Kenmore 80 series washer
My agitator on my washer all of a sudden quite working. Everything else works and it sounds like it is working but it doesn't move. It is also full of water as I was doing a load when it stopped working, how do I get the water out?
Thank you!
  • chrissiek Dec 01, 2007
    That worked! Now I need to figure out why it is not agitating. It does everything else just fine and it sounds like it is agitating but it is not.
    Thank you! Do you know how I would get to this part to replace it?
  • 447 Answers
You should still be able to drain the water by selecting a spin cycle and closing the lid, unless the lid switch isnt working
Posted on Dec 01, 2007
  • joey  shearer
    joey shearer Dec 01, 2007
    Most likely the motor coupling is broken. The machine wont agitate or spin but it will pump the water out. Replacing a coupling is fairly simple but can be daunting the first time. If you decide to try it yourself ill be glad to help as much as i can.
How do I remove the agitator from a Whirlpool washing machine ?
check this link part 5 and 7
Sep 17, 2014 | Whirlpool Washing Machines
Kenmore 80 series washer won't spin or agitate
check to make sure the belt hasn't come off. if it's direct drive make sure the shaft is working and moving freely. if all of these check out the motor that turns everything my be stuck, frozen up or just bad all together.
Jul 14, 2012 | Kenmore 24032\24036 Top Load Washer
80-series w/ broken top agitator
There is a video at that will walk you thru the replacement of the agitator dogs, this is a common problem with this style washer.
Mar 28, 2010 | Kenmore Washing Machines
Kenmore 80 series washer. Agitates immediately and does not fill
it sounds like the water valve is bad,the water valve level(sm. med. lg.)controls the water valce-mike
Jul 17, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 Series draining problem
Check the following before replacing the timer.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Jun 01, 2009 | Kenmore Washing Machines
Kenmore washer 80 series 110 model not spinning.
unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not.
need to know if it agitates or drains and just wont spin.
if it agitates but no spin or drain, then you have a bad lid switch.
if it wont agitate or spin, but will drain, then you have a broken drive coupling.
Jan 08, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series agitator problem
time to look for a new washer, this is a gearcase problem, or cluth. Not easy to fix , unless know how.
Nov 08, 2008 | Washing Machines
Kenmore Series 80 Washer goes through all cycles but will not agitate or spin.
Hi thanks for the question The part that has broken, is called the drive coupling . located between the motor & clutch. replace that part thanks the appliance doc
Oct 01, 2008 | Washing Machines
Washing Machines Logo
105 people viewed this question
Top Washing Machines Experts
