Question about Toshiba 51H84 51" Rear Projection HDTV-Ready Television
Toshiba projection television
Red is out of place
  • 934 Answers
If setting the convergence in the menu doesn't help it's most likely the convergence amps. Your set takes two STK394-250A Sanyo built amps at Q751 & Q752 Toshiba p/n# 23135048. Also check, or have checked, the low ohm resistors in that circuit referred to as the yoke return resistors.
Bill
Posted on Dec 01, 2007
SOURCE:
Having problem adjusting red color once I place them together they fall apart again
it has an 2 convergence ic try look first for swollen capacitor beside the convergence ic and replace it.
Oct 15, 2010 | Toshiba TP50F50/51 50" Rear Projection...
Red keeps going out but there is a new bulb in place.
red light keeps blinking on and off but the tv isnt turning on
Jun 02, 2009 | Toshiba TN61X81 61" Rear Projection...
The red seems to be out of place on my toshiba 50h72 projection t
Replace both convergence ICs they are stk392-110 you will also need at least the six 1.8 ohm 1watt resistors. You can get replacement ICs and resistors at the following link and they provide free installation instructions so you can do the repair yourself.
heres the link.
http://servicemanuals.vstore.ca/
Jan 18, 2009 | Toshiba 50H72 50" Rear Projection...
The red in my tv is out of place
you will need to have someone come out and reconverge the tv for you. it shouldnt cost alot but its what you will need to do unless you can do it youself.
Picture red and green not lining up on my Toshiba 61HX70
Repair will require technical and mechanical skills.The red convergence IC will need replacement,which will require the chassis to be removed.After IC change,alignment in the servicer menu may be needed.Go slow--Remember, above all else,do no harm.You have a great tv,so my suggestion is get a senior tech on this one.
Sep 26, 2007 | Toshiba 61HX70 61" Rear Projection...
Color is Bland--Seems we're missing red color
THE PROBLEM IS THE SAME AS I HAD PREVIOUS,A PROJECTOR BULB HAS GONE ON THE RED PROJECTOR,YOU PROBABLY HAVE YOUR SOLLUTION BY NOW I HOPE SO ANYWAY.
Feb 24, 2007 | Toshiba 50H72 50" Rear Projection...
Toshiba 51H84 51" Rear Projection HDTV-Ready Television Logo
59 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
