Question about Sony KV-32S26 32" TV
Won't Turn On
Just picked it up from the side of the road. No surprise it doesn't turn on. I realize it could be a plethora of problems but we want to start with replacing the power system. What parts do we need and how can we get them? Thanks!!
  • 2ndhandcash Dec 08, 2007
    I have the same Tv with the same problem. I know that both 2sc4834 are dead, along with the resistor. I cannot find the Horizontal IC with that number, is it on the same board? I have not been successful on finding a service manual for this model.
I had problems with same unit turning on and then shutting down full power cut out and then it would sometimes work fine for hours.
Some components soldered in Mex. and some boards soldered in other 3rd world manufacturers, depending on problems, it may be just a bad joint on one pin on a vid board or other board.
Total power shutdown caused by bad solder joints on main power supply transformer, resoldered and it has not missed a beat in 10 years.
Posted on Dec 11, 2007
  • 1,694 Answers
REQUIRES carefull, meticulous soldering of horiz drive circuit
before replacing four parts or it will blow again...........
Parts list.......
Horiz output = 2SC5148 Use OEM or equiv....NO generics...
use 237470 RCA or very expensive SONY or
if it is 2SC4927, use first quality only = measure
Base to emitter LESS than 50 ohms.....
two converter transistors = 2SC4834 generic ok
one .1 ohm resistor R607................
Purchase from TV shop or electronic parts supply........T. know..................
Posted on Dec 05, 2007
  • Vista Electronics Dec 05, 2007
    Ps resistor can be half watt or one watt...........
2002 PT Cruiser. Well first my vehicle was overheating then I put coolant in the radiator and it was going well until it passed the middle of the thermometer so therefore it still over heating. My engine...
Are you saying the car you have now stopped on the road because of no oil in the engine ?
Can you give more details of the car you have now and what you have checked ?
Jul 05, 2013 | Cars & Trucks
My 1991 Ford Tempo won't start. It turns over but doesn't spark. The battery has been replace, checked fuel pump and spark plugs but it still won't turn on. Help?
change the ignition pick up coil assembly normally located on the distributor under the rotor on the bottom of the distributor or just replace the distributor
Jan 30, 2013 | 1991 Ford Tempo 4 Door
GMC 2000 sierra pick up 1500 sounds like it wants to start but won't turn over. Battery sounds good so I guess battery and alternator are ok. For several years fuel gauge doesn't work and...
It sure could be. But, "won't turn over" you do mean it cranks at normal speed but won't start?
A simple test of the fuel pump is to stand by tank and listen as someone turns key to on. When first turned to on, your pump will activate for 2 or 3 seconds, pressurizing the fuel system, and then shut off if the engine computer doesn't get a cranking signal. Do you hear it come on? If not, then something's not turning your pump on. If you can hear it buzz on briefly, then maybe it's your filter. Another test: Spray a little starting fluid into your intake manifold (remove the big hose going into intake manifold) while someone tries starting it.If it doesn't fire and try to stay running, then it's probably an ignition problem. But if it does fire off, then you know it's a fuel problem-likely your pump or filter. good luck.
Nov 07, 2011 | 2000 GMC Sierra
2002 Dodge Caravan,3.3L,Engine won't turn over at the key.Battery,starter and relay are good.Relay doesn't function when plugged in.It has 2 feeds.If you run a ground to the ground side of the...
It has 2 feeds.If you run a ground to the ground side of the relay,engine turns over but doesn,t run ????? The PCM - engine computer isn't supplying the ground for some reason . Anti-theft system problem . Disables fuel an starting systems . Have you checked for codes ?DTC'S - diagnostic trouble codes .
Mar 04, 2018 | 2001 Dodge Grand Caravan
My laptop won't turn goes dead and doesn't turn back on..Is there some procedure to help this..its an acer aspire 5532..
When you say it goes dead are you saying the batteries die because if so you do realize they have to be charged once in awhile right? If you do know that and were serious about the problem try removing the battery for a minute then replace battery and restart see if that helps!
Good luck!!!
Jun 08, 2011 | Computers & Internet
Sony KV-32S26 32" TV Logo
62 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
