Question about Samsung HL-S5087W 50" HDTV
Screen flicker The screen of my Samsung s5087w is flickering. I can hear a noise coming from inside the set that may be the color wheel rubbing against something? Please help.
  • brad4900 Dec 01, 2007
    Thanks!, I still hear a noise after turning the set off. If the problem is a fan, how labor intensive and expensive will it be for me to replace it?
  • immortal1974 Feb 03, 2009
    I have the same light flickering problem. I notice it mainly when im playing video games on my xbox 360. I thought it might be the lamp as when i replaced the lamp the last time the flicker stopped but then started again after the lamp was less than a year old. I do hear the fan slowing down after i power the tv down, but this normal isnt it? A fan will not instantly stop in any electronic device that requires one, Ive read alot and seen people saying it could be the DMD board or SEINE CBA. I would really like to know where the issue stems from so i may get it fixed. The flicker comes and goes, it will do it for about 30 minutes to an hour then stop for several hours then start again. If there is any accurate information on this problem please provide it. I spent alot of money on this tv and I really like the tv, the picture quality is incredible except the flickering light! I have no other problems with the tv nor have i ever.
  • 934 Answers
When you turn off the set listen carefully... If the noise stops abruptly it's the color wheel, if it winds down a bit after you press power off it's a bad fan..
Posted on Dec 01, 2007
  • William Rayburn
    William Rayburn Dec 02, 2007
    If you're asking the question I would ass-u-me it's a bit beyond your ability... Not costly though...
  • Lacy Sep 25, 2012
    is that why it's causing the static sound?
Lamp comes on but without picture
The color wheel is the likely problem here.
Nov 27, 2012 | Samsung HL-S5087W 50" HDTV
Hi I have a Samsung HLN467W, a 46" DLP TV. And after 50-60 minutes, it starts to flicker white, like lightning flashes. But the whole screen is not blank white, it's more like the images are...
It seems color wheel problem in your tv that gets problem after some time and you hear high pitch noise along with picture flicker.
Color wheel need to be replaced to solve this issue. Required color wheel is available with (click to view image of part and price info) and it is job of qualified tv repairman because light engine will take apart for that.
Hope these info will help you.
Mar 15, 2011 | Samsung HLN467W 46" Rear Projection HDTV
My Smasung projection TV keeps flickering, also every hour or so the screen turns to a green flicker. I have to unplug the power cord and that temporarily fixes the problem. How do I stop the flickering?
The tv colors wheel is dying,replaced the tv colors wheel,will solved this problems.Hire a tv change the tv colors wheel,it pretty hard to change the colors wheel in this tv.Because u require take out many machanical parts before u even can come to the tv colors wheel itself to change it.
Nov 08, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
My screen color looks like the green and the red are split.
U hear grinding,squiling,motor noises,picture flicker black&white?This tv have a colors wheel.The problems u describing sound like the colors wheel it not functions correctly any more.
Jul 16, 2010 | Samsung HC-P4752W 47" Rear Projection...
Tv went grayscreen, flickering. turned off, then
When you had gray screen and flickering you had only one problem - color wheel. After "putting everything together" you have totally different problem, caused by multiple possibilities like: forgotten connectors, cut/jammed cables/wires, lamp not being inserted properly, lamp door not being set properly, disconnected color wheel, etc. Try to open rear cover and redo what you have done. Remove optical block, check everything visually and slowly put everything back. If still no luck - then only skilled TV repairman may (or may not) help.
Mar 10, 2010 | Samsung Televison & Video
Samsung hl-s5087w noise problem
a growling sound can mean a defective light engine as there have been issues described a s a growl or groan sound when a light engine is defective
Jan 26, 2009 | Televison & Video
TV grinding noise
A grinding noise in that model usaully means the light engine is defective or it could be the color wheel. But light engine is most suspect as there have been some issues with the light engine assemblies
May 11, 2008 | Televison & Video
Missing Color.
the color wheel may spin but if you hear noise when it spins it's bad. the jumper is used when replacing one type of color wheel for a nother type. so donot remove jumper unless you've replaced the color wheel and the picture is bad. if the color wheel is good replace the DMD board. if the DMD is not available replace the optical engine.
Jan 22, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung HL-S5087W 50" HDTV Logo
177 people viewed this question
Jerry Greenberg
Jerry Greenberg
