Question about Protron PLTV-4250 42 in. LCD Television
Removing the stand/base off of the PLTV-4250
How can we remove the stand/base from the PLTV-4250? We removed the four screws on both sides of connecting the rods, but something is preventing the rods from siding out. Please help, customer support was helpless.
THANK YOU!!!
  • 2 more comments
  • Anonymous Apr 10, 2008
    remove stand base, four screws on both sides and still will not remove base
  • Anonymous May 13, 2008
    can not remove base from tv
  • Anonymous Jan 01, 2009
    Cannot remove base. Only solution I see is to "yank it off." Not sure that's the best solution.
  • Anonymous Mar 25, 2014
    No sound but do have picture. Not on mute
I did the same exact thing. I unscrewed the main screws holding on the base, the rods run up through the TV, and I still couldn't get it to come out. So, I went and hired a repair guy to come and tell me what I was doing wrong and he said it should come right out. All he did was give it a good hard yank, and out it came. I was afraid I would tear up something, but it worked. Good luck. P.S. Those idiots at Customer Service don't care at all.
Posted on Jan 28, 2008
How do I remove the stand from a toshiba 32hl57 tv
  • 1 & 2 Remove all cables and lay down towels on a clear space.
  • 3 Set the 32HL57, screen side down, onto the towels gently.
  • 4 Locate the four screws at the bottom center of the TV. These screws attach the stand to the Toshiba 32HL57.
  • 5 Using the Phillips screwdriver, unscrew all four screws, one at a time.
  • 6 Once the screws are completely removed, grab the base of the stand and gently pull away from the TV.
  • Read more : http://www.ehow.com/how_7318172_remove-stand-toshiba-32hl57.html
    Jan 20, 2015 | Toshiba Televison & Video
    I need a stand for 42
    Hello.....Try this link....http://www.retechtv.com/products/protron-pltv-4250-tabletop-base-pedestal-stand.....They may have the replacement for you.....I hope this was helpful.....PEACE....
    Feb 08, 2012 | Protron PLTV-4250 42 in. LCD Television
    I Have a Panasonic Veria TH37PX600B flat screen TV with no manual,what I would like to do is take it off it's stand to wall mount it.But how? I've tried removing various screws and plates but it...
    Unscrew the base screws attaching the base to the TV set, once the four screws have been removed, the TV can be seperated from the base as shown below. The circles are where the screws were on mine before I removed the base.
    Jun 12, 2011 | Televison & Video
    I can't remove the stand off the tv
    Hi, i have instruction on removing your base stand.
    Removing the Pedestal Stand
    1) Carefully lay the front of the unit face down on a flat,
    cushioned surface such as a quilt or blanket. Leave the stand
    protruding over the edge of the surface.
    Note: Extreme care should always be used when removing
    the pedestal stand to avoid damage to the LCD panel.
    2) Remove the jack pack cover on the back of the TV to expose
    the pedestal stand screws. The jack pack cover can be removed
    without tools.
    3) Remove the four screws shown in the diagram below. This will
    allow removal of the pedestal stand.
    4) Once you have removed all four screws holding the pedestal
    stand in place, remove the pedestal stand from the TV by
    sliding the pedestal stand away from the TV.
    Feb 12, 2011 | Toshiba REGZA 52RV530U LCD TV
    How does one remove the Toshiba TV stand. There does not appear to be any levers etc to release it. We want to mount our TV on the wall so the stand needs removing.
    ya we put four screws in the base of the stand you have to lay t.v. on a flat surface protect the screen from getting damaged by putting a blanket over it when u flip it over or lay it flat on the bed you will see the 4 screws that hold the base to the t.v., but if it's a model that's having trouble just leave the base on as you will probably be returning it the store where you bought it lol
    Aug 24, 2009 | Toshiba 40RV525U 40 in. LCD TV
    Removing the stand on Insignia LCD 26F TV
    My insignia 26 inch dvd combo TV stand can be removed by removing the access cover to your input connection. There are eleven black phillip-head screws. The three bottom screws also hold the plastic base cover in place. Remove all eleven screws and pull the stand out from below. The four philip-head screws on the back center of the TV is for the location of the wall bracket mount. Good luck.
    Jan 26, 2009 | Insignia LCDTV26 26 in. Television
    Pltv-4250 post
    YOU NEED TO INSERT A FLAT BLADE SCREW DRIVER BETWEEN THE PIECES AT THE TOP OR BOTTOM EDGES. THERE IS A LITTLE EDGE ON THE INSIDE OF ONE PIECE AND A SLOT ON THE OTHER PIECE THAT LOCK THE 2 PIECES TOGETHER. EVERY 4 TO 5 INCHES THERE IS ANOTHER LITTLE LOCK PIECE.
    Dec 07, 2008 | Protron PLTV-4250 42 in. LCD Television
    Remove base of Insignia ns-ltdvd26-09
    to remove base from insignia tv
    1)remove plastic cover from bottom rear of tv
    2)remove 8 philips head screws on rear of tv above base
    3)pick up tv and base will come off
    once you remove it you realize how easy it is
    Jun 29, 2008 | Insignia LCDTV26 26 in. Television
    42'' LCD PLTV-4250 MOUNTING
    The universal mounts generally have a selection of screws that are to fit different makes and models of tvs.
    If you bought the appropriate size mount for the size of your TV, there should be mounting holes that match your TV, and screws that will secure it.
    I have not seen any mounts that use more than four.
    Apr 07, 2008 | Protron PLTV-4250 42 in. LCD Television
    How to Remove the Base
    I have an Olevia 42" TV. I was able to remove the base by removing 16 screws on the back side. They were arranged vertically in 4 sets of 4. The screws go through the back panel, through the base and attach (without nuts) directly into the inside of the TV. After removing the 16 screws the stand simply slides out.
    I tried removing two screws underneath the base area. They were small screws and were a pain to remove. I thought I would try that first instead of removing 16 screws but that did nothing.
    Dec 10, 2007 | Olevia LT42HVi 42 in. LCD Television
    Protron PLTV-4250 42 in. LCD Television Logo
    171 people viewed this question
    Top Protron Televison & Video Experts
    Jaime Hernandez
    Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
