Question about Creda W100FW Front Load Washer
I have a creda simplicity 1000 front loader washer.
I have just moved into a new property and the taps are connected correctly to hot and cold but for some reason the washing machine is only filling with cold water not hot? how do i solve this
  • Toreba Dec 02, 2007
    I have exactly the same problem with exactly the same model of machine left to me in a house I moved into. I've no instruction manual. The hot water feed is connected to a spur off the hot water pipework in which there is abundant hot water. The machine will neither take water from this feed nor heat the water itself. Can anyone offer any advice more insightful than just making sure everything is connected and on?
  • Anonymous Dec 28, 2007
    tried hotter temperure to see if water will heat
    President:
  • Creda Master
  • 662 Answers
Check connections to solenoid valve. If no go just replace water solenoid valve.
Note: cold water valve fails first, it gets most use, if only using cold water, you can simply swap the hot and cold hoses at the tap, and swap the hot and cold electrical connectors on the solenoid valves, the hot solenoid is now the cold one and the washer can be used, cold only.
Click here if helped.
Posted on May 01, 2013
Premm, I can't find any reference to the online manual you mentioned. When disconnected, water passes through both hot and cold hoses under considerable pressure. The filters on the machine side of the hose fittings seem just as clean for hot as cold. Can there be a physical barrier inside the machine? Could it all be airlocked or something?
Posted on Dec 04, 2007
    President:
  • 1,294 Answers
Maybe the pipes are not connected to the heater on the wall. You could heat your water in the machine, if there is a provision; most machines have it.
Posted on Dec 02, 2007
  • prem mathew Dec 03, 2007
    Click on your brand name (below FIXYA) on this website, type in your model number & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, voila! u hv your manual on line.
    And dont forget to rate me, on this great site.
  • prem mathew Dec 04, 2007
    toreba
    First close your wall inlet, disconncet machine hoses; check to see if water comes from the wall inlet & if the valve works. If if is okay clean out screens on both ends of the hose/hoses.
Need operating instructions for creda simplicity 1000
laundry.manualsonline.com/manuals/.../creda/w100fw_w120fw_w120vw.html -
Mar 22, 2010 | Creda W100FW Front Load Washer
We have a second hand Creda Simplicity W100 washing machine and want to know if it needs to be connected to both the hot and cold water supply or if just the cold can be connected
yes you can just connect the cold water side however you will need to cap off! the hotwater side due to a reverse flow issue when the tub is filling
Jan 17, 2010 | Creda W100FW Front Load Washer
I need a manual for a Creda Simplicity 1000 washing machine as I have mislaid mine
In your browser bar, type in:WWW.HOTPOINT.CO.UK.
Click on after sales, and follow links.
Pease rate my solution.
Thanks.
Jun 30, 2009 | Creda W100FW Front Load Washer
Creda W100FW Front Load Washer. access to service drain plug?
Hi.
Remove lower rear cover of washer, locate pump, and remove large hose attached to it, remove and clean filter inside hose, check pump for possible blockage.
Please rate my solution.
Thanks.
Apr 19, 2009 | Creda W100FW Front Load Washer
Creda 1000 simplicity washing machine
try
www.theservicecentre.co.uk
creda and hotpoint website
good luck and rate me
Feb 17, 2008 | Creda W100FW Front Load Washer
Creda simplicity 1000 door hinge
I had the same problem and got a new one on ebay
Nov 30, 2007 | Creda W100FW Front Load Washer
Creda W100FW Front Load Washer Logo
936 people viewed this question
Top Creda Washing Machines Experts
Gerry Harvey
Gerry Harvey
paul
paul
matt
matt
Are you a Creda Washing Machine Expert? Answer questions, earn points and help others
