Question about Magic Chef CER3725AA Electric Kitchen Range
Have a magic chef oven, f1 display after self cleaning, stove top works fine, any thoughts
  • 3 more comments
  • cadeco Dec 04, 2007
    I have an f1 message so I have to unplug my stove so the beeper would turn off, while in f1 I can't use my oven
  • Anonymous Dec 11, 2007
    I turned on the self cleaning yesterday...now the fan is on with F1 on control panel. oven is not working...elements on top are fine?!?! help
  • Anonymous Sep 27, 2008
    cut the red wire feeding the plezo-beeper between the fist and 2nd circuit boards. This is a common problem in Magic Chef glass top stoves and the company, now owned by Whirlpool, should have been subjected to a class action suit
  • Anonymous Feb 22, 2009
    self cleaned oven, now getting F1 error and oven will not turn on
  • Anonymous Mar 22, 2014
    How to clean door window between the glass panels
Your sugestion does not work.I press CLEAR/OFF and power off several times, the F1 error and beeping is continue every 2 minutes. Any other suggestion?
Posted on Jan 02, 2008
  • 22 Answers
F-1 is a fault code.
Disconnect the power plug or turn range power off at circuit breaker. Wait a couple of minutes, then plug the range in or flip the range circuit breaker to ON.
Oven control beeps & displays any F  code error (for example
F11) - Electronic control has detected a fault condition. Press
CLEAR/OFF to clear the display & stop beeping. Reprogram
oven. If fault recurs, record fault number. Press CLEAR/OFF
contact an authorized service agent.
Posted on Dec 04, 2007
SOURCE:
I have a magic chef range. I ran the self cleaning on the range. Now when trying to use the oven I get a F1 and a F3 code. I unplugged it for a while to reset and still have the same problem.
F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F3 or F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Nov 25, 2010 | Magic Chef Ovens
Good Morning, I bought a used Magic Chef stove. I don't have the manual. The alarm/bell keeps going off. The display shows "F-1" Would you please let me know how to turn off this alarm? I keep...
F1 Defective Touch Pad or Membrane
Replace Touch Pad or Membrane
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
Display Condition Remedy
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 20, 2010 | Magic Chef Kitchen Ranges
Self cleaned a magic chef, now receiving an f1 code. the oven won't turn on. the clock works, and the stove works
This is the classic F1 error which is usually caused by a component failure in the control board. We repair a lot of this type of controller and would be happy to have a look at it for you if you can have the controller removed and sent to us.
Best Regards,
Bruce
www.fixyourboard.com
Oct 13, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
My mom has a Magic Chef oven, model 5892VRV. It
You have 2 choices.
Replace the electronic control(clock).
Or, replace the range.(stove).
Sep 04, 2009 | Magic Chef Ovens
Magic Chef oven & broiler do not work
you know i am thinking more towards a bad temp probe.
May 28, 2009 | Magic Chef 31000 Gas Kitchen Range
Our magic chef oven f1 code keeps coming on
MAGIC CHEF
Range/Stove/Oven Fault Codes
F1 1. Watchdog on board
2. Touch membrane defective To determine which component is at fault, disconnect ribbon strip. If NO fault code, replace membrane, otherwise replace board F2 Oven too hot Check oven temperature sensor F3 F4 Open or shorted oven temperature sensor Replace F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Replace clock assembly (also called the ERC) F7 Function key shorted Replace touch pad F8 Analog/Digital converter Replace clock assembly (also called the ERC) F9 Door latch Check door lock circuit F10 Function key stuck Replace touch pad
Feb 07, 2009 | Magic Chef 31000 Gas Kitchen Range
Magic chef gas oven will not turn on
F1 means, defective touch pad or control.
Jan 09, 2009 | Magic Chef CGR3725 Gas Kitchen Range
"F1" error code on Magic Chef gas range Model 3488XRA
the burners on my magic chef stove work but the flame is not as high as it should be on one burner. I switched the top of the burner with another and it did not solve the problem.
Jan 03, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
Oven keeps beeping and displaying F1
this code is suggesting that you might need a control board.
Jun 21, 2007 | Magic Chef 9815 Electric Single Oven
Magic Chef CER3725AA Electric Kitchen Range Logo
1,117 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Steve Allison
Steve Allison
Marvin
Marvin
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
