Question about Toshiba Satellite M30 Notebook
Wont start up
Started going slow n shut down 2/3 times now wont boot at all,only starts and will accept the password then only shows a short white bar flashing at the top left of the screen,
if restarted and press F2 it will show the bios after ir accepts password.
Doesnt seem to be able to read any thing ,i put a disc in the reader and it spins ok but wont read either
any suggestions please
  • 1 more comment
  • rfb640 Dec 01, 2007
    ok ill try it when i get home thanks
  • rfb640 Dec 02, 2007
    Romeet
    Thanks ur help but nothing worked
    my bios is detecting my hard drive but as soon as i exit bios my little white cursur comes back on the screen
    I also let it run with all the screws loose and the key board off but alwasys the same,,the cooling fan operates ok !!!!!!!!!
    I even twisted the chassi but all to no availolny one thing i did find once it was stripped
    in the middle of the space were the keyboard was there is an L shaped opening with a black chip of some kind,it gets very hot but not hot enough to melt the plastic coveri dont want to through it away as its been my companion for the last 3 years n never gave me any problems now it SICK. HELP
  • rfb640 Dec 03, 2007
    Hi Romeet
    Yes I did, all i get is the curser still blinking and nothing else
    it doest seem to be able to read any thing at all.
    i also checked the voltage and its ok ,i removed the battery n tried
    GRRRRRRRRRRRRR it dont want to work.
    Regds
    Ron
  • 66 Answers
Hello rfb640,
This is Romeet, i would like to help you with this problem. Please go into the BIOS and check if the hard disk is detected? if it is then remove the hard disk from the laptop and turn on, check if you get any error message for " disk boot failure" or something of that effect or you continue recieving the white cursor?
B.Regds
Romeet
Posted on Dec 01, 2007
  • Romeet Barmeda
    Romeet Barmeda Dec 02, 2007
    Hmm,did u try removing the hard disk physically from the laptop and then booting without it.Check if this gives you any error.
My Toshiba c-55 wont turn on the white button light flashes 4 or 5 times and then stops but it never turns on.
I heard of many power issues with these models. Mostly concearning the battery, it sounds like this may well be the case from the 'light flashing' issue.
The other problem involving slow start up/ being laggy could be down to the machine running hot and Windows is using passive cooling in the power options, or a failing hard drive can also cause software problems.
Dec 25, 2014 | Toshiba Satellite Computers & Internet
Flashing green light and monitor wont start
There are one or two capacitors that open in the power supply, sometimes it will have a bulge at the top, making it easy to spot.
Apr 05, 2012 | Acer Computers & Internet
Lap top locked wont accept usual password
When you boot up to the log in screen type in administrator as the user to log in once you have your computer running again you have to take control (administrator)control panel user accounts on the users tab,click the name of the computer administrator you can change the password there or if your computer has a system restore you can restore it to an earlier date which will have your personal settings or
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up
Press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
also
click start control panel user accounts
hope this helps
Jan 13, 2011 | Computers & Internet
ENGINE MISFIRE TO THE POINT, THE CHECK ENGINE LIGHT COMES ON. AN IT WILL START TO FLASH. AN WONT GO OUT UNTIL YOU TURN OFF THE CAR .60-65 IT WILL STOP, AS SOON AS THE CAR START TO SLOW DOWN.IT START ALL...
wait untill its dark outside, open your hood and start the engine. look around for white / blue or yellow flashes of light coming from your plug wires. most of the time the spark plug wires are worn out / degraded from heat , and you can see the small lightning flashes in the dark. if you see no light flashes ( shorts to ground) then you can have a cracked / faulty distributor , or bad spark plugs.
Jul 31, 2010 | 1999 Mercury Cougar
My computer with Windows xp gets to the log in page but wont accept my password,tells me that caps are on ( my password has caps in it)then just freezes there and wont boot into anything
now listen that start your pc and before windows starts press F8 and select the option safe mode and windows will start in safe mode and at welcome screen you will see two accounts one your own and adminstrater and click on that and go to user accounts in control panel and delete your password by seleting your account and reboot pc . note that graphics will be odd dont take tension about it okay
Aug 18, 2009 | Computers & Internet
Wont boot up starts up and go into windows but isnt showing icons ot task bar and i cant use my recovery disc that came with my notebook
a regular XP or Vista installation cd will work as well.... for a recovery if you have one on hand try a System Restore first if you can under : Start/Programs/Accessories/System Tools this process will take a while to shut down and reload so be patient.... make sure to select a previous restore point
Aug 05, 2009 | Acer Aspire 3690-2196 Notebook
Car was giveing slow acceloration fron time to time
When disconnecting an O2 sensor it could cause damage to the EGR system. Why was it disconnected in the first place?
May 24, 2009 | 1996 Honda Accord
Windows Xp wont boot up
try starting windows in safe mode and go to an earlier system restore point if that wont work try installing windows again if windows wont respond to this it will be a hard drive issue it will need replacing
Jan 22, 2009 | HP Pavilion dv9000z Notebook
It wont start up.
Part of the process that Windows needs to fire up has been corrupted. This prevents you using safe mode also. Generally only a repair or full install will fix it but first try a disc check
boot from any xp cd and select R at the first options screen.
select C drive by entering the number shown (1?)
hit enter when asked for admin password
type chkdsk /r (space between k and /r) and hit enter
let it do its thing - it may take some time.
Dec 21, 2008 | Computers & Internet
GA-8IPE1000 Pro
Hi, Does it start to boot from windows and then shut off or is it before windows? Try removing the HDD and see if it will still shut down. If it does not shut then with the HDD removed, then the OS on the HDD is corrupted. Thanks, Mike
Nov 02, 2008 | Intel Motherboard
Toshiba Satellite M30 Notebook Logo
154 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
