Follow up on "no power to my tv"
OK I changed the fuse at the power supply and the new one blew also. I am going to have to have it looked at by a pro, I know this, but I was wondering if anyone knew what it could be and about how much it would cost to get the job done, I would like to at least have an idea so I am not getting messed over when someone comes to look at it. ps. There was no lightning and the wall plug-in works fine Thanks for the help before on the previous question. tv turned off. friend said it sounded like crinkling aluminum foil found blown fuse on power supply, replaced fuse as soon as i plugged tv into wall outlet it blew again, was also told right b4 it went off tv looked like a 3,d picture all the colors were seperated. plz help low budget, expierenced it electrical but not electronics.
    Genius:
  • 1,030 Answers
3d picture ...sounds like to me a convergence amp issue...what type of tv is this?
Posted on Dec 07, 2007
SOURCE:
My mitsubishi tv started out with white dots on the screen.eventullay i heard a sizzle and pop and the tv went out. so i did research found that i needed to replace the dlp chip which i did and the la
Most likely a fuse blew when the lamp blew, there is internal fuses on the power supply board on these mitsubishi's, if the fuse is ok though then most likely another component somewhere failed.
Jan 02, 2018 | Mitsubishi WD Televison & Video
TV blew fuse. Replaced with 125v 5 amp from a 33 inch Toshiba that has gone bad. The 5 amp also blew. Purchased new 4 amp fast blow fuse for unit, now nothing happens, i.e., no blown fuse, no circuit...
replacing the fuses with random values is prolly not a good thing...but one thing to check is a big transistor know as the HOT. This will more than likely be clipped or screwed to a heat sink NEAR the flyback (big transformer, has a wire going into the big glass tube). That causes fuses to blow...If this does not work, let me know.
Nov 30, 2010 | Toshiba 13A23 13" TV
My tv is 3 years old. I was watching it yesterday.Something poped and it went black. what is wropng?
A capacitor shorted (popped) in the power supply then the fuse blew (went black) unplug TV, remove back cover, look for power supply; follow cord to it; find small silver can with top bubbled (bad)
unsolder/replace; replace fuse. plug in turn on.
Mar 20, 2010 | Protron PLTV-32 Television
Blew internal fuse in maxim tv
the fuse is on the power supply board. remove the back and replace the fuse with the exact type. if the fuse is ok, you'll need a new board.
Jan 07, 2010 | Televison & Video
My SW 22HT Kenwood subwoofer stopped working.The fuse was bad it was replaced and the new fuse blew again
The reason the fuse blew again is that an overload has occured. It could be a faulty part in either the power supply section, or the amp section. Follow the curcuit from the fuse, be on the look out for damaged, burnt parts, suspect anything on a heat sink.
Nov 30, 2009 | Audio Players & Recorders
Tv worked until I unplugged it and moved it, now it won't turn on.
Ok try connecting it to another plug see what happens if that does not work then more than likely your tv set blew the main fuse which is located on the power supply right where the power cord comes into your tv set, you can get that fuse in any electronic store and change it out yourself just be very careful,hope this helps thank you.
Aug 15, 2009 | RCA F36650 36" TV
Will not turn on.
If the TV is blowing the fuse in your house, It looks like a component in the power supply is shorted.
To fix the TV, you will need to buy a new power supply module or get the one inside the TV fixed.
Good Luck.
Apr 24, 2008 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Loud pop and picture is no longer available.....
blown resistor (42ohm) replaced this and it imediately blew it clearly shows that there is a short circuit in your tv. if you are a tech person please proceed as follows. 1 isolate power supply from hor.output section. 2 now check power supply section.i.e. switching tran., cap..diode etc. 3 if it becomes ok check power supply output. 4 if output is ok then check hor. output section.i.e. h.out tr.,cap& diode in eht winding. 5 check print near eht. 6 at finally eht. 7 see every thing is normal now. now reconnect power to hor.section. put on tv. good luck.
Sep 24, 2007 | Philips 7P6041W TV
Fuse location on tv
a fuse is a small glass tube about 3/4" to 1". it is located near the end of the power cord inside the tv. it is located in the power board supply circuit. there are several reason why fuse blew up. 1. sudden surge current/voltage in your area 2. shorted in either power supply or horizontal deflection circuits. when replacing fuse, be sure to change it with the same value. but if after replacement has been done and the fuse blew again, there is a short in the circuit as stated in reason no. 2. refer to a qualified service technician if you are not inclined with this job. good luck!
Feb 12, 2007 | Panasonic CT-32HXC43 32" TV
Let me give an idea ...after the fuse you have the bridge rectifiers and it can be all in one package or 4 individual diodes after that you have a big filter capacitor and then a power transistor called the switch mode regulator,this are major parts that can make the fuse blow up right away as soon as you plug the set in wall but these parts work along with about 30 other minor parts.If the fuse blew up at plug in it can be one of these but if it blew at turn on from the power botton it can go farther down the power supply,is hard to tell how much is damage and how much it will cost.Get an estimate and then decide.Good luck
Oct 02, 2006 | RCA D61W20 61" Rear Projection Television
Televison & Video Logo
179 people viewed this question
Top Televison & Video Experts
Ekse
