Question about Samsung HC-P4363W 43 in. TV/DVD Combo
Colors are horribly misaligned... Do not have manual convergence...
I have a Samsung HC-P4363WX and the colors are not aligning. I've searched this site for a solution but I can not adjust the convergence manually. Is this a sign that something going out or what? How can it be fixed?
Have you entered "Mute-> 1 -> 8 -> 3" to get to the remote convergence menu? There you can manipulate each color, null convergence, load last saved and make corrections. From this menu you should be able to determine if one or more convergence failures have occured.
Posted on Jan 25, 2008
Problem with the Samsung HC-P4363W 43 in. TV/DVD Combo TV shows partialy double vision in blue color.
The tv have a problems,known as a convergence problems,it is dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D picture look alike?Yes.The tv convergence board it is dead.The tv convergence board must require replacing 2 STK convergence ICS and some or all of it resistors too.Fixed the tv convergence board to solved the tv convergence picture problems.The tvs shops will cost u like $300-350 for parts and labors.
May 25, 2011 | Samsung HC-P4363W 43 in. TV/DVD Combo
Our tv just started having a fuzzy image and the auto focus function aborts during the red color alignment. is there a manual alignment I can do to fix it.
What does this fuzzy image look like? Does it have ghosting shadows. Of course it is possible to align red manually from the convergence menu. But first lets confirm that it is indeed a convergence related problem.
Aug 18, 2010 | Samsung HCL552W 55" Rear Projection...
ISamsung TV model # HC-P4363W
Check the tv out?If the tv have picture,colors R,G,B misalignment,picture have colors shadows,look like 3D pictures.The tv problems is it have a convergence problems.Very common on a DLP tvs.Very much repairables.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts,must replaced to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 17, 2010 | Samsung HC-P4363W 43 in. TV/DVD Combo
Picture is fuzzy and colors are distorted
You will probably need to replace ALL of the CRT's and do a Full Convergence Alignment by a very experienced tech. Never replace only CRT as it will be brighter than the other two CRT's.
Apr 08, 2010 | Samsung HC-P4752W 47" Rear Projection...
My convergence wont adjust on the blue and have no blue in screen
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
Feb 20, 2010 | Samsung HC-R4755W 47" HDTV
Cannot get the set to focus. Colors are blured
Sounds like a convergence misalignment, go into the tv menu and look for other adjustments sub menu and follow the on screen directions,this is a simple procedure but will take a little time to get it adjusted just right. Directions are also on pages 20 and 21 in your owners manual. Good luck!
Nov 26, 2009 | Panasonic PT-47WX49 47" Rear Projection...
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
Jun 13, 2009 | Samsung HC-P4752W 47" Rear Projection...
My hcp4752 started smelling hot now the colors are
It looks like you have a problem on your convergence panel. Look for burned resistors near the STK-* IC's. One or more of the STK-* IC's may be bad. When the resistors get hot they smell but so do the IC's. You can replace the bad parts or you should be able to replace the entire panel then go thru a convergence alignment.
Jun 06, 2009 | Samsung HC-P4752W 47" Rear Projection...
Now What???
I want to get this straight are you saying that you cant align them
and this is your focus problem or you have two problems that you cant get the convergence and the focus?
it might have been easier just to have the board replaced...
Samsung parts for convergance problem
Jan 28, 2008 | Samsung HC-P4752W 47" Rear Projection...
Covergence Problem
What exactly are you seeing on the screen? If one of the colors is only slightly off, you should be able to correct it with the standard menu. If one or more of the colors has suddenly taken a dramatic shift, and is curved inward at a side, it means that one of your convergence output IC's has burned out. You should not attempt to realign the convergence if this happens because you will only be messing up all the settings, and when the new IC is installed, the picture will still be out of alignment.
Aug 26, 2007 | Samsung HC-P4752W 47" Rear Projection...
Samsung HC-P4363W 43 in. TV/DVD Combo Logo
234 people viewed this question
Jerry Greenberg
Jerry Greenberg
