Question about Reddy Heater RLP100 Portable Forced Air Propane Heater with Variable Heat Ouput
Irritation I have a PRO100 (RLP100) that I have only used twice in the last 7 years because whenever I turn it on, my eyes immediately start to burn andmy sinuses go nuts. I don't have any problems with other propane or kerosene heaters. The heater is continuously clicking while plugged in, which I think it is supposed to do, to keep ignited. Am I just too sensitive for this heater, or is it not working right. I follow all the directions on the side for lighting and running the heater...I just don't understand why it irritates me. Thanks for any assistance you may be able to provide.
  • 625 Answers
Once the heater starts the clicking should stop. the clicking is the high voltage to the spark plug. once you have a fire it should maintain itself. check the control unit.
Posted on Dec 02, 2007
How to adjust fuel mixture propane rlp100 this unit burns my eyes and the fumes are bad
It sounds like it needs a service if it is giving off fumes turn off and get it serviced asap
Dec 16, 2016 | Heating & Cooling
Ready heater Pro 100 (65-100,000 BTU0) strong oder that berns the eyes after a short period of time and is worse on low settings. Does have suffishent ventalation.What cold be wrong or cause this
Your eyes burn because the flame is burning too rich or too lean. Always start troubleshooting a fuel delivery problem by setting the pump pressure.
If the pressure is correct, check for a restricted fuel filter, a cracked end cover, air or vac leaks between the pump/nozzle and tank/nozzle.
DESA recommended annual replacement of the nozzle because they wear out and start producing a spray rather than a fog.
Oct 10, 2011 | Reddy Heater RLP100 Portable Forced Air...
I have a rlp100 heater that works well but now has an annoying smell. It also burns your eyes some. It is 3 years old and hasn,t been used much. What can I do to get rid of the smell?
The smell is unburned propane and the burning of the eyes is caused by carbon monoxide. My heater (RLP100) does the same and I was able to measure the carbon monoxide at 95 ppm (deadly). I have yet to figure out what exactly is happening. Tried a new regulator/hose from a new unit - no help. Also pulled apart the burner nozzle and cleaned the holes - helped a bit. Next step is the valve.
Dec 18, 2010 | Reddy Heater RLP100 Portable Forced Air...
My heater worked fine for a few months last year before it started burning a smaller flame and not heating as well. I then started noticing the increase of propane used. It seems as if it is running rich ...
Check for an air filter....many of these heaters have an air filter that gets dirty or clogged and then they will do just what you are describing her....
also take an air hose and blow out everything....
What you have there is an air/fuel mixture problem...
you are not getting enough air to the burner... most like because of dirt...
The only other explanation would be that the blower is no longer running at full RPM's....
You could also try to get some oil on the shaft of the motor to lubricate it and get it running back to full speed again...
Check the fan blades for dirt also...
Nov 27, 2010 | Reddy Heater RLP100 Portable Forced Air...
Why do my eyes always burn?
The eyes burn because nerves on the surface of the eye are irritated.
The nerves are irritated because something is wrong with the moist surface of the eyes.
Tears furnish moisture to the ocular surface.
Now, about your problem. The most likely cause for your burning is a defective tear film: inadequate tear production, abnormal chemistry, wrong, pH, etc.
It would be wise to have Dr. Easton evaluate you. It is most likely a simple case of dry eyes, but there are other major medical problems that include tear film deficiencies. Your physician knows what questions to ask and what diagnostic tests to perform. In the meantime, she can recommend the best treatment plan to relieve your discomfort.
Nov 23, 2010 | Health & Beauty
I have a pro100, from day one u start it up and it burns your eyes at any setting
Did you hook it up yourself? It may have the wrong size oriface does it soot up at all?
Nov 06, 2010 | Reddy Heater RLP100 Portable Forced Air...
Propane 100,000btu heater runs fine but has a lot of fumes, it almost burns your eyes
Go to my tip at for all your answers. Your air fuel mixture is off. You need a new air filter and need to set the bleed air. For that you need special tools which you can get at the information I give at my tip. Let me know if you need anymore help.
Thanks for using FixYa
Feb 13, 2010 | Reddy HEATER RLP100 100,000-BTU PORTABLE...
My propane construction heater -reddy heater pro100- will only work if I keep the control knob pressed in and hold it there, if I let it up the fuel flow stops and it will not burn but as long as the knob...
you need to change the vsafty alve when you push the knob you are lettingv the propain go directly to the burner and bypassing the safty valve...this is not big issue to replace just get the part and you will be easy able to rep[lace when you see it...
Sep 11, 2009 | Reddy Heater RLP100 Portable Forced Air...
Propane forced air heater
Need to make sure you are supplying a minimum tank supply of 100lb cyclinder. If smaller,you are producing co due to low gas flow
Nov 02, 2008 | Reddy Heater RLP100 Portable Forced Air...
Burning eyes, can't breathe.
These produce large amounts of carbon monoxide, so you essentially are poisoning yourself. Leave the garage door open part way when using it.
Feb 10, 2008 | Reddy Heater RLP100 Portable Forced Air...
Heating & Cooling Logo
89 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
