Question about Samsung HLP4663W 46" Rear Projection HDTV
Samsung HLP 5063W
Hi 6 weeks ago we replaced the lamp in our Samsung DLP 5063W TV, the color wheel needed to be replaced too but we tolerated the screeching color wheel and watched TV while waiting for a back ordered color wheel. Before the color wheel arrived the noise became unbearable, there was a popping noise and the screen went black. The new bulb, with likely less than 100 hours of viewing time on it, appears to be fine but we put the TV away, awaiting the color wheel. Now the new color wheel has been installed. We turn on the TV and get the blinking lights on the switch--all three blinking and then switching to "lamp" blinking--but no picture and no sound. We have double checked all connections.
  • AK52 Dec 02, 2007
    Thanks,
    Schematics would be great. Which board does the failure occur on most often?
  • Anonymous Mar 29, 2014
    Samsung DLP TV HLS 5087W Lamp bulb shattered internally --Installed new bulb but Tv will not lite the lamp--replaced the ballast --still won't light up the bulb--Changed the color wheel- Now the TV operates picture and sound but on the screen is "check the fan #2--replaced both fans #1 & #2- still have normal tv function with check the fan #2 on the screen. Removed the new fans & installed the old fan- still get check the fan #2 message on screen. What would you suggest I do next?
  • 4,102 Answers
Hi it sounds like the problem is with the convergenge ics these can be replaced but the problem usually comes from a bad resistor this causing the ic to go.
The only problem is without having the proper testing equipment in front of you you could keep guessing and never find the problem the best thing to do is if you dont have the equipment nor the knowledge of diagnosing the problem it is best left to somebody who know what they are looking for.
I see this problem often on these sites and it all comes down to the convergence ic failing they usuall fail to a resistor failing on the main board the board will need testing and tracing back from the ics to eliminate any resistors that could have failed.
I have seen alot of people that have replaced the ics without checking the resistors and then they have the same problem shortly after.
The resistors tend to start failing shortly after the warranty has run out.
The cheapest sollution would be for you to take the tell yourself to repair shop as calling somebody out might charge for the call out and for transporting the tell.
Their isnt much you can do yourself but if you need it i can get the spec sheet for you so you can follow circuit diagrammes let me know what you want to do
Posted on Dec 01, 2007
  • paul proctor Dec 03, 2007
    hi im jsut looking for the best place to get the schematics from sorry wasnt online ysterday but will look now for you ok
    Hi try this link to get your schematics from http://www.download.nitd.co.uk/news.php you should be able to get it from here but you might need to download some software to open the file as it will be a rar file i used winrar from http://www.download.zdnet.com if you have any problems post back this site will sometimes tell you about common faults with certain boards let me know how you get on ok speak again soon
SOURCE:
Samsung hlp-5063w no picture when its on
Do you have three flashing lights on the front? You most likely have a problem with your lamp or color wheel. Those two component combined are pretty much the guts of your TV. If you are handy, you can replace those parts yourself. I have a 50" Samsung DLP and I've already replaced those to items myself. Otherwise, you can contact Samsung at 1-800-SAMSUNG and they can assist.
I bought my parts using Amazon, had them shipped to me, and took an afternoon to take about the back of the TV; documenting everything and taking photos of the progress, until it was done. There may be video tutorials on Youtube. There was for my model (HLS5086). Here is a great link to help you along. Good luck.
http://blog.trebacz.com/2011/01/50-samsung-dlp-hl-p5063w-with-3.html
Nov 19, 2013 | Televison & Video
My Samsung HLP-4667W DLP TV has no picture when I turn it on.
The color wheel can be ruled out by looking at it---it faces the lamp and can be seen---look to see if any segments of the wheel are missing or if the wheel is totally shattered.
Other than the wheel I am concerned by "blue splotches etc" as it might be a DMD gone bad. Look at the attached photo and the color wheel first.
May 03, 2012 | Samsung Televison & Video
My samsung 5063w turns on and the screen is bright, no noise but the color is "faded" for lack of a better word? what could be the problem?
Reset all ur setting back to factory setting.Still same problems,might be the colors wheel is not woking right anymore.
Mar 26, 2010 | Samsung DLP HL-P5663W 56" TV
My tv is a samsung dlp 5063w I change de dlp bulb and now is working good but from the back of the tv is a loud noise
Ok look my friend..
first i need to know what type of sound is it. like a click or a buzz?
and then here are 3 suggestions.
first clean your TV with some latex globs and a can of compress air try to do it really good try that...
second. check that all the cooling fans are working just fine!
last one. its your color wheel and you need to change it.
here is a link were you can find the part and not so expensive prices!
http://www.discount-merchant.com/PANASONIC-Cooling-Fan-Set-Cooling-Fan-Set-p/1002171.htm
http://www.discount-merchant.com/product-p/samsung-bp96-00674a-cw-enc.htm?1=1&CartID=0
good luck!
Jan 21, 2010 | Samsung DLP HL-P5663W 56" TV
Samsung DLP TV has lot picture. Makes a Humming sound
That sounds most like the color wheel,
to change that you need to have some skill in electronics, I would recommend to take it to a shop
Apr 25, 2009 | Samsung DLP HL-P5663W 56" TV
TV won't stay on
Hello Fonzell!
Regarding the tv turning, my question is, do you hear a clicking sound? if so, it's most probable tio be your ballast, that might not have enough voltage to keep on with your lamp, and that's why it shuts off.
You could try replacing it and seeing if it resolves your issue, I believe they're running around 70 dlls..
have a great one ! :)
Apr 21, 2009 | Samsung DLP HL-P5663W 56" TV
My Samsung 50" DLP HDTV keeps humming when the DLP lamp comes on.
Hi, you have one of two problems, either the color wheel is going or one of the cooling fans are going, the color wheels are a very common problem in samsung dlp`s, sorry I can`t nail it to a specific part but I`d bet it`s the color wheel as they are notorious for failing in samsungs, video-tek
Mar 17, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Samsung HLP 4663W DLP TV 3 lights blinking
Color wheel is the biggest failure part in Samsung DLP...
A little technical to replace...............T.
Jan 22, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung HLP4663W 46" Rear Projection HDTV Logo
155 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
