solution #7
Not Rated (0)
jessie25
jessie25 - usenet poster
Rating: 0%, 0 votes
Philip
I had a leak that dripped onto the engine that made it so I could smell the leak
but it was so slow that nothing showed up. It only leaked when the car was
running. No wet carpet
Solution #8
Not Rated (0)
Ross
Rating: 0%, 0 votes
I do smell coolent when I drive, but I keep my coolent filled and so far the
temp gauge stays normal.
Is there anyway to tell if the car is overheating other than the temp
gauge??
Solution #9
Not Rated (0)
Putty
Putty - usenet poster
Rating: 0%, 0 votes
If you smell coolant while you're driving you may have a heater core leak.
Solution #10
Not Rated (0)
Ross
Rating: 0%, 0 votes
I had those effects in a 92 Excel, six months later I lost the head gasket
with a cracked head.  Have your whole cooling system checked out
immediately.  The sensor, thermo, everything.
Solution #11
Not Rated (0)
kcw573
kcw573 - usenet poster
Rating: 0%, 0 votes
The thermostat was recently replaced & I think the coolent is circulating
because I get lots of heat.  There is lots of coolent in the reserve.
could it be the pump if I get heat??
if it is the pump, shouldn't it be overheating??
Solution #12
Not Rated (0)
herself
herself - usenet poster
Rating: 0%, 0 votes
The reason the cooling system is designed to operate with pressure is to raise
the boiling point. Loss of pressure can cause some cars to overheat even when
there are no other problems.
I recommend taking your car to a shop and having them pressure test your system
to locate the leak. If there is no visible leaks then have them test the
coolant for presence of hydrocarbons (exhaust fumes) as this may show a head
crack or gasket problem.
-ANT
P.S. for 10,000 Quatloos, what was the first car to use a pressurized cooling
system? I'll give ya one hint, it was American.
Solution #13
Not Rated (0)
Charlie
Charlie - usenet poster
Rating: 0%, 0 votes
Stab in the dark, but it sounds like any of 4 things:
1) Bad temp gauge/sensor
2) Bad thermostat
3) Plugged rad
4) Bad pump
Sean
"Duct Tape is Good To Mach 3"
Solution #14
Not Rated (0)
Brad
Brad - usenet poster
Rating: 0%, 0 votes
84 used the swirl port cylinder head for the first time, I think. This was
the year they had many, many problems with cracking between the valves,
extremely bad on #s 1 and 4. Keep checking your oil fill cap and dipstick
for condensation (milky white substance). Had the same problem with my 84,
and after 2 heads and 3 engines (in 66,000 miles) I finally gave up and
started a v6 swap, only to sell it incomplete.
Da Rev
| "Sean Fogg" <umfog @mail.cc.umanitoba.ca> wrote in message
| > 2) Bad thermostat
| > 3) Plugged rad
| > 4) Bad pump
| > Sean
| > "Fiero Racer" <fierora @home.net> wrote in message
| gasket
| > > "Gasolene" <Gasolene2 @telusplanet.net> wrote in message
filling
| > the
radiator
always
| > in
| > > > the middle.
| > build
| > > up
| > > > pressure?
| > > > gasol @hotmail.com
Can you Help with these Vacuums problems?
Vacuums
Possible missing screw and not
Possible missing screw and not... Answer This...
Vacuums
Do you deal with Royal
Do you deal with Royal vacuum... Answer This...
Vacuums
how do I change the
how do I change the belt on a... Answer This...
Vacuums
Hoover windtunnel cyclonic...
Hoover windtunnel cyclonic... Answer This...
Vacuums
Bissell 7901-1 Problem: no...
Bissell 7901-1 Problem: no... Answer This...
Repair Service
Find Vacuum Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
